10440 rechargeable batteries plus charger for ITP A3 EOS - recommendations
39 posts / 0 new
centaurus3200
hi all,
first post here. i’m sure it’s been discussed before, but would the below link work well enough for an ITP A3 keychain light? are the 10440 batteries a drop in replacement for the ITP A3 flashlight?
yeah, i know the below link isn’t the best of the best as far as the batteries and charger, i just want to know if the setup will be serviceable for urban use (i’m not some psycho outdoors man).
i just want something that fits and works decently. what do “protected batteries” do? what’s their advantage? are the batteries in the below link decent enough? or what would you suggest for 10440 batteries WITH a charger (i want to buy both at once).
http://www.ebay.com/itm/4pcs-TrustFire-AAA-10440-PCB-Protected-600mAh-Rechargeable-Li-Battery-Charger-/161290445666?pt=US_Rechargeable_Batteries&hash=item258da8e362
as far as the safety of using 10440 batteries with the ITP A3, i doubt i’ll use more than the medium setting, but it’s nice to know i can rock 200 lumens for a few moments, if necessary. i do unfortunately have vision issues with one eye, and it has pretty crappy sensitivity to low light.
plus i’m getting sick of the ITP sucking AAA’s dry to where i only have enough power for the 96 lumen setting for like a week or two before the battery can’t muster the voltage for the highest setting anymore.
any suggestions would be greatly appreciated Smile
Regards,
Robby
centaurus3200
and if unprotected 10440 batteries prove to be too big of a hassle (like risking them catching fire in the charger), what’s the best AAA batteries/charger combination (meaning i just want to buy batteries and charger all at once).
do rechargeable AAA’s risk catching fire in the charger to? or just the 10440?
i’m just sick of the thing sucking enough life out of a fresh alkaline AAA to where the highest setting only works for like the first two weeks.
though a 10440 would be fun to just freak people out with so much light coming from a little keychain light Wink
Regards,
Robby
dw911
Last seen: 1 year 6 months ago
I wouldn’t waste my money on the ones in your link, for a start they won’t be 600mah batteries and you’ll be disappointed when they don’t perform well.
Also a cheap *****fire battery with a cheap protection circuit IMH option is more dangerous than an unprotected quality one, as it often leads to a false sense of security
I’d buy some efest 10440 cells, in fact I have
As for a charger do a search in the battery and charger section and see what’s been reviewed and recommend
Worth spending a few more £ on some quality batteries and a good charger for peace of mind
breinrules
breinrules's picture
Last seen: 3 years 7 months ago
if you can find them. led lenser has protected 10440 lcr battery and usb charger edit: check thickness first, they might not fit due to protection circuit strip in the side
zak.wilson
Last seen: 10 hours 19 min ago
Most commercial chargers won’t overcharge your 10440s. Jetbeam/Nitecore Intellichargers are pretty inexpensive and seem to work well. Protection circuits also usually prevent over-discharge and shorting. You can prevent over-discharge and shorting by paying attention to what you’re doing.
Any 10440 that claims more than 350 mAh is lying. The Efest IMR 10440 is one of the best on the market, but I think it only comes in flat-top and may not make contact in all flashlights. My local Interstate Batteries store stocks button-top 10440s for $2 each. They seem to be ok.
Running 10440s in that light should be fine. It may shorten the life of the LED some, but it will be decades before you notice. It may get hot; don’t leave it on high unless you’re holding it in your hand to absorb the heat and monitor the temperature.
Ceilingbounce – flashlight testing and runtime graphs for Android
centaurus3200
thanks for all the info!
so, feasibly i should get these things:
http://www.amazon.com/Nitecore-IntelliCharger-i4-Battery-Charger/dp/B005...
and 2 or 4 of these:
http://www.amazon.com/Efest-10440-350mAh-Rechargeable-Batteries/dp/B00HY...
as far as how long i leave them in the flashlight. when should i recharge them? can i just use the light “here and there” for like a month… mostly on medium setting. perhaps a few high bursts to freak out some friends?
how vigilant do i have to be about making sure to NOT let the batter get too weak before recharging?
i’m assuming good quality unprotected batteries like elfest plus the intellicharger should “shut down” if the batteries start to pull too much current… like they are gonna burst?
i’m assuming even rechargeable AAA batteries could burst too, right?
thanks,
Robby
centaurus3200
Anybody know if flat top 10440s will fit in an itp a3 eos?
how careful do I have to be with unprotected 10440s? I mean if I use the intellicharger and the efest batteries? Can I just leave the battery in for a month? I’d probably average like 5-10 minutes a day on the medium setting. If even that.
