Update - $29.95 from GB, on the Ultrafire 1226 - GOLD COLOR ONLY
58 posts / 0 new
Old-Lumens
Old-Lumens's picture
Last seen: 5 years 9 months ago
$29.95. GOLD COLOR ONLY
uiuik,gtuik,
IF you want black you have to "wait for a while", till they "get some".  Whatever the hell that means, but you won't be getting black till they have them and it might be a day or two weeks with these people. If you bought a "Black One", then contact May@gearbest.com, to get your refund and if she gives you any crap problems let me know.
Ultrafire 1226
Coupon  UF1226CM
No Group Buy at this time. GB can't get it cheap enough to discount the price any more. I think it's too high as is, so I'm dropping the idea.
Here's a light from GB, that I know would serve as a larger reflector light for the MT-G2 and it would could run 2S/2P 18650, for longer run times. I like this style of light and I prefer it for walking.
Ultrafire 1226
On Gearbest it shows as Uniquefire, but the light is an Ultrafire. It doesn't really matter, these are made under a bunch of brand names.  Anyhow, I just want to see if you would be interested in this type of format for the MT-G2. It has a larger diameter reflector and it can be modded to 2S/2P 18650.
Of course, it can work well for the XM-L2 for a thrower. I just thought it would be good for the MT-G2.
This light is also made in a darker brown color and I am finding out if that is available as well. We might be able to choose, if so.
I have one coming, so I can tear it down and see what we have inside and give some details about it. I have played around with lights like this before, but that is back when I thought "massive heat sinks" were the answer, which I now know better. This one will have a thin heat sink, but if it is placed well in the head, it should transfer the heat out.
Anyhow, at this moment we could get it at $30.49, but I am working on a lower price, so if you have any interest, just post here.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
Edited by: sb56637 on 10/20/2015 - 12:18
netprince
netprince's picture
Last seen: 8 min 8 sec ago
Interest!
ImA4Wheelr
Last seen: 1 year 1 week ago
Definitely a good host with mod potential for any of the traditional emitters.  Super thrower with small emitter or decent throw with big emitter.  Seems to have enough surface area to handle an MT-G2.
If I recall correctly, the pill had a hollow center but was actually pretty thick and very big.  Press in a copper disk and it should be good to go.  I have a old review of one here.
netprince
netprince's picture
I’m curious how the handle feels? Is it well balanced? If you are holding the light by the handle, does it feel front heavy?
Boro
Last seen: 1 day 10 hours ago
Interested
RonMuller
interested for certain.
wight
Last seen: 2 years 6 months ago
Does this light use a battery carrier? I’m guessing no.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Old-Lumens
wight wrote:
Does this light use a battery carrier? I'm guessing no.
No, it's just like an SRK battery section, or very close to it.
wight
Thanks OL. Can you link me to a 2s2p conversion for this kind of battery setup? I’m drawing a blank right now.
Old-Lumens
Well, here's one way. I do believe I also did it with an SRK clone, but I would have to do some more searching.
http://budgetlightforum.com/node/26427
I think that is another way, but since I am at work and can't see the photos, I might have linked to something totally different.
http://budgetlightforum.com/node/21185
antiparanoico
Last seen: 2 weeks 5 days ago
WOW!!
If anything can go wrong, it will.
Matter will be damaged in direct proportion to its value.
wight
Old-Lumens wrote:
Well, here’s one way. I do believe I also did it with an SRK clone, but I would have to do some more searching.
I think that is another way, but since I am at work and can’t see the photos, I might have linked to something totally different.
The first link is the one I wanted to see. I think I’ve seen you do that on another build as well. Thanks.
ImA4Wheelr
I would describe it as slightly front heavy.  Not a strain to hold, but not balanced.  Fine for casual to medium length walks.  On a long hike, it would probably get on your nerves.
Jubeldum
Jubeldum's picture
Last seen: 6 years 6 months ago
Isn’t this the same light but black and cheaper
http://budgetlightforum.com/node/31602?page=1#comment-689261
MountainKing
An MT-G2 light for $30? Is this correct? or its the light to be used as host only?
