Code now public! BLF A6 FET+7135 Light. Short 18350 tubes and Unanodized Lights Available
6278 posts / 0 new
keengeorge
xzel87 wrote:
I sent a complaint to banggood regarding my low mode problem I hope they send me a fixed head....it's really unusable as an EDC as it is as my most used modes are the low modes...Turbo is just for wow factor.
Btw the email in OP heyanqing1@banggood.com is no longer reachable.
What do you mean by not reachable?
xzel87
mailbox does not exist error
Error Screenshot
keengeorge
Error Screenshot
I suggest you try sending it again, as it's most likely a temporary issue with Banggood's server.  Smile
raccoon city
raccoon city's picture
Last seen: 1 hour 38 min ago
Location: Palm Desert CA ~ West Coast is the best coast
Error Screenshot
It looks like the correct email address is:
not
heyanging1@banggood.com
Wink
xzel87
Damn I need to retest my eyes, I think my degree went up....I swear I see that as a "q"
lionheart_2281
lionheart_2281's picture
Last seen: 9 hours 23 min ago
xzel87 wrote:
Damn I need to retest my eyes, I think my degree went up….I swear I see that as a “q”
That’s why I copy / paste email addresses and any other important details, so if it’s wrong it’s not my fault!
keengeorge
lionheart_2281 wrote:
That's why I copy / paste email addresses and any other important details, so if it's wrong it's not my fault!
That's why I always copy & paste too  Wink
DEL
DEL's picture
Last seen: 4 years 5 months ago
ToyKeeper wrote:
So, if I understand correctly, the X7R class capacitor reduces the temperature sensitivity but does not eliminate it entirely?
I’m not sure if a capacitor 1/20th the size would work or not. The driver measures voltage, not capacity, so it should depend on whether the capacitor can handle the same voltage with a similar discharge curve.
I have a firmware already made which blinks out the raw ADC value for the offtime capacitor. I use it for calibrating timing. I would imagine it should also work for a totally different capacitor, or at least would reveal whether it discharges in a manner which is useful for this purpose.
The ‘R’ in X7R signifies that its specified uF value varies +/- 15% over its specified temperature range. Worst case will be at 125 C, where it will be ~15% less than at 25 C. This should be good enough for what we are doing.
Some better curves and info here:
http://product.tdk.com/capacitor/mlcc/en/faq/faq00035.html
Going with a capacitor that is 1/20 uF (to accommodate C0G type), the voltage value read at boot up will be 1/20 of what you would read with a 1 uF.
DEL
DEL's picture
ToyKeeper wrote:
We managed to greatly reduce this effect, but couldn’t eliminate it entirely. So, when it’s hot, a “medium” press is faster than usual. And if you put the light in a freezer, a medium press will be slower than usual. In my tests, the timing changes by a factor of about 2, which is way better than the factor-of-10 sensitivity it originally had.
If we assume that most of this effect is due to the temperature (in)stability of the OTC, this indicates that we have an xxU capacitor. Not a good choice for this application. ‘U’ would be -56% capacity at its upper temperature rating. If it is a x5V in addition, this temperature is only 85 C.
If I have time this weekend, I will remove an OTC and put it on a meter while heating it. Or just swap out with an X7R and try to compare with an unmodified light.
fatboy
Last seen: 15 min 49 sec ago
Are they checking QC? Banggood keeps moving restock date back It’s now october 2
tkd15
Last seen: 2 years 9 months ago
Finally got my 25R cell to work with my 3D. Turbo is impressively bright, UI is great, the light works flawlessly. Thanks to all who make this GB happen, really appreciate all your hard work.
DavidEF
DavidEF's picture
Last seen: 7 months 4 days ago
If so, I’d count that as a good thing! 8)
- The YKK Philosophy
BLightSam
Last seen: 3 years 7 months ago
Wonder if that also mean further delays in sending out replacements for the defective parts.
SciFiFreak
Last seen: 4 days 22 hours ago
dthoang wrote:
This is the part that I used in my driver builds. I never noticed any issues with mode changing when hot.
This is the one I’ve used for all my builds and I notice mode change problems when hot. It’s also the part specified in the original driver build thread.
Tom E
Tom E's picture
DEL wrote:
ToyKeeper wrote:
We managed to greatly reduce this effect, but couldn't eliminate it entirely. So, when it's hot, a "medium" press is faster than usual. And if you put the light in a freezer, a medium press will be slower than usual. In my tests, the timing changes by a factor of about 2, which is way better than the factor-of-10 sensitivity it originally had.
If we assume that most of this effect is due to the temperature (in)stability of the OTC, this indicates that we have an xxU capacitor. Not a good choice for this application. 'U' would be -56% capacity at its upper temperature rating. If it is a x5V in addition, this temperature is only 85 C. If I have time this weekend, I will remove an OTC and put it on a meter while heating it. Or just swap out with an X7R and try to compare with an unmodified light.
I've been using only X7R 1 uF caps for all my OTC driver build/mods and I still see the temperature related problems in most of the lights I modded using it. Now I did buy the caps off of eBay at the time, so no guarantees I got caps as labeled. I suspect though they won't make much a difference, but it would be interesting to try. In my next DigiKey or Mouser order, I'll definitely will be ordering some 0603's and 0805's - cheap enough.
The inconsistencies with the OTC's is some of the reason why I much prefer e-switch's now -- you have true control of timing under the MCU. I've also used the NOINIT (brown out) method as well, but still seems to have some timing inconsistencies.
Joat
Last seen: 1 year 8 months ago
The circuit is the cap and the resistance it bleeds down through, if the resistance goes down with heat the timing will get shorter also.
BLightSam
What was not working with 25R and what did you do to fix it?
chuckhov
Last seen: 3 years 11 months ago
I actually think that they are!