How do I know when to charge the battery? I’m there’s there’s a FAQ on the interwebs.
Thanks
Robby
LowLumen
Last seen: 1 hour 13 min ago
I wouldn’t use unprotected Li-ion in that light. It will drain the battery dead before you have a clue it is happening. Just get some AAA eneloops and a ni-mh charger for it. These will work so much better than the Alkaline you are using.
centaurus3200
LowLumen
Those are the right batteries but that charger only charges batteries in pairs. (1&2, 3&4 together)
You really should get a charger the charges each battery separately. Much better for the batteries and since you have a single cell light.
zak.wilson
  • An unprotected lithium-ion battery will not drain any more in almost any flashlight that’s turned off than it would sitting on the shelf.
  • You don’t have to be very paranoid about over-discharge. If you notice it getting dimmer, that’s time to charge the battery. If you don’t use it a lot, turn it on high once a month to check, or just put the battery on the charger monthly regardless of apparent performance.
  • Eneloops hold about 1 watt-hour. Efest 10440s hold about 1.4. If they were supplying equal power to the light, the Efest would last longer. They’re not; at the higher voltage, the 10440 supplies more power. Medium with the 10440 may well be similar to high with the AAA with longer life, depending on how each mode of this light responds to those particular batteries. High with the 10440 will be very bright and drain the battery very quickly (my 1-mode 10440 light lasts 15 minutes).
  • Leaving the batteries in the Nitecore charger should be safe, as it turns off when it detects the batteries are charged. I’d still probably take them out if we’re talking about weeks instead of a day or two.
  • Unprotected batteries do not shut down when too much current runs though them, as in a short circuit. The Efest 10440 can put out a steady 3 amps at around 4 volts for about 5 minutes. That’s enough to start a fire. Don’t short them.
CRX
CRX's picture
Last seen: 2 weeks 1 day ago
Lots of info for you here
centaurus3200
wow, lots of info! i’m thinking 10440s are overkill for my purposes and there’s always be a part of me worrying about using unprotected li-ions.
as far as eneloops and chargers, what about this one then. and how do the panasonic pro eneloops compare to the regular 4th gens? or pretty much teh same?
i mainly just want to be able to use the 96 lumen high setting on the ITP A EOS more than just the first few weeks of a fresh alkaline before the battery no longer has the juice to power the flashlight’s high setting.
http://www.ebay.com/itm/PANASONIC-PRO-kit-ENELOOP-AAA-4-Pack-BK-4HCC-4-BQ-CC17-Advanced-Charger-/221554601314?pt=US_Rechargeable_Batteries&hash=item3395aeed62
is there a problem with my previous link of using the cheapie tandem chargers (need to charge two batteries at once). or will the cheapie charger wear the batteries out or possibly overcharge them?
thanks,
Robby
Rufusbduck
Rufusbduck's picture
Cheapie chargers and cells don’t last. You end up buying new ones and the whole point of rechargeable cells is avoiding replacement. All my radio shack nimh’s are dead and none of my Efest 10440’s have failed though several ultrafire cells have. Eneloops have a good reputation but I prefer the higher output capability of liion so my recommendation would be a couple Efest 10440’s and an MC0 charger from Mtnelectronics (plugs into any USB) so you can charge it anywhere you can charge your phone. Your choice in the end and not wrong either way but I don’t think you’ll hear many voices recommending the cheapest options of either type.
Scott
centaurus3200
Okay, I think I’ll buy a nitecore intellicharger, 4 Panasonic eneloops and two efest imr 10440s to play with. If I don’t use the 10440s for a year, will they take out my house?
Rufusbduck
No, self discharge rates are low but check them once in awhile with a voltmeter. Best to store around 3.7V. I find it handy to have one of the small led voltmeters to check cells.
Scott
centaurus3200
okay, latest is intellicharger i4, 2 efest 10440’s and a 4 pack of eneloop AAA’s.
can i just use this little battery tester with the eneloops and the 10440’s? i just want something simple.
http://www.ebay.com/itm/New-BT-168D-Digital-Testers-for-Button-Cell-Batt...
looking forward to not having to buy bulk pack AAA’s from costco anymore Smile
Robby
zak.wilson
That battery tester looks like it’s just a voltmeter, so I’m guessing yes. It says it supports 1.5 volt and 9 volt batteries, so it probably works with 4.2 volt batteries too.
Rufusbduck
This is what I was referring to. Works on any cell 2.5 -30V. Cheap. MtnE usually stocks them but is out tight now.
