hi
i have found this on aliexpress but it says Can not delivertoEgypt so what about you, and do you think it is fake cells ?
hi
They don't deliver to the United States either, and I'm not buying 10 of them. It's probably legit. I want to order some, but I have nothing to put them into.
To my findings, the big 32650's can't deliver the current rates of their smaller siblings. I've used them in D sized MagLights, but stepped down to 26650 or 26700's for more power. I have 3 MagLites running Li-ion in this category at present, 2 that are triple XM-L and one that is MT-G2.
Powerizer or King Kong cells are being utilized in my big MagLites at the moment.
Edit: Ok, technically I have 10 MagLites running Li-ion cells, but 3 that are D sized. One 3D is using NiMH "D" Imedions. And one is in a non working state, awaiting a plan. yes, I have 12 MagLites.
If you want really high power cells, just go with the KeepPower IMR26650 5200mAh unprotected cells from Illumination supply. Using them in my SuperNight 12x Cree (Same as LightMalls version) with a starting tail current of 10.45 amps on HIGH mode, they don’t seem to break a sweat.
They are listed as flat tops, but actually are raised, so they work perfectly in a series configuration.
Don’t forget that gamezawy is in Egypt.
It seems the only place they can deliver to is Russia.
Yes, but that could be other places technically too, after all, Putin seems to think quite a few places are Russia too
Look again: result at 10 Amps is 5797mAh. The unprotected TF32650’s are awesome and dont even break a sweat at 10A sustained discharge rates.
Trustfire TF32650 6000mAh test/review After removal of the crappy PC, compare the 10A curve (capacity and sustained voltage to any 26650, and they all lose). I have 12 of these that have been cycled @7A several times. Although they are less than a year old, they discharge evenly with the same ending voltage in 3S config and havent shown any signs of deterioration yet… which is usually not the case with any of the Chinese cells.
