17mm & 20/26/27mm single-sided DD/FET driver release: A17DD-SO8 / A20DD-SO8 / etc
731 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 1 day 9 hours ago
Trying to follow the logic on how the top of that cell heated up so fast, I think I might be on to something.
I’ve got a spring on the driver, with a 22 Ga wire inside to carry current, right? So this ends up making a point of contact at the cell that is on the very small side. Okay for 6A, but with 15A… maybe not so much! With that much current flowing through a small space what does it do physically to the wire and spring? Heats em up! Immediately!
So I’m going to put a 5/16” diameter brass post on the driver this morning. Far more current carrying capacity and a major contact surface improvement, giving full contact to the top of the cell. That should solve the PTC shut down issue. I’ve already put a solid copper plate at the negative end, with a beefy spring and also wire bypassed…I’ll put a copper top on that spring for a larger flat surface as well. Wink
The Sony C5 is a flat top, it ran 54 seconds on the light box without shutting down. The button top Efest shut down within 10 seconds. Smaller top plate, smaller contact surface. (granted, the spring with wire soldered in still gives a small surface contact either way) Could simply be that the Sony has higher quality components.
Does that sound right?
Thanks Scott, that copper sheet has been really coming in handy! Smile The really thick stuff not as much as the thinner, scissor cut capable sheet. But I’ve used the thicker stuff as well, albeit with some more work getting the piece desired. Wink
Edit: I might even see higher current with the blockages addressed! :bigsmile:
wight
Last seen: 1 year 4 months ago
It’s hard to say for certain, and I already mentioned some of this, but here goes:
  • HKJ managed to get full 30A discharges out of the ones he tested.
  • The PTC responds directly to temperature, not current.
  • I think it’s a temp issue, not a current issue.
  • The PTC on the Efest may simply be using different materials which change more aggressively with high temperatures.
  • I think a battery spacer which blocks the flow of heat from the pill to the battery is what you need. Maybe stainless or maybe delrin/whatever with a 12AWG solid copper wire hammered into the middle.
  • If problems persist then maybe your Efest batteries are mildly damaged? Although I thought a PTC was supposed to be tough, repeatable, and difficult to damage by it’s nature.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
DB Custom
DB Custom's picture
Ever hold a wire on cell while pulling high current through it? Current IS heat! You can’t have high current through a wire in a transition without some heat, the springs get hot that’s why bypassing their current handling makes it work.
HKJ didn’t test 30A on the cell installed. Big difference. I’m sure his connection wasn’t a pinpoint of solder by spring contact either.
Yes, high temperature causes the polymer to cease being electrically conductive. The design is to protect against a short circuit, high current-high heat-shutdown. After cooling the physical properties of the polymer switch are supposed to go back to normal and continue being electrically conductive again, according to experts that put together a paper from Cambridge, NASA and YALE.
At any rate, putting the solid brass contact in place of the spring was one too many times working on it. It’s DIW.
wight
I realize that a high-resistance path (such as a small contact point) generates heat. I’m a little frustrated that you find the need to mention all that again. OTOH I suppose it’s only fair since I was repeating myself as well.
It’s your light: if you’re happy with it on the Sony cell then there’s certainly no need to ‘fix’ the light’s behavior with the Efest cell.
DB Custom
DB Custom's picture
Working again, soldering on the brass post caused the diode to lose contact on one leg opposite the battery contact.
I mentioned it again for 2 reasons, one to be sure I was understanding it correctly and 2 this is an open conversation that others with as little understanding as myself can get it.
And besides, isn’t the actual pcb of the driver a FR G10 laminate? Doesn’t this separate the battery contact from the pill? Isn’t most of the heat brought through at the contact point itself, regardless of being surrounded by FR G10 or Delrin or whatever?
I don’t know these things, just going on reasoning and what little common sense I have left to me…
wight
All fair enough. I agree, it seems that most of the heat must be finding it’s way back through the positive contact… or the battery tube?
I’m not really certain what the best way to block the heat transfer is. A stainless steel spacer might be an OK option, assuming that the heat is coming through the positive terminal.
DB Custom
DB Custom's picture
I had it too tight with a beefy tail spring and the glass lens broke. Cutting a UCLp down to fit, then I’ll see what the Efest cell does on it with the brass contact.
Had to come in, cordless drill battery died and my backup wasn’t charged, go figure.
DB Custom
DB Custom's picture
Efest 35A runs 15.10A at start, fresh off the charger. It’s down to 14.10A at 36 seconds and the head of the light was uncomfortable to hold onto. Stuck the cell back in the charger, showing 4.06V.
Little power hungry beastie is what it is! The FET on this A17DD-S08 performs just fine, both it and the MCU now have a thermal pad on top of em.
I find it amazing that a single cell can run that kind of power. Crazy stuff. And I love it!
Thanks Wight for a job well done with this driver! This will be a staple for me now, the single sided layout is just so much easier to build and install.
