Newbie wants to start soldering. Suggestions?
4 posts / 0 new
kragmutt
Last seen: 11 months 1 day ago
Hello fellow BLFers, I want to get started soldering, so I guess I should start with cheaper equipment, right? below is a quote from Oldienea on another thread. Are these good to start with, or are there other suggestions out there? Maybe a vacuum desolderer?
Oldienea wrote:
I give you a list of what I use, but there will be probably other suggestions to come, from our modding professionals.
I use this iron:
http://www.dealextreme.com/p/heat-adjustable-60w-electronics-diy-solderi...
then you need solder, something like this:
http://www.dealextreme.com/p/1mm-1-meter-rosin-core-solder-16027
and some flux:
http://www.dealextreme.com/p/goot-super-soldering-flux-6502
and maybe something to remove solder, like that:
http://www.dealextreme.com/p/goot-wick-soldering-remover-1-5mm-x-1-5m-6252
and this soldering paste is not a must, but I find it useful:
http://www.dealextreme.com/p/lodestar-soldering-paste-50g-4711
Thats solder and flux in one. I use it for pre-tinning wires and solder points.
Ah, I forgot to mention I use also this, because I have a bad eyesight:
http://www.dealextreme.com/p/led-illuminated-cheaters-magnifier-with-3-m...
Edited by: kragmutt on 08/05/2011 - 18:21
E1320
E1320's picture
Last seen: 11 months 5 hours ago
That looks like some great advice start on some broken or junk lights so it doesn't hurt so bad if you mess them up. I used a cheaper soldering iron for many years, I just recently upgraded my soldering iron.
I have one of those clamps that Triker posted they are very useful.
I am already visualizing the duct tape over your mouth.
kragmutt
Good idea. Link? I don't even know what it's called so I don't know what to look for...
robostud5000
Last seen: 9 years 6 months ago
unless you're doing a lot of big jobs, de-soldering braid should be fine.  you don't really need a pump.
