16mm Noctigons for MT-G2
18 posts / 0 new
Ouchyfoot
Ouchyfoot's picture
Last seen: 11 months 12 hours ago
Hanks got them. 16mm Noctigons for MT-G2. Mounted and unmounted.
http://intl-outdoor.com/index.php?main_page=products_new&zenid=9c9d2a688...
aoeu
aoeu's picture
Last seen: 2 weeks 1 day ago
What’s a good host for these? I figure it’s going to be in a 30second hand-burner application.
djozz
djozz's picture
Last seen: 3 hours 42 min ago
Cool! So what is the obvious mod to use this board/led with?
MRsDNF
MRsDNF's picture
We need DBC to answer this.
Itinifni
Itinifni's picture
Last seen: 2 days 1 hour ago
Mini-Mag mule, direct drive with two 14500 INRs.
I remember a time, when I searched for lights to fit my needs. Now I search for needs to fit my lights.
ChibiM
ChibiM's picture
Last seen: 7 hours 33 min ago
They should also make them bigger, not smaller.
I want one for my Ultrafire M51, which has a 32mm board.
I have a maxtoch mcpcb from banggood, but its 26mm and thinner than the original mcpcb.
The original one isn`t DTP...therefore want something bigger.
djozz
djozz's picture
...and today MT-G2 on new 25mm Noctigon, with 4 XQ-E pads, a wild board!
leaftye
Last seen: 1 year 1 month ago
Where do you get the XQ-E emitters and the driver(s) that can run a MT-G2 and those XQ-E?  Oh wait, Mouser has red, blue and green emitters.  I didn't see amber, red-orange or royal blue.  Then you'll probably need a light with two buttons and enough space for two floating drivers.
The low mode should be lower.
Hikelite
Last seen: 1 day 6 hours ago
Cutter has several XQ-E emitters, colors, warm whites, etc.
There are a couple of modders here making multiple color lights with one switch and one driver.
leaftye
Not like this.
6V MT-G2, 3V XQ-E.  Sure, you could get a driver that works in 6V, but is there a color 6V driver, and are you willing to run half the colors by running two of them in series to get down to 3V?
Hikelite
4 XQ-E in 2S2P configuration if you want all the same color, just an idea.  (like 850 lumens of green light)
Luxeon UV should fit the XQ-E pads, I think it should since they are almost identical, 4 of them blasting UV light.
djozz
djozz's picture
wow, 4x Luxeon UV, that will be a pricy flashlight Surprised
I guess any led with two pads will fit, indeed LuxeonZ, but Nichia 119 should work too.
Hikelite
XQ-E is 1.6 x 1.6mm and the Luxeon UV is a 1.7 x 1.3mm (but almost the same size pads so will match)
Nichia 119 is 3.5 x 3.5mm, huge LED compared to the XQ-E.
zeremefico
zeremefico's picture
Last seen: 9 hours 10 min ago
Any idea for update on mt-g2 bin?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
djozz
djozz's picture
I have reflowed oslon leds on XP-boards while oslon leds have a smaller footprint, it is all not that critical. With this simple double-pad footprint I'm sure you can get the 119 succesfully reflowed, even though the pads on the emitters are way bigger.
Cereal_killer
Cereal_killer's picture
Last seen: 2 years 1 month ago
Not like this.
Wouldn’t be hard to pick up GND for the color channels from between the cells, especially in a sidexside host like say a ZY-T08. Or use an SRK style light with 2p2s 18350 and 2p1s 18650.
I guess the race is on between tterev3 and I now.
Edit: in fact it’d eliminate the need to voltage protect (Zener mod) the MCU since it could run off the low voltage side. That’s it, I’m doing this. Who wants to bankroll?
Hikelite
Overlapped the pads, no doubt you can do it as you said, but I am not sure how useful is to fit 4.1 times bigger LED there. Took the size info from the datasheets. Luxeon Z is the same size and pads as Luxeon UV, turns out they will fit just fine on the same pads and be discreet as XQ-E are.
nofearek9
nofearek9's picture
anyone used the 25mm board with 4 XQ-Es ?