Edit: might should mention that in all the rebuilding and messing with this light, 2 of the 4 XP-L’s have become de-domed…one was mysteriously so and the other had a loosened dome that I pulled off with my fingernail. Lucky that they oppose each other on the board so it looks ok.
Edit II: Cell recharged, 4416 lumens at start, 3743 at 30 seconds. Efest 35A works fine now.
wight
Thanks for the complements and for keeping us up to date. I’m glad that the Efest is playing nicely now. So do we think it turned out to be contact resistance after all? (eg the heat from high current across high contact resistance was tripping the PTC?)
DB Custom
DB Custom's picture
I addressed multiple issues by putting thermal pads on both the MCU and MOSFET, and also gave that larger contact point for the cell. The combination works, not sure if any one would have done it stand-alone.
This host is really a bad choice for this, as it has poor head-to-heat sink contact and no cooling fins at all. I’m thinking of using a mix of JBWeld and copper sanding dust to fill in around the copper heat sink in the head, there’s enough space for a 22ga Silicone coated wire to fit all the way around from about 1/4” up from the base of the heat sink…so a little more than 3/4” of the heat sink has no host contact. I really should have used a larger diameter copper bar to start with and totally filled the head, but I used what I had.
This design puts all the thermal path contact right down there at the driver, no contact anywhere else.
wight
@ DBCstm – I’ve been thinking of getting one of those PH-08. Maybe to build a triple in since I have no quad MPCB’s. I do have a lathe, so the pill isn’t the end of the world to me as long as there is a nice cylindrical area to interface with. Knowing that, would you recommend something else in the price bracket?
In the meantime:
I’ve created a new derivative driver from this project, eliminating the Zener in favor of an LDO with a much lower parasitic drain: http://budgetlightforum.com/node/36023
A17DD-SO8+LDO
DB Custom
DB Custom's picture
FastTech has this one for around $11, don’t know that they can be had much cheaper. This one is kind of an odd duck, but for some reason I like it. It’s not any bigger than it has to be, has some mass in the head albeit not a lot, the only thing I can think of as a true con is that…on mine…the tail threads are sorta weak. They’re not very deep and the tail cap is a bit oversized so it’s not a good solid threaded fit. Mine’s an older one though, so maybe they’ve gotten a little better.
I had a few Quad optics and boards and the 24mm size fit this one perfect, so I used it. It’d do good as a triple, there’d just be some space around the lens with the 20mm optics.
DB Custom
DB Custom's picture
My 7 yr old just decided the PH-08 is a heat lamp and started singing a song about it. Crazy kid…
I wrapped the copper heat sink with an appropriate ga bare copper solid wire and sealed it at the top (between the star and host) with Arctic Alumina Thermal Adhesive. The heat goes into the full head now, but while it does ok for the first 30 seconds or so by the time it’s hitting 50 seconds you can feel the heat (head only) really cranking up. At 55 seconds it’s about to leave burns on the hand. (Edit: I guess it’s safe to say that if it were turned on to the highest level and laid down, left alone, it would self destruct in a fairly quick manner)
Serious amount of light coming from a very small source. The 2 domed and 2 de-domed XP-L V6 2C gives a nice neutral/slightly warm tint and is nicer than I expected. Smile
The driver, with ToyKeepers ramping firmware, will make a bit of song at certain levels but it seems to be more during ramping than when sitting on a level. With 64 levels there’s a decent place to stop it pretty much whatever the need. Really like it, very useful light and easily maintained at decently high levels without getting crazy hot.
Edit II: Further testing (and some assistance from younger ears) proves out that the singing is done just below max level. Silent at max though. Then it quiets down toward medium levels and is silent on the lower levels.
wight
Heh, I have placed on in my cart at FT to “think about.”
ToyKeeper
ToyKeeper's picture
Last seen: 1 week 4 days ago
DBCstm wrote:
The driver, with ToyKeepers ramping firmware, will make a bit of song at certain levels … Further testing (and some assistance from younger ears) proves out that the singing is done just below max level. Silent at max though. Then it quiets down toward medium levels and is silent on the lower levels.
Did you build it with fast PWM or phase-correct? It’ll make sound with phase-correct, but shouldn’t be audible with fast PWM.
BTW, the Roche F6 is a nicer-quality host than the PH-08, and with Comfychair’s driver it also provides battery indicator lights. I really really like mine. I don’t think a quad would fit though; IIRC it’s a bit smaller.
Tom E
Tom E's picture
Last seen: 21 min 52 sec ago
Dale - on the PH-08, do you find the button is pretty stiff? Is it a hard rubber? I got two XP-11's from WallBuys that seem to be the same exact light with a hard rubber button cover. Weird brass pill that sort of fits snugly into the body with no threads? I know you replaced the pill though... After some usage and time with them, I prefer the Small Sun's of a comparable size with the e-switch, basically same cost, ZY-T11 or ZY-T29 with the alum reflector.
One of my XP-11's side switch had a short, couldn't see how to get the rubber cover off, so ended up ripping it. I repaired the short on the switch, but now it's switch is exposed - not too water resistant... Tried gluing the button back, seemed to work for a while but didn't hold up with usage.
