17mm & 20/26/27mm single-sided DD/FET driver release: A17DD-SO8 / A20DD-SO8 / etc
731 posts / 0 new
ToyKeeper
ToyKeeper's picture
Last seen: 1 day 21 hours ago
BTW, on that note… if you have suggestions for LVP values to use on various drivers, I’d like to include those as presets in the firmware.
I’m hoping for the attiny13 internal voltage value for 4.2V, 3.9V, 3.6V, 3.3V, and 3.0V. It’s a pain for me to calibrate voltages since I don’t have an adjustable power supply.
Tom E
Tom E's picture
Last seen: 7 min 7 sec ago
I tried 124 (low) and 115 (critical) last night and they are better, but just not sure of my bench power supply setup or measurements. Sometimes the supply seems to be close to the DMM, sometimes not. Bottom line is I have no clue how accurate the reading is and not sure if reading the voltage drop across the LED is an accurate way to determine the equivalent of a battery's output.  I know there are voltage drops typically - I've seen other posts about that. I thought the 124 was close to 3.0v, but really not sure - not confident with my setup and readings... This is why I'm asking for other input.
Rufusbduck
Rufusbduck's picture
Last seen: 3 weeks 3 days ago
Led Vf is most but not all of the voltage drop. Most of the rest is across the driver so to get a more accurate reading go from led+ to ground. I would think it safest to measure voltage on low and compare that to resting cell voltage adjusting from there.
Scott
Tom E
Tom E's picture
Thanx Scott - I'll check that way - LED+ to ground. I was using high mode but at lower amps of 0.5 to 1.5A or so -- No PWM's. Hhmm, maybe that's way my readings were all over the place because I tested at different amp levels.
ToyKeeper
ToyKeeper's picture
Thanks to the Ferrero Rocher driver, I’ve gotten to watch attiny voltage measurements in real time during load… and it can vary pretty dramatically depending on how big the load is.
For this reason, I try to calibrate for a really low output level, to get it close to resting voltage. However, finding the precise value to use is difficult with only a battery as the power source, since it only crosses that threshold briefly and it must be charged to get back to that level… also takes a while to charge or discharge to the level I’m trying to calibrate.
Oh, and the values vary by like 5% per individual driver anyway, kind of like how the clock speed varies per attiny chip and the lumen output varies per emitter even within a single bin.
I’m hoping to get more than just the low/crit values though, since I want to include a battery check mode in as many lights as possible. For that, it at least needs the 4.2V value and 3.0V value, and preferably more. (just adding 3.6V is usually enough; the others tend to follow in a nearly linear curve)
Tom E
Tom E's picture
I was using the 12 step battery check mode from the original luxdrv, but find it too annoying. Maybe reduced to 6 blinks for 0.2v deltas would be a lot better. I would like to integrate in in my main e-switch UI, but wasn't sure how. If I don't use strobe, it could replace strobe with the extra long press, but was hoping to add it in. Maybe a extra long press while in moon mode or low? Something like that... Trying to avoid using dbl clicks - hate to lose fast single click capability...
ImA4Wheelr
Last seen: 2 months 3 days ago
Received the 26mm boards today.  Package is heavier than I expected for 3 boards.  Looking forward to using them. Smile
bugsy36
bugsy36's picture
Holy cow! Just installed one of the two of these that Dale built for me in an S2 XPL triple. EASIEST installation ever. Works fantastic!! Thank you Dale!!!!!!
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
DB Custom
DB Custom's picture
Last seen: 1 min 9 sec ago
Potent lil buggers aren’t they? Smile
ToyKeeper
ToyKeeper's picture
Tom E wrote:
I was using the 12 step battery check mode from the original luxdrv, but find it too annoying. Maybe reduced to 6 blinks for 0.2v deltas would be a lot better. I would like to integrate in in my main e-switch UI, but wasn’t sure how. If I don’t use strobe, it could replace strobe with the extra long press, but was hoping to add it in. Maybe a extra long press while in moon mode or low? Something like that… Trying to avoid using dbl clicks – hate to lose fast single click capability…
I’ve found it fairly effective to use a 25% or 0.3V blink system… 0 blinks means < 3.0V, 1 blink is 3.0V to 3.3V, 2 blinks is 3.3V to 3.6V, 3 blinks is 3.6V to 3.9V, 4 blinks is 3.9V to 4.2V, and 5 blinks is > 4.2V.