Scott
jerm03
Last seen: 5 days 7 hours ago
Be aware that some AAA lights will not accept protected lions. I just one of my iTP A3 lights, and a protected Ultafire was too long, and would not fit. I remember a thread maybe a year ago that showed how to modify a light to take the protected 10440’s, but could not find it.
I just use unprotected batteries, but normally prefer eneloops.
Jerry
centaurus3200
got presents this week to try with my ITP A3 EOS keychain flashlight.
bought a nitecore intellicharger i4
- efest IMR 10440-just one to try out
- panasonic eneloop AAAs
first question… does the efest 10440 come fully charged? i tried it in the ITP A3 – HOLY CRAP that thing is bright!
i have a battery voltage tester coming, but it’s not here yet. if the 10440 comes fully charged, then fine… i assume there’s no serious harm in putting the battery in the intellicharger it SHOULDN’T CHARGE the 10440 if it’s fully charged, right? just curious.
tried the AAA enelooops… meh… about the same brightness as a new akaline AAA, which is what is expected, eh?
next up, researching a “real flashlight” thinking of a convoy X3, but they seem to all be out of stock currently?
thanks,
Robby
Rufusbduck
Batteries are supposed to be shipped ~ 3.8V so yes, throw it on the charger.
Scott
LowLumen
Be careful using the 10440 in I3 that you don’t discharge it too far and ruin it.
Really need to monitor voltage on the battery as the light will give you no warning.
…. also that 10440 is rated for 300mA max charge rate, prefer 150mA rate.
I believe your charger will charge them much faster than this
centaurus3200
Just read the nitecore instructions.. It says I should never charge just one 10440. There’s too current voltage for 1 battery. Wtf? That was the whole point of the charger!
I only have 1 efest 10440.
Should I put an AAA eneloop in there in the slot next to it?
The eneloop is already charged though.
Muto
Last seen: 4 hours 56 min ago
The amperage will be halved if you use slots 1&3 or 2&4 together.
Do you have any other 3.7 volt batteries?
If so, insert one of those in the other alternate slots. 375 mAh is close enough to the 300 mAh recommended.
Do not know what will happen if you use one of the Eneloops in the other slot.
HTH
Keith
The difference between Hoarding and Collecting is the illusion of Organization
.“I will get one of flashlight from patrol car”
“History doesn’t repeat itself, but it sometimes rhymes,” Mark Twain
After the Apocalypse there will be only 2 things left alive, Cockroaches and Keith Richards
Halo...
Halo...'s picture
Last seen: 5 years 5 months ago
375mAh is 25% higher than 300. And 300 is already the max recommended fast charge. 150mAh is recommended and what your suppose to aim for. When you push it you degrade your battery, reduce its capacity and life.
centaurus3200
So this seems a bit disconcerting… Seems I pissed money away on the nitecore i4. Needs two 10440s… And even 375mh is a bit high or will this thing be fine if I charge two 10440s ? What if one charges before the other?
Will it zap the 10440 still charging with 750mh?
Can I put 1 10440 in with 1 charged eneloop AAA? Reason being to get the current halved. Or is that useless because the current won’t be halved if the other battery us already charged.
Gah, this stuff is frustrating!
Rufusbduck
Why I recommended the Xstar MC0 charger. Inexpensive and good for all the small cells from 10440 up to 18350.
Edit- you’ll just have to get an 18650 light to go with that nice charger. The learning curve in this hobby pretty much guarantees this sort of inefficient use of funds. For some reason it doesn’t ever seem to get better.
Scott
Muto
OK, but his choices are 750 mAh or 375 mAh, so here we are. Lesser of 2 evils, doesn’t make it perfect but it is what he apparently has for choices at this venture until he can acquire a low powered charger.
Bottom line, it is a $3.35 battery.
Yes, he needs to get a nice low powered charger, I have been happy with the XTAR MC0 and it only costs like $6.
On low it puts out 250 mAh.
Who makes an inexpensive quality 150 mAh charger?
Driving an LED at twice it’s recommended amperage will no doubt lessen it’s lifetime, yet we do it everyday.
It’s all relevant.
Thanks,
Keith
Rufusbduck
Check the cell temperature while it’s charging. If it doesn’t get hot then yes it will have a shorter lifespan than otherwise but not a problem. If it does get hot then under no circumstances should you continue charging at the higher than rated input current. Get an MC0 or if you feel up to some light modding a PT4056 charge board from Mtnelectronics, even cheaper and with a resistor swap to set charge current as low as 40mA.
Scott
centaurus3200
Well, I do have a variac… Can I plug the nitecore into it at say 60 volts? Or it has a regulated power supply and won’t even turn on unless it sees 110 ?
