Did you ever carry/make a Nanjg 7135 driver that had moonlight low (I think it was 5mA mode) as well as H-M-L? I am trying to find a driver like this but can only find old discussions of it.
if you usually use the moolight mode ,i think LD25 driver is better ,LD25 has no pwm
and of course ,i can make moonlight mode version 7135 driver
wight wrote:
MRsDNF wrote:
Chloe wrote:
convoy-flashlight wrote:
sorry ,there is no star version LD25
Thanks for clarifying! Did you ever carry/make a Nanjg 7135 driver that had moonlight low (I think it was 5mA mode) as well as H-M-L? I am trying to find a driver like this but can only find old discussions of it.
:_( I notice that Ric did not bother posting 17mm pictures, both listings show the 20mm version. Do you have these? If so will you measure the spring for me? Mostly I'm interested in what diameter it is where it sits on the PCB.
The spring diameter is a couple of thou under 1/4''. The pad diameter is around that size or maybe 6mm. its hard to see.
djozz quotes, "it came with chinese lettering that is chinese to me".
:_( I notice that Ric did not bother posting 17mm pictures, both listings show the 20mm version. Do you have these? If so will you measure the spring for me? Mostly I’m interested in what diameter it is where it sits on the PCB.
The spring diameter is a couple of thou under 1/4’‘. The pad diameter is around that size or maybe 6mm. its hard to see.
Well, I do not notice the PWM so much on these drivers. But I know others do not like it.
Can you make LD25 driver with moonlight too? How low can the current be for moonlight?
I would like something like <1 lumen – Low (5%) – Medium (30%) – High (100%).
THAT IS AWESOME! Does this mean I can reprogram the driver to have the modes Low, Medium then High instead of high first? Also, does the brightness programming change the output of strobe and SOS as well? Thanks.
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself.
I also got 3 of those 105d drivers instead of regular ones, and i was refunded, in the opened ticked a guy assued me there those shoudlnt be even in the store
And mine didnt have memory too
From now on will order 4 mode ones
I don’t see what the extra three resistor spots are for.
The stars on this version, while functional, are mainly for show. R3/R4/R5 are where you easily bridge each star to GND. A pick-n-place machine or assembly worker can easily place a zero-ohm jumper across those pads.
stars for bridging throw some 000 resistors on the pads, if you look close the star is connected to one side of the resistor pad, the other side is connected to ground
Most definitely odd, but interesting on the new revisions of the 105 *7135 type drivers
Sure! If I had 9hr of work I’d forget where to go home to.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Yes, that was it. I don’t think they sell them anymore. I do have an Atmel programmer somewhere but it’s just easier to buy a new driver.
Thank you for the links! I didn’t know about these.
$4.7 seems a bit expensive!
Plus it has two medium modes. >.< Reflashing looks like the way to go.
IOS has them listed, but I have been getting them from Mountain Electronics.
Flashlight designers should look at lighthouses and pottery.
这些谁设计的手电筒应该看灯塔,以及在陶器。
my aliexpress store:
http://www.aliexpress.com/store/330416
skype: simon.maomao
sorry ,i dont understand “Qlite from IOS”
skype: simon.maomao
Note that “4th Star : 5mA – 2% – 25% – 100%”
LD25 may be better, I do not know.
skype: simon.maomao
skype: simon.maomao
Can you do that for each mode??!
video of LD25 output current setting ,wish you success!
Thanks wight!
Thank you!
I had the same issue and opened a ticket because I always use the stars for switch/offftimecap.
Put mine to good use
Quite nice to have a symmetrical layout on top for stacking and making improved thermal paths. Glad I got a few of these by accident.
Complete conversion of BTU shocker: 3x Mt-g2, Handle, Battery Pack. >9000Lumens ~150W
Courui "Even Bigger Head" D01
Looks like FT updated their listing pictures for the 2-group '105c'. Yet to update the title, description and specs.
Came across this tonight.
http://www.kaidomain.com/product/details.S023811
http://www.aliexpress.com/store/product/2015-Arrival-Free-Shipping-Nanjg-105E-AMC7135-x-8-MCU-3040mAh-4-Group-2-5-modes/809204_32259022955.html
Which gets really boring. – Tuomas Holopainen, 2015
Heh, interesting.