In theory, this means each blink represents one quarter of a full charge, but in practice it’s usually best to recharge the battery somewhere around the 1 or 2 blink range (and some high-amp cells are practically empty at 3.5V anyway so the “25% to 50%” estimate isn’t very close on those cells).
I’m not looking for a precise measurement though… I just want a rough idea, and to know if the battery is ready for a recharge without having to remove it from the light and use a DMM.
cajampa
Last seen: 4 years 10 months ago
Hi ToyKeeper & Tom,
I have to say this feature sounds very useful to me, i am rather new at this but i found myself rather quickly in the habit of opening the flashlight to test the battery on my DMM to see if i should recharge or not.
So something like this would save a lot of thread wear and a lot of time.
And because i plan to gift a lot nice flashlights in the future :-), it is a lot easier to explain to someone “press one long press at low and count” to know when to recharge, so there lithiums can last a long time and be safer as well.
I think the first time i heard of it (remember i am new at this) was the MELD drivers by tterev3 and those require an e-switch and a lot of other hardware and customization thats just to advanced for me yet.
wight
Moved!http://budgetlightforum.com/node/36228
I did some videos this evening.
How to strip a Nanjg-105D for parts with a soldering iron:
How to assemble an A17DD-SO8 with a soldering iron:
Here is the equipment list I used:
Hakko FX-888 w/ T18-D16 chisel tip
a wet sponge (hence the sizzle noises from offscreen in the video)
Kester 951 liquid flux in a syringe
3mm Goot Wick (CP-3015 via this listing?)
Radio Shack .032” 60/40 Rosin Core solder
WeiTus No. 10 stainless tweezers (130mm x 13mm) from IOS/MTN < these are my favorite tweezers.
black stainless tweezers.. maybe ESD13 or ESD14 from this VETUS set.
Really you don’t need all that stuff, but as you can see sometimes it makes things easier. I’d start with a cheap iron w/ a 2mm chisel tip or similar, 60/40 solder, and stainless tweezers. Anything else is gravy!
As far as techniques, mine are not always good.
Basic soldering advice: All of these components are pretty heat tolerant, but if you find yourself unable to make something happen, take a break from doing that thing. Eventually you can burn components by rubbing the iron on them long enough! I made some mistakes with the OTC at the end and really dumped a lot of heat into it. Ideally I would have given up for a while, then come back to it. I’d have removed it, cleaned up the area, and then soldered it in place again.
EDIT: It never really make sense to put this here. It just happened to be related because I was building an A17DD-SO8, so I plunked it down here. I turned the post into a new thread instead: http://budgetlightforum.com/node/36228
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
M4D M4X
M4D M4X's picture
Last seen: 6 days 9 hours ago
nice videos!
you are not very “shaky” Wink
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
wight
Thanks! Sometimes I am more shaky than others, but even with shaking it comes down to technique. IMO shaking can be dealt with pretty well when soldering boards like this.
ToyKeeper
ToyKeeper's picture
I have a battery check mode already built in to an on-time clicky firmware, an off-time clicky firmware, and an e-switch firmware. However, both of the clicky firmwares are a bit complicated (I crammed in as many modes as I could fit).
The clicky ones go in a loop (read voltage, display it, pause, repeat) while the e-switch one simply displays the voltage once and shuts itself off. Since the reading can vary from measurement to measurement, it’s usually a good idea to watch it for a few cycles to get a more accurate idea what the actual value is.
Unfortunately the hardcoded voltage values generally need tweaking for each style of driver, which complicates things. I’m hoping to include some reference values for common drivers to make this easier.
