Test/Review of Basen 18650 2100mAh BS186E (Black)
Official specifications:
  • Type: BS186E (High Drain)
  • Capacity: 2100mAh
  • Voltage: 3.7V
  • Style: Flat top
  • Protected: No
  • Max.discharge current: 30A
  • Weight: 48±1g
  • Size: Diameter:18.17mm; Length:64.98mm
This is a 18650 with a very high current rating.
The cells has good tracking and nearly constant capacity with any load. The Sony datasheet do rate this cell for 30A continuous discharge, but I would prefer to stay below 20A.
Conclusion
This is a very good cell with a lot of power.
Notes and links
The batteries was supplied by Basen for a review.
Compare to 18650 and other batteries
From a capacity standpoint it looks like it is a lot happier at 20 Amps and below. The discharge energy chart says it is happier at 10 amps it looks like. Then the steps widen. Of course they are bigger steps too.
