Is there a 4x18650 parallel host, or else cheapest way to build it?
I’m interested to put in a few NW/CW XML2’s, up to 4, and put in my own 105c driver with stacked or slave 7135s.
Which host/cheap donor would you recommend?
Supfire M6 is probably the big answer around here. You should be able to get one to your door for $40-$50 USD I’d say (not counting import taxes?).
If you need more than 3 emitters I think you can swap in a Skyray Kung reflector or other 5/6 XM- reflector.
EDIT: if you want cheap then you’ll be looking at an SRK clone with the 4x reflector.
32
SRK and clones are from $32 upwards cheapest that I could find, and often without solid pillow hole, supfire seems better for just few bucks more, so supfire it is. Thanks.
