Test/Review of AWT IMR18650 1600mAh (Yellow)
1 post / 0 new
HKJ
HKJ's picture
Last seen: 5 hours 43 min ago
Flat top version (ft)
DSC_6759
This is a high current battery with fairly low capacity.
Official specifications:
  • Nominal Voltage: 3.7V
  • Capacity: 2000mAh (35Amp)
  • Lowest Discharge Voltage : 2.50V
  • Standard Charge: CC/CV ( max. charging rate 4.5A )
  • Cycle Life: > 500 cycles
  • Max. continuous discharge rate: 10C
AWT%20IMR18650%201600mAh%20(Yellow)%20ft-info
The battery does nice up to 20A with acceptable tracking between the cells and nearly constant capacity, but it cannot do 30A.
DSC_6758
DSC_6760 DSC_6761
DSC_6762
DSC_6763
AWT%20IMR18650%201600mAh%20(Yellow)%20ft-Capacity
AWT%20IMR18650%201600mAh%20(Yellow)%20ft-CapacityTimeHours
AWT%20IMR18650%201600mAh%20(Yellow)%20ft-Energy
AWT%20IMR18650%201600mAh%20(Yellow)%20ft-PowerLoadTime
AWT%20IMR18650%201600mAh%20(Yellow)%20ft-TripCurrent
AWT%20IMR18650%201600mAh%20(Yellow)%20ft-Charge
Button top version (bt)
DSC_6734
AWT%20IMR18650%201600mAh%20(Yellow)%20bt-info
The button top version has slightly higher resistance due to the button top. This is only significant well above 10A.
DSC_6733
DSC_6735 DSC_6736
DSC_6737
DSC_6738
AWT%20IMR18650%201600mAh%20(Yellow)%20bt-Capacity
These two cells do also track very nicely.
AWT%20IMR18650%201600mAh%20(Yellow)%20bt-CapacityTimeHours
AWT%20IMR18650%201600mAh%20(Yellow)%20bt-Energy
AWT%20IMR18650%201600mAh%20(Yellow)%20bt-PowerLoadTime
AWT%20IMR18650%201600mAh%20(Yellow)%20bt-TripCurrent
AWT%20IMR18650%201600mAh%20(Yellow)%20bt-Charge
Conclusion
The battery is a acceptable high current cell, at least up to 20A, but the capacity cannot match the newer high current cells.
Notes and links
The batteries was supplied by AWT for a review.
Compare to 18650 and other batteries
Edited by: HKJ on 12/15/2014 - 14:09
