17mm & 20/26/27mm single-sided DD/FET driver release: A17DD-SO8 / A20DD-SO8 / etc
731 posts / 0 new
pilotdog68
pilotdog68's picture
Last seen: 3 weeks 1 day ago
90% chance your meter is the problem
Smiglo
Last seen: 4 years 5 months ago
I measured using 0.1ohm 2w 5% resistor, I only get 300-350mV
Tom E
Tom E's picture
Last seen: 7 hours 18 min ago
Those batteries are certainly far from the best to use for max amps - Samsung 30Q flat top is great, maybe the SONY VTC6 the best, but they are pricey. Also depends on other things: thickness/length of LED wires, if springs have been bypassed or not.
Smiglo
Now with spring bypass I have max 4A with Keeppower 18650 3500mAh. About 0.5-0.6A increase.
RMM
RMM's picture
0.35v is a ton of drop.  You can easily lose 1A+ from that much drop.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
degarb
Last seen: 7 months 14 hours ago
RMM wrote:
degarb wrote:
Okay. . I would like one without the fet or anything above 380 ma. . The settings need be 100% of one amc7135 (not 2 or more) , 75%,50%,25%,10%,5% pwm based on max 380ma. Is this possible? . Or how much is possible? Most drivers are wow factor designed, and such are lacking for usefulness and efficient 10 plus hour runtime from a single 18650.
Why not just use an ak-47-a and remove some chips?  Cheaper and easier.
Looking at this ak47 at mtnelectronics.com . . Close to my desired 100/75/50/25/10 levels. . Never having this driver, I don’t understand which option to choose that would get me close to these single amc7135 levels. . Memory of course, remove two amc7135 naturally. Start in low, if no memory. Probably 7, but is that custom or is custom where I can choose my levels?
Runtime=Usefulness
degarb
RMM wrote:
Tom, degarb is an oddity.  He has e-mailed me several times and he has no interest in anything more than the power stated, period.
Yes, i run a service sector business. . On one hand, both my workers and myself regularly accidentally use the high modes. . This can strand my workers or myself for hours without ideal inspection work lights. . During the sales phase wow factor can come in handy, also my huge Fenix 35 for final brief inspection. . However it is not 2012 anymore and people aren’t wowed anymore. . Runtime is always their first question, and if not full day, they loose interest. . Moreover, you should be able to do more with less power as the years creep. . Not more wow, as the years creep.
So, if the wow (non workday) levels were locked or hard to get to…. It is 8th grade math that one battery swap a day, cost a company 1000 to 2000 use a year.
Yes, the ak47 looking better, as a cheap faster alternative to 555 on vdd. . Though at this 5 minute point unsure how customizing works…. It is easy enough to add a second switch for a second amc7135. . I really don’t like the efficiency droop over 700ma. 700 is super bright with right v6 setup and smallest runtime. . I can always wear a strap on wristlight to double my hl output.
Even biking with my buckpuck 700 ma 2 watt 2×18650 xpl light at highest speed downhill I couldn’t out run my lighting by a 5th. Keeping from inhaling the bugs was my biggest issue.
Runtime=Usefulness
maryzhu
Last seen: 4 years 2 months ago
Such heated topic,many people come to the heated topic…Now I am joining.
An optimistic person with smile on my face when meeting difficulties not only in my daily lives but on work. I have always done a good job on work. Very excellent.I want to be a happy person with no worries.
Mike C
Mike C's picture
Last seen: 15 hours 9 min ago
Yeah, really heated indeed. No one has written anything for almost three months. Incoming spam alert.
maryzhu
However,I did not get the hotpoint of the topic.What is mainly about ?