Obviously the first batch was rushed, and now we are seeing the spotty QC as a result of it.
I am down for four, but have thus far only ordered one. – Received (3D), and I am very happy with it – But some it seems are not so lucky…
I just thought that one would be enough to play with to start, and wanted to see how things would go before I order the other three. – I think that was a good decision.
Many, Many thanks to all involved for Continuously working to make this GB Right! – It can’t be all that much fun Sad
Thank you,
-Chuck
Mitko
Mitko's picture
I ordered several aditional 3d binned ones:
Well, this aint a XLP 3D but smth like 3C, kinda disappointing- the left is IOS V6 3D
1A ones were just fine though
One of them dont have a moon mode, just a blank space, i will reflash the driver but for someone it could be an issue
Many thanks to the TK for that lovely all arround firmware! And the OP ofc
bugsy36
bugsy36's picture
Last seen: 12 months 1 day ago
Mitko - If a reflash brings back the moon...please let us know. Actually if you could directly flash TK's UI and tell us that would be a big help to all.
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
Mitko
Mitko's picture
Will do that- its actualy a black space instead of the moon mode, only on one of 3 lights, maybe a glitch or smth- i usualy get glitches like that when i overhear the a13 while soldering
ToyKeeper
ToyKeeper's picture
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
FWIW, the color temperature will change depending on what mode it’s in. This is a side effect of having two power channels at very different amps.
So, it can be tricky to compare the tint against other lights unless they run at similar power levels and have a similar type of AR coating on their lenses.
SmokinH
Last seen: 3 years 8 months ago
I’ve had a time to look at my 3 lights I’ve ordered. One of the lights I have to tighten as tight as I can to get it to work. If I put this tail cap on the other lights they do not work at all unless I put a shim the switch. I’m not sure if I received 2 short body tubes or 1 short tail cap. The length of my body tubes are 2.732, 2.723, and 2.730. I also measured the tail caps from the thumb indent to the end and tail cap that is giving me problems is a little shorter. The tail cap measurements are .998, 1.000, and 1.000. The tail cap that measures .998 only works when the 2.732 body tube, but i have to crank the tail cap as tight as I can to get the light to work and have it not flicker.
chuckhov
That really sounds like a tube issue to me – Too short.
Thanks,
-Chuck
hank
hank's picture
Last seen: 3 weeks 3 days ago
Quote:
body tubes are 2.732, 2.723, and 2.730 … … tail cap measurements are .998, 1.000, and 1.000. The tail cap that measures .998 only works when the 2.732 body tube, but i have to crank the tail cap as tight as I can
That’s a perfect illustration why having a production that respects and understands specified tight tolerances matters.
There you have one that is less than .01 too short on one part, and less than .01 too long on the other piece, and — put them together, and hey, this one sample works fine.
Checking one product fails to detect the problem — too much variation around the spec — because some combinations of parts will average out to working properly.
Too much on one part, too little on the other, result — it lights up if you happen to get those pieces put together.
That’s why taking a real sample of the products — not just one, not just one they know works, definitely not one prepared to show as a “sample” — is what you need to check them.
Measure, write down the result, find out how variable the work is.
Given sloppy work with overmuch variability, the workaround — assemblers fishing through the bins looking for a slightly longer tailcap to go on a slightly shorter body tube, trying to make the damn thing light up — isn’t the right fix.
Want to build a modern nation that doesn’t melt down and fall apart?
Here’s how: https://www.google.com/search?q=production+tolerance+variability+specifi...
SmokinH
What are other people’s tubes measured at? My issue seems to be that one of my tail caps. Unless all 3 of my body tubes are too short. If someone just ordered 1 light then this issue may be missed. The only reason I noticed it was because I ordered more then 1 light. I was wondering why one of my lights I had to crank the tail cap as tight as I could to make the light work. When I put the tail cap in the other lights the only way I could get it to work was by putting in a paperclip shim in the tail cap. If people order the 18350 tube the light may not work, but it works with their 18650 tube.
chuckhov
SmokinH wrote:
What are other people’s tubes measured at? My issue seems to be that one of my tail caps. Unless all 3 of my body tubes are too short. If this is an issue with the tail cap then some of the 18350 tubes my not work even though the original 18650 light appears to work properly.
Re the 18350 – You have made a very good point.
Thanks!
-Chuck
SmokinH
What is the proper length and tolerance for body tube suppose to be?
chouster
Last seen: 1 year 4 months ago
bugsy36 wrote:
Mitko – If a reflash brings back the moon…please let us know. Actually if you could directly flash TK’s UI and tell us that would be a big help to all.
Hi bugsy36 and Mitko.
I don’t know if Mitko has the same issue like me and some others. If so, the bike flasher for example wouldn’t work as it should (only flashing, no continiuous “background” light”), and the battcheck mode wouldn’t function, just like the moon mode. If that’s the case it’s very likely a problem with the 7135 solder joints. When I received my light and experienced that issue, my first thought was I am going to reflash it. TK asked for some macro shots of the driver and when I posted some, DEL suggested that the 7135 solder joints could be bad by the looks of it. And he was right. With that kind of issue, reflashing the driver wouldn’t do anything to get rid of that.
cavesprings
Last seen: 3 years 3 months ago
Has anybody measured the tail cap threads on the tube,from the end of the threads to where the tailcap seats? Seems like if the whole tube was too short it would be noticeable. The tailcap would be hard to twist on because of the springs compressing and there would be a gap between the body and tailcap.
When I put a unprotected battery in mine I can barely feel the springs compress, I tried a protected battery and I can feel the springs compressing more but the tailcap is still easy to put on.
All 4 that I got work great, but I don't have anything to measure mine to post for comparison.