DB Custom
DB Custom's picture
I used phase correct, knowing it might sing a little but I don’t mind. I wanted the 64 position ramp so went with the phase correct.
Yes, the button is pretty firm on this e-switch…I consider that a good thing because it won’t accidentally turn on very easy. I built a Small Sun ZY-T29 and was using these 2 side by side with single emitters. The build quality is probably a bit nicer on the Small Sun but for some reason I like this PH-08 quite a lot. Gave the Small Sun to my mom with a reversing UI.
If I was buying a light to do a mod like this I might would get the Small Sun ZY-T29, it just happened that I had this one sitting here when I was looking for something that would be a likely candidate for a quad that I could try wights driver out on. Smile And it also just so happened that I had a 3/4” bar of copper sitting here that I’d gotten months ago for a project I canned. AND it just so happened that the machined sleeved area that the PH-08’s brass pill slides into easily accepted that 3/4” bar with just a light touch from some sandpaper.
I get lucky far more often than I should, I know. Someone upstairs has my back, which is really good, because my front is very faulty…
wight
Thanks ToyKeeper, I’ll have to mull this over.
ToyKeeper
ToyKeeper's picture
I’m getting a PH-08 eventually for a project, so I should be able to post comparison pics then. However, shipping from China (and everywhere else) is now in crazy-holiday mode so it might be a long time before anything arrives. Comfychair’s thread on Roche F6 hacking provides lots and lots of details though, if you’re curious.
wight
I followed the thread pretty closely, although I didn’t participate at the time. I’d say that I do not find either flashlight particularly aesthetically pleasing, but it’s easy for me to assume that the Roche is built to a higher standard. $9 extra worth? I’m not sure about that. Also the PH-08 has the advantage of a separate button board.
NightSpy
NightSpy's picture
Last seen: 4 years 3 months ago
5 pages of posts and I am still looking for 2S performance Smile
I guess that with the zener removal, we’re back to 1S solution for this driver too.
Rufusbduck
Rufusbduck's picture
Last seen: 3 months 6 days ago
The regulator does the job of the Zener with less leakage current. So this is a 2s solution.
Scott
wight
Zener performance doesn’t need to be tested. Due to the high gate voltage (which is assured by the high Vcc provided by the Zener) the FET’s performance is already guaranteed. [In 1s applications we do not have a regulated gate voltage, so it’s possible to get a low enough gate voltage to put the FET into a less efficient state. This was never a concern for Zener builds.]
I don’t think I understand the second half of your post. Maybe RBD has answered your question? If you are under the impression that the LDO version is for 1s applications it’s because you haven’t clicked through and read the OP of the thread about it. |(
ChibiM
ChibiM's picture
Last seen: 16 min 28 sec ago
one thing that I notice in this thread, is that DBCstm talks a lot Big Smile
anyway.. does anyone wants to build these and sell them?
A17DD-SO8 that is
DB Custom
DB Custom's picture
Wight, do I understand correctly that the new design can be used normally for a single cell light without the LDO or as a 2 cell (like a zener but with the LDO instead) with the LDO?
Just making sure the driver works the same without the LDO, I’d like to do this but again my lack of knowledge leaves questions and uncertainties.
Down to 4 of the first version, need to order some of these and make sure I still have LDO’s from my Knucklehead experience. And which ones they are if I do…
ChibiM
ChibiM's picture
what I said
wight
No, not correct. I placed some strike-through where I quoted you for the benefit of those that skim. The LDO version requires the LDO. This thread is really still about the AxxDD-SO8 drivers which do not require an LDO (but are are Zener ready). v024 is the current version of the A17DD-SO8, here it is on OSH Park.
A17DD-SO8 that is
Wink RMM asked about selling them, I think he’ll be doing that fairly soon.
DB Custom
DB Custom's picture
It’s now known all the way to Japan that I talk too much! Silly
And to think, I was about to put together one or two of these for my friends in Japan, pity…
I have the Ver 024 built and installed in an X6 Triple, waiting on emitters…
djozz
djozz's picture
Last seen: 4 min 48 sec ago
I am willing to make me these boards, I have the components but not the FET. And Mouser and Digikey are too expensive. I found these on Ebay, will they do the job? :
http://www.ebay.com/itm/PSMN9R0-30YL-NXP-MOSFET-N-CH-30V-61A-LFPAK-10PCS...
wight
http://www.ebay.com/itm/PSMN9R0-30YL-NXP-MOSFET-N-CH-30V-61A-LFPAK-10PCS-LOT-/281514838554?pt=LH_DefaultDomain_0&hash=item418b978a1a
I think it’s probably OK for most single cell single emitter applications, but none of the specs are really that good compared to the one I specified in the OP. I think that besides being targeted at a different application this is probably an older FET (based on the use of LFPAK instead of LFPAK56?). PM sent.
EDIT: Changed my mind and added strike-through. Rds(on) is just not looking good here, and nothing else is that good either. It might work acceptably or it might not. It’s definitely not a good choice.
