Closed - Last of the Christmas Giveaways from O-L - The Winner is DrJones!
And the winner is:
DrJones!
Here's a light that is older than I can tell. It's a 2C Maglite, but it must be an oldie, since the O-ring that is between the head and body, is actually in the head, not on the body. Never seen that before. Also, the switch is held in by a threaded retainer ring, not the usual c clip, so it has to be a few years old for sure.
It was sent to me by another member and it had some finish marring. I stripped it and it's not polished. I left it more of a brushed finish. I ended up throwing in three XP-G2 S2 2B leds on copper stars, onto a copper heat sink, (disc and copper fitting style), and used a used SRK reflector that is OP finish. The driver was a Q-lite and I removed all the 7135 chips and put them on a slave board, with some more 7135 chips, so there's 16x7135 chips on it. I also changed the MCU to a DrJones lumodrv one. The switch is now a momentary SMD switch on top of the old switch housing. It takes one 18650 and comes with a sleeve and a spacer for it. You can use protected or unprotected cells, but a protected with a button top might be a little too tight. The tail cap threads are not all that good and neither are the body threads for the tail cap. Keep them greased heavily and when you remove/replace the tail cap, you might want to be gentle with it. Can't do much about that, since both threads are getting old, replacing the tail cap won't do much for it. Just keep it greased.
Hey, it's a freebie ok?
Anyone who is a member of BLF since on or before 12/15/2014 can enter the giveaway. Your post# is your lucky number. One entry per member.
I will draw 1 winner on 12/24/2014, sometime during that 24 hour period. I use Random.org for the drawing.
Good luck
Reserved
I shall be unlucky number 1
If 1 is unlucky, is 2 twice as unlucky?
Three if I’m fast enough!
Edit: 4 will do, Thanks!
inBort
BTW how did you strip it?
In, Monanoke
Count me IN ! Thanks OL> four winners for one light??? I must be missing sumpin...
I like that bare aluminum finish, I’m in!
In please. Thanks, and Merry CHRISTmas, O-L.
NOT IN, if #10 is picked please pick again, O-L can guess why :wink:
I just wanted to thank Old-Lumens for his generosity over the years.
Thank you :party:
Cheers David
i am in for that beauty!
Lucky 12 I be. Please count me in.
I’m in
In, thanks!
Greased Lightning or most caustic drain cleaners, like draino.
Cut and paste just doesn’t work for me.
Corrected.
Thanks OL! Merry Christmas and count me in.
Thanks for the giveaway, count me in.
Count me IN :bigsmile:
Thanks OL
