Test/Review of USB meter: Online Test
Official specifications:
  • White OLED display
  • Input voltage: 3V-10V (precision 1%)
  • Voltage Resolution: 0.01V
  • Test current: 0.A-3.3A
  • Current Resolution: 0.01A (precision 0.4%)
  • Capacity range :0-19999mAH
  • Accuracy: ± 1%
  • Test content: Capacity power Current Voltage
  • Sampling resistance :50mOhm
I found this unit on Ebay at a dealer called hylbuy
How does it look
The small display is a graphic OLED display.
Because the two circuit boards are soldered together it is a bit difficult to see the electronic.
Here is a look between the two circuit boards. There is a small button on the bottom circuit board, it is used to flip the display around.
Everything is shown at once
Measurements
The watt display is not U*I, but slightly above, this may be due to rounding. Also be aware that the voltage is somewhere between Vin and Vout, i.e. the power is neither input or output power, but something in-between.
  • Switch will turn display up/down.
  • Own current consumption is 7.3mA
  • USB data works fine.
  • Capacity display are zeroed when power is disconnected.
  • Internal resistance is about 0.12ohm including connection resistance.
  • Voltage display is within 0.03 volt in the 3.5 to 6.0 volt range.
  • Current display is within 0.06 ampere in the 0 to 3.0 ampere range and better at lower current.
  • Text on display is small, numbers are maybe 2mm high.
M1: 38,5°C, M2: 47,0°C, HS1: 57,7°C
The bottom circuit board gets fairly warm when running at 3A.
Conclusion
Fairly low resistance, good precision, works from 3.5 volt for voltage, but more than 4 volt for current, capacity and power display, but the display is fairly small.
This is a good usb meter when measuring at 5 volt, but I would have like it in a box, not as a loose circuit board.
Notes
How do I make the test
Interesting. Yep, it needs to be in a box.
Nice little USB Doctor!
Thanks!
Do you think a strip of clear 18650 heat shrink tubing would fit and be beneficial?
Just stumbled across this too…his is more or less a review, yours is a very good in depth test
Yes, if it does not press the button when shrinked.
He basically shows that the product exist, I prefer some more information in reviews.
Bought identical USB meter on ebay, never received it :frowning:
http://www.ebay.com/itm/171425534698?\_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
