Test/Review of USB meter: Volt Current Voltage Charger Capacity Tester
6 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 6 min ago
DSC_7491
Official specifications:
  • Voltage: 3V-10V(accuracy: 1% )
  • Current: 0-3.3A(accuracy: 0.4% )
  • Display Panel: OLED(letter color: white)
  • Size: 42mm * 19mm * 10mm(1.65'' * 0.75'' * 0.39'')
  • Sampling resistance : 50mOhm
  • Reading: U=Voltage, P=Power, I=Currency,C=Capacity(mAh)
I found this unit on Ebay at a dealer called axeprice
How does it look
DSC_7476
DSC_7477
The usb connector is not mounted straight.
DSC_7494
DSC_7478 DSC_7479
DSC_7481
The small display is a graphic OLED display with very small letters.
DSC_7821
I could just pry the box open.
DSC_7822
This device does not have a current sense resistor, but uses a MAX471 current sense chip (That has a 35mOhm resistor inside).
DSC_7823
DSC_7824
DSC_7825
Measurements
Test
The watt display is not U*I, but slightly above, this may be due to rounding. Also be aware that the voltage is somewhere between Vin and Vout, i.e. the power is neither input or output power, but something inbetween.
The voltage readout works from around 3.5 volt, but current is first correct above 4 volt.
  • Capacity always starts from 0 when power is turned on.
  • Own current consumption is 15mA
  • USB data works fine.
  • Capacity display are zeroed when power is disconnected
  • Internal resistance is about 0.13ohm including connection resistance.
  • Voltage display is within 0.04 volt in the 4.0 to 6.0 volt range.
  • Current display is within 0.01 ampere in the 0 to 3.0 ampere range with 5 volt supply.
  • Text on display is small, numbers are maybe 2mm high.
Temp1343
M1: 43,4°C, M2: 50,1°C, M3: 42,8°C, HS1: 53,2°C
Even with this fairly low internal resistance the device gets warm at 3A.
Temp1344
M1: 56,5°C, M2: 50,9°C, HS1: 67,5°C
Conclusion
Fairly low resistance, good precision, works from 3.5 volt for voltage, but more than 4 volt for current, capacity and power display, but the display is fairly small.
This is a good usb meter when measuring at 5 volt.
Notes
How do I make the test
Edited by: sb56637 on 06/25/2015 - 13:46
Woody
Woody's picture
Last seen: 2 weeks 4 days ago
Another great review HKJ – many thanks. I don’t think this is available from ebay.co.uk – the seller axeprice on ebay.com won’t ship to the UK.
HKJ
HKJ's picture
Woody wrote:
I don't think this is available from ebay.co.uk - the seller axeprice on ebay.com won't ship to the UK.
You might be able to find it at another dealer.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 1 year 4 months ago
Nice..thanks!!!
hammerJoe
Is this a good buy or not?
WarHawk-AVG
If HKJ says this
Quote:
Conclusion
You can be guaranteed as long as the seller is reputable…this model of USB Volt Current Voltage Charger Capacity Tester is a good design
