Test/Review of AWT IMR16340 550mAh (Yellow)
Official specifications:
  • Rated Capacity: 550mAh (0.5CA Discharge)
  • Rated Voltage: 3.7V
  • Internal Resistance: <100mOhm (with PTC)
  • Cut-off Discharge Voltage: 2.75V
  • Charge Upper Limit Voltage: 4.20±0.05V
  • Charging Time(Std): 4.0hours
  • Standard Charging Circuit: 0.2C A
  • Charging Circuit: 0.5C A
  • Standard Discharging Circuit: 0.2C A
  • Fast Discharging Current: 0.5C A
  • Max Discharging Current: 2C A
  • Weight: about 30G
  • Height: 34.05mm
  • Operational Temperature: charge (0 ~ 45°C), discharge (-20 ~ 60°C)
  • Storage Temperature: within 1 month (-20~ 50°C), within 3 months (-20~ 40°C), within 3 months (-20~ 20°C)
This is a high current 16340 cell (i.e. cr123 sizes cell).
Fairly good tracking and constant capacity up to 3A
Conclusion
This battery has very good performance, but the current printed on the cell is rather optimistic.
As usual I will rate it as acceptable.
Notes and links
The batteries was supplied by AWT for a review.
Comparison to other LiIon batteries
That is a very descent battery, thanks for testing. If the availability and price will be as good as the Efest IMR or AW, I will get some for my small lights.
