Has ne1 tried the uniquefire 2180 or UF 2170 26650 kits?
I got the UF-2180....Its a decent light. What do you want to know about it?
i will order the UF-2180 from Manafont. I want to use the well known 2.8 A user defined mode driver from kaidomain in it, set in high-medium-low...
I would like to hear if you measure the tail current, if you like the beam (any beam shot????) and most of all i would like to see some pictures of the driver, and the aluminum base-heatsink to prepare my mod.
Have you measure run times????
Most of all... do you like it????
I did exactly what you planned to do. The UF2180 works great with the 2.8A driver. added thermal paste to the pull and the body and heat sinking was sufficent. The light ran fine for 1 hour straight last night. The lens is plastic. It thows real well. However i put diffuser film over the lens to convert it to a flood light. Runtime seem excellent. Brightness remain the same even after 1 hour. The host seem a little glossy black. The tail cap current was of course 2.8A. The stock driver is direct drive in High. I measure 5.5A. That was the main reason why I swapp out the driver right away.
Do I like it?....Not really....Don't buy it. I think there are other higher quality 26650 host out there. I suggest you try the 26650 host from cnqualitygoods.
I got it and its a disappointment. The c-88 has a much better body, the 2170 body feels very light, not tough enough. I gave it to my dad, but I'll have to get him a protected battery cus I don't trust the one it came with.
Also, the http://www.cnqualitygoods.com/goods.php?id=1143 body is about the same quality as the 2170, so I definitely don't recommend it, but the http://www.cnqualitygoods.com/goods.php?id=1151 is a freakin monster and I do highly recommend it. The only problem is that it's a 2 26650 body and can't use just one.
Can you measure dimensions of driver which would fit?
Would this http://www.kaidomain.com/ProductDetails.aspx?ProductId=11408 and an SST-90 fit in this http://www.cnqualitygoods.com/goods.php?id=1151
Do you have both of those flashlights?
No, I didn't get the flashlights, I got just the hosts.
Nice. I thought you could confirm (or not) the weird outer ring which is seen here: http://www.cnqualitygoods.com/images/upload/Image/26650T6.jpg
Is the reflector on that host 30mm deep? That is the spec on taobao but no specs for the reflector on CNQ.
It's 30mm deep and 50mm wide
the host is huge and heavy. Here's how it compares to some other flashlights.
Nice to see those two side by side. That is a BEAST!
Dx has the UniqueFire UF-2180 for$52.90 and UniqueFire UF-2170 for $53.10
I like to see competition
Both come with a charger and battery
Hi, Manny - welcome to BLF. No haven't seen that particular light or brand before, except in batteries. Do you have a link to a sales site that carries it?
Thanks for the welcome..... I have been some time on CPF.... I like budget lights .... I saw this one on ebay. They told me is a New 2012 model ......
The issue with the 3x light is usually a floating pill and poor heat sinking. Too bad they don't show a picture of the guts. I have a Uniquefire 3900 and that is exactly the problem with the light.
I have around $70.00 and was thinking of getting the SkyRay King or this, this will be my first 26650 light .......
I would go with the King - lot's of happy campers here with that light (unless you don't like gold ). If you want to go with the 26650 format, consider looking at the Sky Ray 856:
