Problem with Oshpark board
I’m building an oshpark board designed by Mattaus.
https://oshpark.com/shared_projects/KSUAFAMT
So far I have 17 7135’s on it and I’m only getting 1.1 amps at the tailcap. All the modes are working correctly. Every time I add a 7135 the amps stay the same. I’ve started replacing the resistors one by one and I guess I change the zener diode next.
Ideas?
That’s a tried and true board design by many folks here (most notably O-L) so it has to be something on your end, can you tell us about the rest of the setup? Also are you running this from an MCU for testing or just pulling the VCC leg of the 7135’s high to enable?
Host, cell(s), emitter(s), all the details please…
The problem is me for sure! I ordered 3 of these boards but I only had 2 MCU’s with the Dr Jones program on it. For this extra board I used a MCU from a Qlite driver. The setup is very similar to O-L’s Maglite twins build only without the momentary switch since the Qlite MCU did not use one. I’m using effest 26650 batteries. The same batteries in another MT-G2 Maglite mod will pull around 5 amps on my DMM.
Hm, are the 7135’s you’re using new? Do you have a way to test them off the board? Which pad’s are you adding them too (can you post a pic)?
Are you sure you have the zener forward?
Any photos of what you got now would probably help. A close up of each side of the driver as it is right now.
There needs to be a sticky about this because it comes up every day ("Why are my current readings low?"). What kind of leads are you using to measure this? I'll bet that they are the stock meter's skinny leads.
Edit: I missed the part where you said you tested 5A with the same DMM. Is the rest of your measuring setup the same? Something seems very wrong to only measure 1.1A.
  • 5A isn’t that high, depending on the driver used in the other light.
  • What cells are these?
  • What DMM is this? Have you already installed heavy leads? [Testing 5A with the meter doesn’t actually prove that it’s got heavy leads.]
  • Eliminate the MCU by attaching the PWM trace from the 7135’s to Vcc for the MCU. That will be like high/maximum all the time and is ideal for testing.
Yes the 7135’s are new. Posting some quick pics. I will get a better shot of the 7135 side of the driver in a bit.
Could you spell out for a newb how to eliminate the MCU as you described?
Connect Pin8 (wired to R3 and Z1) of the MCU to Pin6 of the MCU (wired to the 7135’s). At that point the MCU is optional - as long as 8 and 6 are connected on the PCB you do not need the MCU, but it doesn’t hurt anything.
EDIT: Thanks for posting pics - that makes it easier to help!
Are you using this with a momentary switch or a clicky switch?
Clicky switch. Using mcu off a standard qlite. The standard maglite clicky is working good. Changes modes like its supposed too.
Is there a visible difference in brightness when you measure current vs when you operate the light as normal?
You still haven’t elaborated on (exactly) how you are doing the measuring (and what with).
Just to be clear, you are running an MT-G2 on this build also, right?
Have you tried bypassing the switch? As Wight noted, we need complete details about your setup before going further.
Before I put the juice to it will you look this over?
I see no problem there.
Correct, MT-G2 that I bought from you!
My multi meter is a Inova 3320 with stock leads.
Batteries are Efest 26650 35000 mah
I have similiar maglite 2D mods that pull around 5-6 amps on the same meter. I’m not too caught up in trying to get an exact amperage per 7135. I just want it to be as bright as the other mods. The other successful mods I have done had the Qlite driver with stacked chips. This is my first attempt at an oshpark build.
Are you measuring through the Maglite switch? Stock tailcap spring? There are a lot of possible places to add resistance and it only takes a little bit to drop a lot of current with an LED.
I was measuring through the maglite switch at first with a braid modded spring. Now I have the pill out of the flashlight and I’m measuring directly to the short battery and ground leads.
