Test/Review of AWT IMR14500 600mAh (Yellow)
Official specifications:
  • Model: 14500
  • Material: Lithium cobalt oxide
  • Nominal voltage: 3.7V
  • Charge limited voltage: 4.2V
  • Rated capacity: 600mAh
  • Cycle life: Over 1000 cycles
  • Standard charge time: 3-5hrs
  • Fast charge time: 2-5hrs
  • Charge temperature: 0°C~+40°C
  • Discharge time:-20°C~+60°C
A unprotected high current LiIon battery in AA size.
The cells are not equal, this means they are best used on at a time, do not use them in series. Their high current performance is fairly good, there is no problem with 5A.
Conclusion
Fairly good high current performance, but I do not like the difference between the two cells.
Notes and links
The batteries was supplied by AWT for a review.
Comparison to other LiIon batteries
