Test/Review of Basen 18650 3000mAh BS186C (Black)
Official specifications:
  • Type: BS186C
  • Capacity: 3000mAh
  • Voltage: 3.7V
  • Style: Flat top
  • Protected: No
  • Charging current: Maximum 2A (1A current recommended)
  • Weight: 47±1g
  • Size: Diameter:18.22mm; Length:65.08mm
4.35 volt
This battery is a 4.35 volt battery, even though Basen does not specify it.
Very nice discharge curves up to 7A with perfect match and same capacity.
4.30 volt
Reducing the charge voltage to 4.30 volt looses about 130mAh.
4.20 volt
At 4.20 volt the battery has about 330mAh less than at 4.35 volt.
Conclusion
The performance is good on this battery and as usual a 4.35 volt battery gives some extra voltage during discharge.
Notes and links
The batteries was supplied by Basen for a review.
Compare to 18650 and other batteries
Nice review…thanks!
