Test/Review of Component tester MK-168
9 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 hours 17 min ago
DSC_7182
This is a fairly universal component tester, it can recognize a lot of different component types and give some parameters for them.
It is also fairly cheap on ebay
How does it look
DSC_7342
This tester is in a box with 2 mm connections, it includes test wires.
DSC_7341 DSC_7343
It does also include a circuit board with a socket and a smd pattern. The box has a connector for external power, but can also fit a 9 volt battery inside.
DSC_7344 DSC_7345
DSC_7184 DSC_7185
Inside it is made very nice with connectors and a circuit board designed for this box.
DSC_7188 DSC_7189
The display is a standard display with 2 lines with 16 characters.
DSC_7193
All the electronic is placed under the display.
The circuit is very simple, the microprocessor do everything. It has 3 pins connected to each of the 3 terminal, one directly for ADC, the two other pins with different resistors between.
DSC_7195
The adapter has a smd pad, but with fairly limited functionality.
DSC_7194
DSC_7196
Resistors
R
The ohm range looks fairly good.
DSC_7285
The display it not graphical, but because it is possible to program some characters it can show a useable symbol.
Capacitors
C
It cannot measure small capacitors.
DSC_7288
Inductors
ind
With inductors it uses the resistor symbol, but shows a inductance in addition to the resistance. It cannot measure small inductors.
DSC_7289
Diodes
diodes
Due to the 5 volt test voltage it cannot see zener diodes above 5 volt.
DSC_7291 DSC_7290
There is a bug in the symboles, one of the diodes are not programmed correctly.
SCR (Thyristors) + Triacs
scr
It cannot detect most SCR and triacs, because the tests currents are too small. Only very small types are detected.
DSC_8076
Triac is spelled out and MT1 and MT2 is shows as 1 and 2.
BJT (Bipolar junction transistors)
BJT
It do see the diode in the transistor, but not the resistor.
DSC_7292
There is not space for a transistor symbol on the display, the letters NPN or PNP are used instead.
DSC_7293
The faulty diode symbol is a bit confusing to see here.
FET (Field effect transistors)
FET
It can detect normal fet transistors, but not a deflection transistor.
DSC_7294
IGBT (Insulated gate bipolar transistor)
Not supported
Voltage regulators
Not supported
Technical details
Components are tested with 5 volt signals.
When on the current consumption is 10mA to 27mA.
When off the current consumption is 0.
Conclusion
The tester will recognize many different components and show the values. For passive parts the precision is fairly good.
It can recognize the common semiconductors, but fails on some more special types. There is also the "problem" that any testing values shown for diodes, BJT and FETS are at unspecified conditions and the values will change with conditions.
I could have wished for a better SMD pattern.
For the money it is a good tester for leaded parts and acceptable for smd parts, but the defect diode symbol is confusing.
Notes
This tester is based on this design:
Original design article in German
Improved design (czech clone)
Software
About the testing of testers
kuoh
Last seen: 3 weeks 2 days ago
I had no idea such versatile diagnostics devices were available at such a low price. Now I’m off to shop for one! Thanks for the review.
KuoH
HKJ
HKJ's picture
kuoh wrote:
I had no idea such versatile diagnostics devices were available at such a low price. Now I'm off to shop for one! Thanks for the review.
There are many different models, most of them based on nearly the same hardware and software, but they are not the same.
I do plan to post some more reviews of these testers
kuoh
I couldn’t wait, so I just ordered one of these GM328 because it included a frequency generator. However, I have since found a youtube review showing the model you tested that indicated it also has a frequency counter / generator. Did you happen to check if yours has that functionality as well? I like that it has a case, but prefer one of the other variations with bigger graphical LCDs.
KuoH
HKJ
HKJ's picture
kuoh wrote:
I couldn't wait, so I just ordered one of these "GM328":http://www.ebay.com/itm/121430288103?_trksid=p2060778.m1438.l2649&ssPage... because it included a frequency generator. However, I have since found a youtube review showing the model you tested that indicated it also has a frequency counter / generator. Did you happen to check if yours has that functionality as well? I like that it has a case, but prefer one of the other variations with bigger graphical LCDs.
I missed that, but it has that functionality.
texaspyro
Last seen: 2 years 6 months ago
The units with the fancy extra features require a ’328 processor that has more memory in it. HKJ’s use the smaller ATMEGA 168 processor.
I also bought a couple of the GM328 units. I wish it had the power-off button. It does the auto-poweroff, but it takes a while to kick in. I also wish it drew the diode symbol bigger.
The GM328’s have fixed high parasitic power drain that my earlier units had. They also draw a symbol for SCRs and triacs. My earlier ones just had a text display for those part.
kuoh
Which extra fancy features, the bigger graphical LCD or something else? It seems from the video I found, that at least some 168 models also include a frequency counter / generator. I do like the 328’s display better, but wish I could’ve found one with a case. I might get this 168 as well, since it can do almost the same thing and has a good case and build quality. As for the power off, I guess it would be simple enough to add a switch in with the battery. It’ll be nice to have something that I can test my cheap scopemeter against.
KuoH
Chloe
Chloe's picture
Last seen: 5 years 6 months ago
Thanks for the review. Will you review any of the kits available?
HKJ
HKJ's picture
I am way to lazy to solder a kit together. I will only be looking at the assembled versions.
