Comparison: Budget LED Light Bulbs
50 posts / 0 new
texaspyro
Last seen: 1 year 11 months ago
lesliemorris85 wrote:
so how about those who already have lights from these manufacturers post theirs here and we also agree to some standards for the tests? Smile
http://budgetlightforum.com/node/9179
udit
udit's picture
Last seen: 6 years 12 months ago
Nice review, but i will go with led lights for their economical benefits.
MountainKing
I believe philips do make led lights?
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
Le_Zouave
Le_Zouave's picture
Last seen: 11 months 3 weeks ago
Ikea led, 400 lumens, 5€ (maybe 7$ in the us). Warm tint (claimed to be 2700K). Better build quality than budget led bulb. Even cheaper than brand fluorescent bulb and no warm-up delay.
udit
udit's picture
LEDs are almost 85% more efficient than these incandescent lights and about 5% more efficient than the CFL Lights.
dspiffy
Last seen: 7 years 2 weeks ago
The E27 spotlight you bought looks near identical to these I just received:
http://www.aliexpress.com/item/10X-Dimmable-Led-Lamp-E27-GU10-MR16-E14-G...
I love them! They’re very close in beam and brightness to a narrow flood PAR16, and actually cost less, despite being LED! I havent tried the dimmable version but I am going to. I know when I do, the choice of dimmer can make as much difference as the quality of the bulbs.
aoeu
aoeu's picture
Last seen: 4 months 4 days ago
I’ve bought a few of these to test http://www.banggood.com/Wholesale-GU10-6_4W-16-SMD-5630-LED-Warm-White-Energy-Saving-Spot-Light-Lamp-Bulb-85-265V-p-50082.html
But I’ve just watched a vid a similar bulb where the guy explains how dangerous these bulbs are. I don’t understand exactly why but it was something like this bulb not being earthed so there was a 50% chance the heatsink housing could become live if inserted the wrong way. He said the LED area was an aluminum plate which was live, and it was separated from the housing by only a few microns. This sounds really dangerous.
Would this be the same for the globes I purchased which look identical? Should I just throw them out? The BG rating seems to be quite high and customers are happy with their light output.
dspiffy
The “couple of microns of insulation” is all circuit boards . . . I wouldnt worry about that. The aluminum plate itself isnt live.
The exposed electronics at the bottom, that I dont care for. It would be easy to coat the “input” solder joints with some insulating material. Even clear nail polish would make a difference.
I wouldnt sell them to customers unless they knew what they were getting.
dspiffy
The points that are circled. There is a small chance it you touch one of them you could get a shock. It depends on how the bulb is installed, and if they are grounded. Pretty unlikely, but still surprising.
keltex78
keltex78's picture
Last seen: 1 year 2 weeks ago
Those points are low-voltage DC. If you were to stick needles into your heart, then short them directly across to those connectors, I could see that you might have a bad day, but your body's resistance is so high, and the power on these bulbs is so low, that it is safe. Think touching both contacts on a 9V battery. Or even a 12V car battery...
A static shock from shuffling on carpet is thousands of volts and is just an "Ouch"...
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
dspiffy
keltex78 wrote:
Those points are low-voltage DC. If you were to stick needles into your heart, then short them directly across to those connectors, I could see that you might have a bad day, but your body’s resistance is so high, and the power on these bulbs is so low, that it is safe. Think touching both contacts on a 9V battery. Or even a 12V car battery…
A static shock from shuffling on carpet is thousands of volts and is just an “Ouch”…
According to the video the OP is referring to, the way the power supply is configured, neutral goes straight through to the emitter board, and is not isolated by a transformer. Therefore if the polarity in the bulb is reversed, 120vAC will go straight through.
All of the LED bulbs I have taken apart have a transformer in the power supply so this would not be an issue.
risky_hir
risky_hir's picture
Last seen: 6 years 4 months ago
need help. i want to buy a best quality bulb for bathrooms of all my home. I have searched for best quality in terms of lumens per watt, cri, power factor, warranty as well as led life.
what is your expert advice on this product: http://www.snapdeal.com/product/charlston-lights-white-glowup-5w/6678088...
please suggest…
risky_hir
risky_hir's picture
This will be helpful to general customer to find out best quality led light.
risky_hir
risky_hir's picture
no dude you are not right.. technology is gearing up nowaday. LED manufacturers are giving brightest led chip day by day. just you have to keep in touch with latest specification. I found charlston and philips brands in india with the best quality product. Charlston is however small company but very competitive price with quality too.
jcs0001
Last seen: 1 year 3 weeks ago
I bought a few of the “ebay specials” led 120 volt bulbs several years ago with varying degrees of success. 6 out of 8 or so are still working well. At that time a philips 10 watt (or so) yellow bulb (looked like a bugs eye) was about $30 Cad. I recently bought some of the newer philips flat white bulbs and they are below $10 Cad. The price on the ebay bulbs went up after I bought them and I’d no longer consider them since the philips are almost in the affordable range.
I still have a bunch of cfl’s working – they refuse to die – so with these and spares I won’t need more led’s for some time.
John.
topgreenlighting
Last seen: 6 years 3 weeks ago
Thank you for sharing Smile
Professional Green LED Lighting Solution Supplier | www.topgreenlighting.com
Lennart
Lennart's picture
djozz wrote:
This thread is all about very cheap led-bulbs, just thought it was fair to join in with an experience with a quite expensive one, I bought it half a year ago for I think it was 30 dollars at the time, a GU10 reflector bulb replacement:
Two years later and Ikea is getting close, 6W and 400 lumen. Useful spot, I hope. Will buy and try. http://www.ikea.com/nl/nl/catalog/products/30304651/
Lennart
SawMaster
Last seen: 1 year 8 months ago
On today’s work site I used a couple of the Utilitech 60W equivalent LED bulbs and they seemed to be just about right up there with incandescent on color, diffusion, and lumens. And much cooler when I took one out this evening; I would have had to let an Incan cool down but you could handle this one easily, even on the heat-sinked area. I didn’t touch the metal but I probably could have. These have definitely come of age now and are still improving as can be seen in this thread.
LED home lighting is no longer the wave of the future, it is NOW!
Phil
angerdan
angerdan's picture
Last seen: 1 day 21 hours ago
That’s more accurate for 2016:
