I’m impressed with how long the Rofis MR50 can maintain it’s highest brightness setting. After the initial stepdown, it maintained a constant brightness for 3 hours, and it didn’t get too hot either. The boost driver appears very efficient.
Good usb/rechargeable console light.
No need for clip
I bit the gold.
Thx
Edit: Purchased before I noticed the ‘battery’ is usb…… not the actual light.
Never seen that before. Still a decent deal.
And apparently ugly green tint, based on the reviews there.
Just got mine and it does have a pretty greenish tint. But for $13 shipped and with a 1450 battery included I can live with the tint. Especially since it’s going into my car’s glove box so I’ll probably never see it
It’s a really nice light! One oddity is that the included 21700 cell is significantly larger than any other 21700 battery I have; it won’t even fit into any of my chargers or 21700 lights.
No need for clip
I bit the gold.
Thx
Plus if you get the gold one, the tint isn’t the ugliest thing about its color
I concur. Great light.
I’m amazed these sometimes go for around $20 on Amazon. They look and feel like $70 lights.
Yeah the included 21700 is quite large but fits in my Vapcell S4 charger. Surprisingly the much smaller LG M50 21700 battery works just fine with the MR50.
I received the Wuben C5 the other day. Some thoughts:
- It’s exactly as slippery as it looks, which is “very.”
- The UI is ok. I’d rather have double-click from off be turbo instead of strobe. Not memorizing moonlight when accessed via a hold from off is nice though.
- Good mode spacing.
- The tint is horrendous, unless you like a green hotspot with purple spill.
The LED on mine was quite a bit off-center. It didn’t bother me too much because the tint was so bad I knew I’d never use the light anyway. I began trying to remove the bezel for an emitter swap. A heat gun plus grippy rubber gloves wasn’t working. I got fed up and used two pliers. The gouges give the light some much-needed grip. They used lots of threadlocker
My iron had trouble melting their solder. I think the centering issue was due to the weird bowl-shaped gasket they used. I guess as a plus it prevents electrical shorts on the underside of the reflector – something I’ve been having trouble with lately. A 16mm MCPCB requires no modification.
With a 219b 3500k the light is much better. I can see LED petals and slight off-centering if I look for it. I think I’ll add some diffusion film and it will be perfect.
I feel it was a good deal at $10 (plus $5 and lots of aggravation for a new emitter). I see it’s at $26 now. I think there are much better options at that price point, especially if you are even somewhat of a tint snob like me.
Here’s a good deal on a AAA Wuben light. 50% off with coupon puts it around $10.50 and comes with a battery.
I got a coupla those, but be forewarned.
First, it’s got a CW G3, so… enough said.
Second, if I’m remembering right, this is the one that’s all too quick to jump to epilepsy mode if you try changing modes the slightest bit too quickly.
I literally couldn’t give ‘em away.
I normally like Wubens for awesome hardware, but retarded UIs. The exception being the TO46R which I loooooooooove.
The red/black packaging has changeed . No idea what else has changed my E01 is from 2019. It has 3 mode (Low: 1lm / Medium: 20lm / High: 100lm) with hidden SOS mode. In this case it’s a slow flash barely distinguishable from change modes. It starts in lowest mode and resets to lowest mode after about 10 seconds. XP-G3 is notoriously bad looking but what can you do? Emitter swap is as straight forward as with other AAA lights.
I prefer the UI of E01 (L/ M /H ) over the asinine UI of Lumintop AAA (M / L / H )
“ Quality Quester” on amazon gives a pretty good rundown of this light. On a particular note is the lack of LVP these have. It’s a vampire light. It will keep depleting the battery past 0.9v. Not good for NIHM though.
Bluetooth headphones for $12.13
https://www.myvipon.com/product/9175826-BERIBES-Headphones-Wireless-55H-Weigh-Only-amazon-coupons
https://www.amazon.com/dp/B09LYF2ST7
These have good, but limited, customer feedback.
How to Post Images on BLF // Many knives for sale (USA only)
How to move a thread
Niwalker ET mini v1 $19.49 for the black version with an 18350 included.
https://www.amazon.com/gp/product/B097K8VLYB/ref=ppx_yo_dt_b_asin_title_...
I don’t like the way it compresses the springs so much —- I might be converting this cell to unprotected
Flashlight Plasma Lighter 2 in 1 Combo [2Pack]
$29.98 with prime
https://www.amazon.com/Emergency-Tactical-Flashlight-Rechargeable-Resist...
[quote=Bwana]Flashlight Plasma Lighter 2 in 1 Combo [2Pack]
So a plasma lighter gets its 'fuel' from the battery?
EDC
Aurora Clone S11 || S21A, w/Mtn17DD Zener Guppydrv, TIR, XHP-50 || SC31 Pro, SST40 6500K
Recent/ongoing Mods:
S2+, TexAven 17mm, LH351D | L2, Crescendo Mtn20mm, SST40 6500K | C8+ OP, DD XHP-50
SP32A w/SST40 5000K | TIR Upgrades | EagleTac clip | Ultrafire C2 w/6A 20mm & LH351D | S2+, Biscotti, Nichia 219C 2700K
Reviews:
Sofirn SP31 v2.0 Tactical Flashlight (Cree XPL HI) || Sofirn SD05 Scuba Diving Flashlight || Sofirn SC31 USB Rechargeable (XP-G3) || Sofirn SC31 Pro 5000K
Yes. All of these various plasma lighters on Amazon are battery powered.
There is 18650 tubes (plus clip) sold at their store for $9.99.
http://www.niwalkerstore.com/index.php?route=product/product&product_id=94
Seems like a decent UI, at least it has shortcuts to firefly and turbo.
It’s funny over the years I’ve bought seral of the double head type lights — after the initial novelty wears off , they usually never get used
Thank you. Grabbed one just for it’s quirky looks. Haven’t bought a new light in a while. For $20, what the hell.
"Everywhere I go, there I am"
https://www.amazon.com/Cold-Steel-Folding-Tri-Ad-Handle/dp/B0851QHMJZ
Cold steel 4 max scout. aus10A version. about as cheap as i’ve seen it at 65 dollars
Here’s a good deal on a AAA Wuben light. 50% off with coupon puts it around $10.50 and comes with a battery. No 10440 though I don’t believe.
https://www.amazon.com/WUBEN-Keychain-Flashlight-Waterproof-Emergency/dp...That does look like a good deal!
It only comes in cool white, which I'm not too fond of, but at least it has a tail switch, something I like.
XP-G3
EDC
Reviews:
This guy is still at $16.oo with the coupon Wuben T2. I have this light and like it a lot. It stays in my car and feels bullet proof.
https://www.amazon.com/WUBEN-T2-Flashlight-Flashlights-Waterproof/dp/B09...
Peetpen 70% off. $9.19 I have this one too. Cool little light.
https://www.amazon.com/PEETPEN-Flashlight-Rechargeable-Resistant-Flashli...
Rovyvon clone for $13.60 or so
https://www.amazon.com/ZIXEAR-Flashlights-Rechargeable-Super-waterproof-...
COB and Spotlight headlamp 80% off. Comes to $4 or so
https://www.amazon.com/Rechargeable-Headlight-Waterproof-Headlamps-Flash...
Have not used the E01, but if built as well as the E05, I would say that is a great deal.
EDC rotation:
KR4, SST-20 FA3 4000k (favorite!)
FW3A, Nichia 4000k sw40 r9080 (second favorite)
FW1A, LH351D 3500k (third favorite)
FW1A, XP-L Hi 3A
FW3A, LH351D 3500k
FW3A, SST20 FD2 4000k
FW3A, Cree XP-L Hi 5A3
Emisar D4V2, SST20 4000k
Emisar D4V2, brass E21A 3500k (night light of choice)
I have the E6 on me today. Such an impressive light. I have the T2 as well. So far, I have confidence in their build quality for sure.
Headlamp shows as $19.99 is there a coupons code ?
Skywolfeye two pack with batts and chargers. Not a big discount but $20
Wuben E01 review (picture heavy!)
Apparently there was a limit on the discount. I heard from a few guys that it ran out shortly after I posted it
80% off headlamp coupon was available this morning.
Banana****
