Test/Review of USB meter: Online Test
Official specifications:
  • Cable Length: 16cm/6.3"
  • Body Size: 7.5 x 3.5 x 1.8cm/3" x 1.4" x 0.7"(L*W*T)
  • Main Color: White, Black
  • Materials: Plastic, Metal
  • Net Weight: 61g
I found this unit on Ebay at a dealer called sellerbible.
How does it look
This usb meter has a cable on the usb input.
A switch is used to select between voltage and current display.
In addition to the usb output, there is also a DC barrel connector for 5 volt input.
There is no markings on the device showing the DC connector is for 5 volt input.
There is no screws, I could just pry the bottom off. I was a bit surprised about the inside with two circuit boards and lots of wires.
Four screws later and the circuit board is out together with the display.
It looks like this device can be made in two version with different current resolution.
The black blob is the microprocessor, the raw chip is mounted directly on the circuit board.
The current sense resistor is a piece of wire.
Two quality trimpots to adjust current and voltage readings.
Measurements
  • The meter uses 1.1mA current
  • The display shows a voltage midway between input and output.
  • The current is within 0.05A (The reading gets slightly higher when the usb meter is warm).
  • Internal resistance is about 0.17ohm including connection resistance.
  • USB data works fine.
M1:36,8°C, M2:36,4°C, HS1: 42,1°C
Notice that the cable is warm, i.e. the resistance in the cable will loose some power.
M1: 39,4°C, HS1: 43,1°C
Conclusion
This usb meter works fairly well, but I would have liked some markings for the DC connector.
A acceptable device for people that want a manual V/A switch.
Notes
How do I make the test
Thanks for another great test!
That seller sure makes it hard to find. He didn't even bother using the name of the product. I finally found it titled as:
PC USB 2.0 Device Voltage Current Meter Tester w LCD Display Screen
What software did you use for the USB data? I'm hoping it's Logview.
Thanks for another awesome review :slight_smile:
? My table is manual work: Read the DMM's and type it into Excel.
Oh, I thought this "USB data works fine." meant it could be used for logging. That would have been awfully convenient.
Online = inline ?
USB data works fine means that the usb data bus works, i.e. it can also be used to measure stuff that needs a data connection.
Gotcha. Thanks for clarifying.
