1. Post #53 - FrickelFreak - Moonlight Special 17mm 8x7135 driver.
2. Post #101 - BLightSam - XTAR VC2 charger.
3. Post #21 - Kodachrome40 - A pair of Enova 2600mAh 18650 flat top batteries.
To the rest of you: better luck next time!
I just hit 2000 posts this afternoon, so I figured that a giveaway was in order--plus it's the Christmas season (even if I'm a little bit late). I am going to open up one of the items to our international members as well.
I am especially thankful for all of the help and support I've received from many of you over the past 2000 posts! You all have been great!
Rules:
USA ONLY on the batteries and charger, but the Moonlight Special driver can go anywhere USPS ships worldwide.
You may post only ONCE in this thread. Multiple posts will disqualify you.
You MUST specify which of the three items you would like to receive (you can only post about one of them). Posting about multiple items will disqualify you.
Example: I'm in for the Moonlight Special driver!
A winner for each item will be selected randomly by post number on 12-18.
Giveaway Items:
Moonlight Special 17mm 8x7135 driver. Super-low moonlight mode, extra efficiency in the lower modes, and off-time memory. What's not to like?
XTAR VC2 charger. Probably the nicest USB powered charger out there. 2x0.5A charging with LCD display screen. [USA ONLY]
A pair of Enova 2600mAh 18650 flat top batteries. [USA ONLY]
So at this rate you have posted roughly four times a day. Is that good, bad or naughty?
If anyone is interested the driver RMM is giving away is a real wonder. I hope he does not mind me posting a link, if your interested check the options out on it. If I have the wrong driver I will be just a little embarrassed.
Received a lot of great laptop pull cells today so changing my mind, if that’s okay. I’m now in for the XTAR VC2 charger instead. Thanks for this opportunity!
