Have any of you used wire glue to connect a copper part to aluminum? I’m putting a larger driver in a light and I made a copper sleeve that fits it’s perfect. I know that I can crimp it to keep it in place but I would like something to create a stronger bond that still conducts electricity. Does wire glue stick to aluminum and copper and have a good bond?
Tried some a couple years back, not that great, it makes brittle connection and I suspect has much higher resistance than soldering. I only used it a few times on low current though.
Though for your application with tight metal-metal connection, it probably works alright as adhesive and gap filler.
Thanks for the info. I run into this kind of problem every so often and I’m sure others do as well. I wonder if there is an epoxy out there that is super conductive? There must be some someplace.
I've not used that exact product, but I used that conductive paint used to repair broken car rear-window defrost grids once... I used it to repair a broken trace on a video card with good results. I was actually shocked that it worked.
That’s cool. I was actually on an automotive forum the other day and a guy was talking about doing the same thing, that was actually what got me thinking about it.
