The Daily Riddle Thread
149 posts / 0 new
VFMaddict
Last seen: 1 year 9 months ago
Well that depends if they were both going to the same airport. London has three and all are different distances……… Silly But we’ll assume that if they ever do meet they are at the same airport………………..somewhere :bigsmile:
"You are making progress if each mistake you make is a new one."
Remember - Most great discoveries start with maki
Boaz
Boaz's picture
Last seen: 12 hours 23 min ago
Legolas Jr. wrote:
There are two planes. One is going from New York to London at a speed of 600 MPH. The other is traveling from London to New York at a speed of 500 MPH. When the planes meet which one will be closer to London?
 The one coming from London will be approx. 683 feet closer to London . Because meeting would be considered the two planes meeting nose to nose whereas the plane from londons tail is the length of the plane closer than the one heading from New York .
raccoon city
raccoon city's picture
Last seen: 4 min 42 sec ago
Nice!   8)
Legolas Jr.
Legolas Jr.'s picture
Last seen: 6 days 18 hours ago
Smart aleck! Wink
“Strive to be a warrior and a scholar. Be forged in fire and tempered by knowledge. If not, you will either lack the courage to fight for your ideals or lack ideals worth fighting for.”
Legolas Jr.
It’s hard to give up. Remove part of it and you still have a bit. Remove another part, but bit is still there. Remove another and it remains. What is it?
will34
will34's picture
Last seen: 5 hours 52 min ago
A LED dome?
Legolas Jr.
will34 wrote:
A LED dome?
:bigsmile:
Keep guessing…
DavidEF
DavidEF's picture
Last seen: 3 days 22 hours ago
habit
literally “a bit” if you remove the “h”
yep, “bit” is there when you remove the “a”
remove the “b” and “it” remains
Quote:
What is it?
Yes, the word “habit”.
- The YKK Philosophy
Legolas Jr.
Yep!
Legolas Jr.
There is a brick of gold and a brick of iron in a boat (both 10 inch blocks), if they are both dropped into the water which will make the water level higher?
sandanbob
Last seen: 1 month 6 days ago
Neither, as they are the same volume. If, however, they were the same weight, then we would have to take into consideration the density of each.
ChibiM
ChibiM's picture
Last seen: 2 days 15 hours ago
A plane with 168 passengers crashes on the border of 3 neighboring countries, country A,B and C. Half of them passed away. Half of them got burried in country A, the other half in Country B. Where did the other 84 people get burried?
sixty545
Last seen: 1 month 1 week ago
the last one dropped into the water!
DavidEF
DavidEF's picture
Wherever the family chooses to bury them after they finally pass away some day.
Boaz
Boaz's picture
The gold brick ....because me and 22 other people are jumping in after it
ChibiM
ChibiM's picture
smart guy
DavidEF
DavidEF's picture
It can split granite, yet a child can break it up easily.
You can’t breathe it, yet your lungs wouldn’t work without it.
It exists pretty much everywhere, yet people die for lack of it.
What is it?
sandanbob
Water. Smile
DavidEF
DavidEF's picture
sandanbob wrote:
Water. Smile
Well, I was actually thinking about Dihydrogen Monoxide, but I guess water will work too. Wink
sandanbob
Why, David, you are right! What was I thinking? Smile
I reread the iron and gold brick one, and the answer is:
both of them.
VFMaddict
A man is fishing from a boat on a lake. He hooks an old metal anchor. He hauls it aboard. Will the water level in the lake rise or fall?
sandanbob
I would say rise.
While in the water, the anchor takes up a certain volume, regardless of weight.
Once the anchor is brought into the boat, the boat will settle, displacing the amount of water equivalent to the weight of the anchor. Whereas the density of the anchor is greater than water, this displacement will be greater than that of the anchor itself.
However- would it actually be noticeable? Or, measurable? I would say probably not.
VFMaddict
Spot on.
Legolas Jr.
Take away my first letter, and I still sound the same. Take away my last letter, I still sound the same. Even take away my letter in the middle, I will still sound the same. I am a five letter word. What am I?
JohnnyMac
JohnnyMac's picture
Last seen: 1 week 6 days ago
Actually only the gold block will end up increasing the water level because the iron block will rust and dissolve into the water itself where the gold block will remain in it's original volume.
Legolas Jr.
A ladder hangs over the side of a ship anchored in a port. The bottom rung touches the water. The distance between rungs is 20 cm and the length of the ladder is 180 cm. The tide is rising at the rate of 15 cm each hour.
When will the water reach the seventh rung from the top?
DavidEF
DavidEF's picture
One hour and 20 minutes!
raccoon city
If I understand the situation, the answer is never.
Or at least until it starts raining.   Silly
Legolas Jr.
Raccoon City’s got it! The tide is rising, which means that since the ship is floating on the water, it will rise along with the tide, and the water will never go above that first rung. :bigsmile:
Legolas Jr.
How do you make the number one disappear?
