Test/Review of Efan IMR18650 2500mAh (Purple)
11 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 6 hours ago
DSC_6544
Official specifications:
  • Capacity, Std. charge / discharge: 2500mAh
  • Nominal Voltage, average of Std. Discharge: 3.70V
  • Standard Charge: constant current 1250mA, Constant voltage 4.20V, End current(Cut off) 50mA
  • Fast Charge: Constant current 4000mA, Constant voltage 4.20V, End current(Cut off) 100mA
  • Max. Charge Voltage: 4.20V
  • Max. Charge Current: 4000mA
  • Standard Discharge: Constant current 500mA, End voltage(Cut off) 2.5V
  • Fast Discharge: Constant current 10000mA, 20000mA, End voltage(Cut off) 2.5V
  • Max. Discharge Current: For continuous discharge 35000mA
  • Weight Approx.: Max. 48.0G
  • Operating Temperature: charge 0 ~ 50°C, Discharge -20~ 75°C
  • Storage Temperature: 1 month -20 ~ 60°C, 3 months -20 ~45°C, 1 year -20 ~ 20°C
  • Dimension: (D)18.3 + 0.2/-0.3 mm, (H) 66.0 ± 0.2 mm
Efan%20IMR18650%202500mAh%20(Purple)-info
This is a very high current battery, but the 35A rating might be a bit optimistic.
DSC_6542 DSC_6543
DSC_6545 DSC_6546
DSC_6547
DSC_6548
DSC_6549
Efan%20IMR18650%202500mAh%20(Purple)-Capacity
These curves shows a very good battery, there is a good tracking between the batteries and not much capacity drop from 0.2A to 20A.
Efan%20IMR18650%202500mAh%20(Purple)-CapacityTimeHours
Efan%20IMR18650%202500mAh%20(Purple)-Energy
Efan%20IMR18650%202500mAh%20(Purple)-PowerLoadTime
Efan%20IMR18650%202500mAh%20(Purple)-TripCurrent
Efan%20IMR18650%202500mAh%20(Purple)-Charge
Conclusion
This cell has very good high current performance.
Notes and links
Compare to 18650 and other batteries
wolfdog1226
wolfdog1226's picture
Last seen: 2 years 6 months ago
Thanks for the review!
Would you say it is comparable to the Efest IMR 18650 2500mAH 30A Battery?
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
HKJ
HKJ's picture
Yes. The differences in performance may be due to different age of the cell.
dangerous
dangerous's picture
Last seen: 6 years 10 months ago
I’ve heard they may be rewrapped VTC4.
BLF
HKJ
HKJ's picture
dangerous wrote:
I've heard they may be rewrapped VTC4.
Use my comparator and compare the discharge curves at both low and high currents. It is easy to see if it possible.
Billy X
Billy X's picture
Last seen: 2 days 1 hour ago
This seems to be the group with the best cells overall for high amps.The Basen 2.5 and AWT2.5Ah clearly have the same,very good,cell under the wrapper.would like to know what that cell is.The E fest 2.5 purple is slightly below on voltage sag,the same as the Efan,with the same discharge curve for both,just,about 100mAh more capacity for the E fest,production variation?The wrappers are even the same purple!I am sure all these cells are rewraps of at least 2 cells.One is the LG HE2 which HKJ has not tested as far as I can see,Sony is probably another.The KeepPower 2.5 IMR is up there with the basen and AWT,but again with maybe 150mAh less capacity but slightly less sag at the start,at all currents.They all seem to outperform the Samsung 20R.This group of cells seems the most interesting for the Eagle Eye X6 BLF special.
wight
Last seen: 1 year 8 months ago
I do not see discharge data for the VTC4, only VTC5. The VTC5 discharge does look similar to this one (but stretched out).
I’m keeping my eye on this thread. Thanks for the info HKJ.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Dru_dragon
Dru_dragon's picture
Last seen: 4 months 1 week ago
The VTC4 is there listed as Keeppower IMR 2600mah . These will either be Samsung 25rs or LG HE2s
Andrew
wight
Thanks Dru_dragon!
shadockan
shadockan's picture
Is LG Chem ICR-18650 HE2
shadockan
shadockan's picture
The KeepPower
IMR 2600, is the Sony Konion US 18650 VTC5.
The Makita bought all VTC5.
This is the reason that does not exist in the market .
I do not know how many managed to buy the KeepPower, but I think it would be not big lots , because neither you can find anywhere .
The KeepPower IMR 2500 is the LG Chem ICR HE2.
The new will be the LG HE4.
These I know , these are written . If I am wrong , please be deleted , so there is no misinformation
The Efan 2500, has been under the label of the LG Chem ICR HE2 also
