help with choosing right one
I have small problem on deciding which light should i buy... First I want it to have one 18650 cell. Secund thing is 3or5 modes. And third thing is i want to make thrower from it, not as soon as i get it, but after some time I would like to have thrower from same light. here are some of the lights i was thinking of:
http://kaidomain.com/ProductDetails.aspx?ProductId=11243
or one of these two from MF https://budgetlightforum.com/t/-/3225
And do you have any suggestions how to make thrower from some of these lights? thx for advice
can this lens help with throw, and can I install it on any of these lihgts?
http://www.dealextreme.com/p/glass-optics-for-flashlights-28mm-5297
Bigger head/reflector makes the light a thrower, combination of big head and XM-L led will give you good throw and bright spill.
yaeh I know thats how it works...but has anyone tryed new bigger head on these lights??And with wich head i can replace this original one?
I actually don't know if there is a head replacement for the ultrafire 501b, if you want throw better get these or anything similar
UltraFire X2 CREE XML T6 5-Mode 700lm Memory LED Flashlight (1*18650) SKU: S010164
KD C8 CREE XML T6 1000 Lumen 5-Mode LED Flashlight (1*18650) SKU: S009844
If you want an inexpensive floodlight get this.
If you want a thrower then get this.
If you want something which is quite good at both then get this.
It is not really possible to convert an XM-L into a really good thrower at a later date.
You can use the 28mm optic you referenced from DX along with a blacked-out reflector to convert the WF-501b into a thower. I did so with my XRE-R2 501b with good results. I'm not certain how the XM-L lamps would do though... I would imagine you would get a much larger hotspot with reduced thow but I 've never tried to see how it would work.
For throw you aren't going to beat a XR-E with aspheric. The hotspot will be bigger with a XM-L but the XR-E will throw further.
With most of those lights mentioned you can probably just replace the front lens with the aspheric. It's always a bit of a gamble with various lights as you never know if the focal length will be just right until you try it.
As was mentioned paint out the reflector. If you really want a clean beam also paint out the Cree ring.
Some folks also say mask off all but the center of the aspheric lens with black tape. I've also had another idea but I've not tried it yet. Its effectively an aspheric lens with frosted glass except for the center. The way I intend to try to achieve the effect is with the vinyl used by shop signmakers; the type that when it is stuck to windows it makes the glass translucent/frosted in appearance. I suspect that this may smooth out the problem artifacts in the beam.
thats what I was thinking of. Because I dont need throw now, but later on i may need to get as much throw as i can without giving extra 20-30 $...thats way Im trying to get best combo with some flood flashlight and lens or even head replacment. But I still dont know if there is some head for replacment for it.
And thx for advices anyway they were usefu
You can always buy this one...
http://www.manafont.com/product_info.php/ultrafire-uf009-supreme-dual-led-flood-recoil-thrower-4mode-memory-led-flashlight-118650-p-5196
... and then hope that you get a better unit than the one reviewed here:
https://budgetlightforum.com/t/-/2720
Most thrower lights with XRE leds have very narrow beam making the lower modes unusable, I know because I have several thrower lights like the Kaidomain RQ and Solarforce Skyline 1, if you want a do it all light it has to have the balance between flood and throw which only can be achieved by XM-L and big reflector or a Flood to throw lights(aspherics).
how about the skyray stl-v2 both 3 and 5 mode with a twist of the body. really good throw.
This one has more throw than flood https://budgetlightforum.com/t/-/2405 It can be had with a 2800 Mh driver by going through Wendy (PM) It has enough spill to make it a good duel purpose light.
