Test/Review of Efan IMR18650 2100mAh (Purple)
Official specifications:
  • Nominal capacity: 1600mAh, Discharge at 0.2ItA, 2.5V cut-off after Standard charge
  • Rated capacity: 1500mAh, Discharge at 0.2ItA, 2.5V cut-off after Standard charge
  • Nominal voltage: 3.7V
  • Charge voltage: 4.20±0.05V
  • Cut-off voltage: 2.5V
  • Max. charge voltage: 4.25V
  • Continuous maximum charge current: 10A
  • Continuous maximum discharge current: 30A
  • Weight: 50.1±1.5g
  • Allowable environment temperature: Charge: 0 to +45degC, Discharge: -20 to +60degC
A high current 18650 cell with a good capacity.
The tracking looks good between the two cell and the capacity only drops slowly with high current load. The voltage drop at 30A looks high, but the cell handles it.
Conclusion
The cell has good high current performance and decent capacity.
Notes and links
The batteries was supplied by Efan for review.
Compare to 18650 and other batteries
Thanks!
Thanks for the test!!! It’s really helpful. :smiley: If you guys interested in those 2100mah battery,just contact me in here.
