Test/Review of AWT IMR18650 2000mAh (Yellow)
4 posts / 0 new
HKJ
HKJ's picture
Last seen: 23 hours 1 min ago
DSC_6507
Official specifications:
  • Rated Capacity: 2200mAh (0.5CA Discharge)
  • Rated Voltage: 3.7V
  • Internal Resistance: <100mOhm (with PTC)
  • Cut-off Discharge Voltage: 2.75V
  • Charge Upper Limit Voltage: 4.20±0.05V
  • Charging Time(Std): 4.0hours
  • Standard Charging Circuit: 0.2C A
  • Charging Circuit: 0.5C A
  • Standard Discharging Circuit: 0.2C A
  • Fast Discharging Current: 0.5C A
  • Max Discharging Current: 2C A
  • Weight: about 45.5g
  • Height: 65mm
  • Operational Temperature: charge (0 ~ 45°C), discharge (-20 ~ 60°C)
  • Storage Temperature: within 1 month (-20~ 50°C), within 3 months (-20~ 40°C)
AWT%20IMR18650%202000mAh%20(Yellow)-info
A high current 18650 battery. According to specifications I got from AWT the 30A are pulse rating and 15A is continuous rating.
DSC_6506
DSC_6508 DSC_6509
DSC_6510
DSC_6511
AWT%20IMR18650%202000mAh%20(Yellow)-Capacity
The batteries cannot deliver 30A. The batteries has about the same capacity, but there is a difference in internal resistance.
AWT%20IMR18650%202000mAh%20(Yellow)-CapacityTimeHours
AWT%20IMR18650%202000mAh%20(Yellow)-Energy
AWT%20IMR18650%202000mAh%20(Yellow)-PowerLoadTime
AWT%20IMR18650%202000mAh%20(Yellow)-TripCurrent
AWT%20IMR18650%202000mAh%20(Yellow)-Charge
Conclusion
The battery can deliver a lot of current, but the difference in internal resistance means that it is a bad idea to use them in series especially at high current.
Notes and links
The batteries was supplied by AWT for a review.
Compare to 18650 and other batteries
Edited by: HKJ on 10/08/2014 - 12:04
ImA4Wheelr
Last seen: 4 months 1 week ago
Thank you HKJ.  More great info as always.
Typically, when you are able to run all the tests with minimal down time between runs, how long does all this testing and reporting of a cell usually take?
HKJ
HKJ's picture
I usual say a week for the two cells in a test, but the time varies, depending on cell capacity and how many currents I test. The fastest is probably 4 or 5 days and the slowest is probably 9 days (I do not really look at the time). The worst is 4.35 volt because I run 3 sets of test, i.e. 3 weeks.
Because the test is fairly automated the only regular downtime is when replacing cell. There is, of course, Windows! It crashes every few months and it may take a couple of days before I notice it and get the test restarted.
In addition to all the testing I need time to register and take photos of new batteries and some time to write the review. For the battery above I have probably used 2 to 3 hours of my time and as stated above about a week of automated testing.
Ledsmoke
Ledsmoke's picture
Last seen: 1 year 6 months ago
TY for the test. A shame about the batteries internal resistance being so different. Nice cells otherwise.
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