DB Custom
DB Custom's picture
Another A17DD-S08 in an Eagle Eye X6, this one powering a Quad XP-G2 S3 3C at 2340 lumens from a Panny BD. Home made heat sink that’s massive. Smile Gosh I love it when a plan comes together! :bigsmile:
MRsDNF
MRsDNF's picture
Last seen: 1 week 5 days ago
Very nice Dale. Thanks for the video.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 11 months 2 weeks ago
Whoah!
Now all you need to do is mod that for a quad XP-L and give it a go!
That’s a 20mm quad noctigon correct?
Measurement for that quad heatsink sir?
Awesome!
DB Custom
DB Custom's picture
Wights FET driver (A17DD-S08) pushes 4 XP-L’s ridiculously hard. Not so much hard on the emitters, but cell draining and heat producing. So I used the XP-G2’s here for some limitations. It’s still pulling over 10A, but the Quad XP-L’s off this driver pull closer to 15A.
I must be getting old, I’m starting to realize there are times that 100% pedal to the metal is not appropriate. Sometimes 98% is called for. Silly
nitro
nitro's picture
Last seen: 3 years 4 months ago
Ready to test mine,one on left needs lil solder removed but good to go i hope
Rufusbduck
One on the left looks backwards(mcu).
Scott
wight
You are correct. I couldn’t make out the markings when I looked at the picture earlier today, but the Pin1 notch clearly shows that it’s spun around!
nitro
nitro's picture
All fixed
RMM
RMM's picture
Dale, you've got to stop making us all jealous with those lights you're building!
Mountain Electronics : batteries, Noctigon, and much more! What's new?
Tom E
Tom E's picture
I'm "only" getting 5.85A absolute max at the tail with a A17DD-S08 in an X6 powering an old, good XM-L2 U2 1A on a Noctigon, using 20 AWG LED wires, bypassed springs. It's really hard to tell, but out of the 3 types of BLF 17's I used: v1.0 original BLF - Mattaus, the C_K v3.1 version, and the A17DD-08, the only one I could get over 6A out of was the BLF v1.0 originals. I did not compare these head to head -- all were in different lights/builds, so I can't be certain of anything, but really thought I'd get over 6A in the X6 with the 20 AWG wires, and the lock down retaining ring - seems to have a really good ground (batt -) path.
Multiple LED's is the easy case with low Vf's. The single LED setup is the worse case, but is the best real world way to test the resistance of the driver that I know of. I may have to build up a BLF 17 v1.0 just to see if it can do better. Why I need higher amps is not because of the domed XM-L2 U2 1A, but I'm getting a max of only 3.7A in the X6 (w/A17DD-S08, 20 AWG wires) with a de-domed XP-G2 S2. I have a Convoy C8 with a de-domed XP-G2 R5 that gets 3.95A at the tail on a 7135 based driver.
wight
I saw your post about the XP-G2 over in RMM’s thread. I’ve been assuming that you’ve simply got LEDs with a high Vf.
You don’t really have to put them head to head IMO (although that would be ideal). Instead just measure the Vf with your DMM. If you compare the two XP-G2 setups and find that the Vf is similar between the DD setup @ 3.7A and the linear driver at 3.95A… mystery solved.
Rufusbduck
After seeing all the smiley faces from Dale-mode mods I sort of assumed that the FET had become a non issue but if it turns out to be the case that the FET could be improved I would gladly pop for 10 of the more expensive ones to spread around for testing to see if there is justification for a GB for enough of them to bring down the cost plus shipping.
Scott
nitro
nitro's picture
im in for 5-10
DB Custom
DB Custom's picture
I’ve got 24 boards on the way and a few left on hand. Smile I, uh, seem to go through drivers a lot lately. hahaha
wight
Again, let’s not jump the gun. The datasheets clearly show the current FET in a good light, and as far as we know “better” alternatives are all more expensive. IMO the thing to do here is test with what we’ve got vs what we’re trying to meet/beat: the Vishay 70N02. An extra dollar or so per driver really is quite a lot. I’m not saying not to test the more expensive FETs at all, but step one is to see what we’ve got now!
