Test/Review of AWT IMR18490 1200mAh (Yellow)
7 posts / 0 new
HKJ
HKJ's picture
Last seen: 5 hours 36 min ago
DSC_6746
Official specifications:
  • Nominal Voltage : 3.7V
  • Capacity: 1100mAh
  • Lowest Discharge Voltage: 2.50V
  • Standard Charge: CC/CV ( max. charging rate 16.5A )
  • Cycle Life: > 500 cycles
  • Max. continuous discharge rate: 5C
AWT%20IMR18490%201200mAh%20(Yellow)-info
This is a high current 18490 cell (18490 is basically the same as 18500)
DSC_6745
DSC_6747 DSC_6748
DSC_6749
DSC_6750
AWT%20IMR18490%201200mAh%20(Yellow)-Capacity
The two cells has an acceptable match in capacity. The capacity is as specified and fairly stable even at 15A, i.e. the cell is good at high current.
AWT%20IMR18490%201200mAh%20(Yellow)-CapacityTimeHours
AWT%20IMR18490%201200mAh%20(Yellow)-Energy
AWT%20IMR18490%201200mAh%20(Yellow)-PowerLoadTime
AWT%20IMR18490%201200mAh%20(Yellow)-TripCurrent
AWT%20IMR18490%201200mAh%20(Yellow)-Charge
Conclusion
The battery has very good high current performance and capacity is also fine for the current rating.
Notes and links
The batteries was supplied by AWT for a review.
Compare to 18650 and other batteries
Chicken Drumstick
Last seen: 10 months 1 week ago
Thanks for the review. Wished there where more torches that used this size though.
2 × 18500 or 3 × 18500 would make for a nice compact high powered MT-G2 or XM-L2 torch.
TheGloriousTachikoma
Last seen: 5 years 11 months ago
4×18500 = 3×18650
HKJ
HKJ's picture
TheGloriousTachikoma wrote:
4x18500 = 3x18650
Usual the most interesting calculation is: 2x18500 = 3xCR123 (Both length and voltage match)
Chicken Drumstick
4×18500 = 3×18650
Yeah but if you want something compact with sustained high amp draw and a stable forward voltage, or just a higher forward voltage as in the case of the MT-G2, then I think these would work really well.
A single 18650 won’t power an MT-G2 and if you want to maintain a high (above 4amp) constant output, most 18650’s will not maintain the voltage, even more so with these newer higher vf XM-L2’s that are appearing.
Your only options are 2 × 18350 and woefully low mAh or 2 × 18650 and massively bigger.
2 × 18500 however would only be the length of a Mini Maglite just slightly fatter but with considerably more capacity than 18350’s.
hank
hank's picture
Last seen: 3 days 30 min ago
Maybe not worth the trouble, but it’d be a handy option for the earthquake box, to be able to use CR123 primaries.
Chicken Drumstick
Anyone know where you can get these from?
I’ve found these on eBay but they are listed and labelled as 18500 not 18490. Anyone know if they are actually the same thing?
http://pages.ebay.com/link/?nav=item.view&alt=web&id=111562450595