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
C-channel
C-channel's picture
Last seen: 2 years 5 months ago
Yes. Interested.
How bright is bright enough...
Runtime VS Lumens...
Old-Lumens
The light would come as XM-L2. It would need modding to be MT-G2. It could be done fairly easily, with an Ohspark 7135 driver with xener mod or a FET DD, made the right diameter to fit in the light. With a copper insert in the pill and with a 26mm Maxtoch star. I would do a video of the mod and mod options. The driver gurus could do the Oshpark board easily, as it's just a matter of size, using already known components.
This light and the other one I am waiting on info for, are just less expensive hosts for people who want to do an MT-G2 mod themselves rather than buy a light already done. It's just a thought, if there is enough interest. Or they could just keep the light stock, or mod a higher powered driver in for the XM-L2.
Between this one and the Dipper 19, people could choose between body styles.
MountainKing
I see OL. I have zero tools to perform modding and thus have untested modding skills Smile Until I get some proper tools, I won’t be able to try myself at modding. So I guess I’ll be passing the offer. Thanks for the answer though!
nofearek9
nofearek9's picture
Last seen: 6 days 14 hours ago
nice light , prefer it black thow ,i hope it has mass pill for the heat.
HighEfficiency
HighEfficiency's picture
Last seen: 5 years 2 months ago
Definite interest depending on the level of complexity in modding for the MT-G2.
Looking forward to your updates.
Rufusbduck
Rufusbduck's picture
Reread that mod thread you linked to OL and was blown away once more at how you recreated the housing shape in JB Weld as well as all of the interior mods. I know there is a special place in your heart for Mag mods but I’d be interested in how this stacks up in terms of balance and beam.
Scott
Old-Lumens
Jubeldum wrote:
Isn't this the same light but black and cheaper "http://budgetlightforum.com/node/31602?page=1#comment-689261":http://budgetlightforum.com/node/31602?page=1#comment-689261 !http://i01.i.aliimg.com/img/pb/177/595/918/918595177_834.jpg![/quote] I believe the black one is different. Shorter reflector, but I can't be sure. Looks like the head is shorter. Still waiting for replies, just like with the other light. Takes a while for these guys to get together over there and get any results.
L4M4
L4M4's picture
Last seen: 14 hours 43 min ago
The head is definitely shorter.
The black one has no knurled part.
I don’t know… This would be awesome for the MT-G2 if it had a side switch or at least a better accessible switch.
Old-Lumens
If this thing happens, I would try to make the mod as easy as possible. I know many people don't have a lot of tools, so I will look at it from that standpoint and see what can be done simply, without having a lot of tools. Ultimately, it is a mod based change and that's kind of what I do. I figure some of the other guys show the simple led/star/driver changes and there's plenty of those, so I look at it as how much can you get out of it and still have a fairly decent budget on a master blaster light.
gamezawy
gamezawy's picture
Last seen: 3 months 23 hours ago
i am in for a group buy, thanks O-L interesting light.
garrybunk
garrybunk's picture
Last seen: 2 days 23 hours ago
Possibly interested.
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
Suncoaster
Suncoaster's picture
Last seen: 1 month 2 days ago
Location: Where the girls are green and the grass is pretty.
Interested, it would be a great MT-G2 host.
"In the land of the blond the one eyed man is king."
*This message is protected with ROT26 encryption.Old Lumens
my9221
Last seen: 4 hours 25 min ago
Interested!
Jubeldum
Jubeldum's picture
I’m interested. I hope we can get enough people to get on board so the price might get lower.
will34
will34's picture
Last seen: 6 hours 8 min ago
Interested
BILL G
Last seen: 6 years 10 months ago
I do not Need or Want a MT-G2, but I can use another XM-L2 Thrower. Grey would be nice. I have the Black one in Post #13 and it has a Shorter Ref.
