Test/Review of Efan IMR18650 2000mAh (Red)
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 6 hours ago
DSC_6567
Official specifications:
  • Spec: Lithium 18650-2000mAh 3.7V
  • Material: IMR
  • Capacity: 2000mAh
  • Nominal voltage: 3.7V
  • Lowest permitted discharge voltage: 2.5 V
  • Cycle life: 500 cycles
  • Max charging rate: 4.5 Amps
  • Max continuous discharge: 8C
  • Do not short circuit - High current will be discharged
  • Diameter: 18.2 +/- 0.5mm
  • Height: 66.34 +/- 0.5mm
  • Weight(g): 98g/pair
  • Operation Temperature Range: Charge(0~45°C ) Discharge(-10~60°C )
Efan%20IMR18650%202000mAh%20(Red)-info
A high current 18650 battery.
DSC_6565 DSC_6566
DSC_6568 DSC_6569
DSC_6570
DSC_6571
Efan%20IMR18650%202000mAh%20(Red)-Capacity
The two cells matches fairly good and has nearly constant capacity up to 7A, both 10A and 15A looks like heavy overload.
Efan%20IMR18650%202000mAh%20(Red)-CapacityTimeHours
Efan%20IMR18650%202000mAh%20(Red)-Energy
Efan%20IMR18650%202000mAh%20(Red)-PowerLoadTime
Efan%20IMR18650%202000mAh%20(Red)-TripCurrent
Efan%20IMR18650%202000mAh%20(Red)-Charge
Conclusion
The cells has accetable performance at lower currents, but its high current ability is not that impressive.
Notes and links
The batteries was supplied by Efan for review.
Compare to 18650 and other batteries
Shadowww
Last seen: 3 hours 17 min ago
dat protection test graph.
Ledsmoke
Ledsmoke's picture
TY for the review.
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
HKJ
HKJ's picture
Sorry about that, I forgot to strip the last data point.
It is fixed now
ImA4Wheelr
Thank you for the review HKJ.  Your cell reviews are such a great resource for our hobby.
lagman
lagman's picture
I’m surprised at your calculated internal resistance. 0.26 ohms is way too much for a cell capable of discharging at 10A.
My English isn’t perfect but I’m trying to improve it. If you see something that doesn’t sound right or is just plain wrong, please feel free to point it out! Smile
HKJ
HKJ's picture
lagman wrote:
I'm surprised at your calculated internal resistance. 0.26 ohms is way too much for a cell capable of discharging at 10A.
That is also a bit misleading, I do my calculation at the maximum current in the "protection" chart and because the voltage drops significantly at that current, I get a fairly high value.
