This is my 5th project since I joined BLF and it is also the most complex one, I’ve never worked with a maglite before, in fact I never owned one. So I want to thank OL for inspiring me!
The idea was to create a 2D Maglite capable of 4,000+ lumens while being100% stock outside, I chose a purple 2D mag because it looked very unique. I’ve seen lots maglite mods based on 3x XM-L using individual optics, or 4x XM-L using the 50mm Quad optic. But I wanted something different so I went with 4x XM-L using 4 individual Carclo optics. And of course the Zener modded BLF17DD.
First challenge was the maglite head itself with a ID of 48mm at the lower part, while the optics with the base were 22mm. Visually it was impossible to fit 4 of them, but after some measurements with the precision caliper and carefully sanding them down with a dremel for almost 1 hour, the fit was perfect. Something very interesting I found, the Carclo 10003 holder has 4 legs that perfectly grab a 16mm mcpcb and centers the led.
Not very pretty but it works!
The optic itself was untouched since I only sanded the base, it went from 22 to 19.5mm!!
Close-up of the optics in place…
Next I secured all 4 optics together with double side tape and a coin, so I can mount the noctigons in the base to get an idea how to wire them. I used 4x XM-L2 U3 1A on 16mm noctigon wired 2S2P. The aluminium heatsink is 48mmD x 6mmH. You can see in the picture I also purchased Ledil XRS optics but sanding them down affects the beam, also they are too tall for the MagD, I might mod a MagC later which has a taller head.
Before the Arctic Silver 5 thermal epoxy.
They were aligned using the fixed optics. I pressed too hard and they moved a bit… But because the AS5 is metallic colored it doesn’t look as bad. 22awg.
Perfect alignment!!!
Everything fits nicely!! :party:
Now about the batteries. I used 1 1/4” PVC extension tubes with 2 o’ rings and it perfectly fits the 32mm ID battery tube. ID of the PVC tube was 28.2mm but my 26650 don’t rattle… EVVA 4000mAh from MTN.
As for the tailcap, I cut the last 2 “turns” of the spring and used the larger one to fit on the edge, then placed 2 copper braids for a direct contact with the body.
Close up of the spring.
I was ready to assemble everything and proceeded to remove the switch to improve the current flow and add a top in the +ve contact for the flat tops. I was told it can be removed with a “L” hex key so I patiently tried one by one… THEY DON’T FIT!!! |( At this point I was desperate and went to the computer to google for the answer. So apparently newer maglite models uses a “Special Screw” that can only be removed with an “special driver”, which is just a T8 torx with a very thin shaft. I don’t have a T8 so I had to order one online. My project is on hold until it arrives.
So that’s all for now until my torx arrives and I get to finish the swith!!
To be continued…
What to do now? I have plently of free time so I did a quick bench test. Decided to use my cheap DMM with 18awg leads and 2 fully charged 26650s. The wires are LONG for this test but I just wanted a quick reading so why not.
Edit: Improved my connection by revealing a new bit of DMM lead and now it pulls 8.6A!!
First impression was DAMN BRIGHT and it got hot in just seconds. It’s drawing 72 watts so 18W/LED, with a 3.7 vF I assume ~4.8A each emitter, Is that Ok? Anyways I expect higher numbers once I assemble the light and shorten the cables.
A quick ceiling bounce says it is puts out more light than my Nitecore TM26 (3800Lm). Throw is very similar, not great but it’s to be expected from 20mm optics.
Ceiling bounce results:
TM26 with 4 NCRB: 510lux
Quad XM-L2 Mag: 878lux
