Hey everyone, Any LogView users out there? I have a couple batteries I have tested and want to overlay the graphs but cant figure out how to import 2 charts at the same time?
Thanks
Thanks
Sorry, can't give too detailed an answer, as I have only started using Logview recently myself. However, I recently posted this same question on the International sub section of the Logview forums.
As I understand it, you select one of your discharge graphs, and then use the "compare curve" feature, which presumably allows you to select other graphs to overlay on to the one currently displayed on your screen.
If you run a number of discharges without turning off Logview, all your discharge graphs can be found in the drop down box above the main display where you can see the current plot. Presumably you can select these graphs to overlay, or use saved ones. Not had a chance to find out yet. Wish my German was better. :(
OK, I've been trying to compare some discharge curves myself today, went back to the Logview forum to re-read the response to my question about compring curves, and found that I had misremembered the method - sorry about that.
Rather than clicking compare curves, and then selecting the data sets to compare, it's the other way around - select then compare (makes sense really).
Here is the exact wording of the response I received: -
"Just rightclick in the Graph settings on one curve. Select 'Copy to compare Chart'.
Repeat it with your other datasets.
Now select Compare Curve under the chart view."
Hope that helps.
Stephen
