Review TrustFire TR-3T6 Triple XM-L T6 5-Modes Memory LED Flashlight (3x18650)
748 posts / 0 new
Chicago X
Chicago X's picture
Last seen: 7 years 12 months ago
2100 wrote:
...All in all i have purchased 7pcs of various triple XM-Ls now.  I think I have over-measured all of them...time to enjoy now.  LOL!
Surprised
I bet you could mount them in a panel and give those searchlights a run for their money !!!
TK70 in the middle, 3 DRYs around the edge, and a few thinner TFs and SRs to fill in the spaces....BAM !
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
benckie
benckie's picture
Last seen: 8 years 2 months ago
sb56637 wrote:
And can somebody please confirm that the 3x18650 version in shorty mode works well with two regular 18650's? And would two XTAR 18700 cells fit?
Thanks!
Yes the TR-3T6 3 x 18650 model will run either 2 x 18650 or 3 x 18650's not sure about 18700 as I don't have any but the extra extention tube to run 3 x 18650's is made from two tubes about 50 mm or 2 inches long (once screw down) so you could remove one of them if needed to make it a tad shorter and you can move them around to make it sorter or longer depending on how you put it to gether plus the tail cap has a brass plunger that can take up some of the slack or pressure if that makes sense
sb56637
sb56637's picture
Last seen: 2 days 4 hours ago
Very good, thanks benckie for the reply!
2100
Last seen: 2 years 7 months ago
Thanks!
confirm can for both questions. Spring loaded inside.
sb56637
sb56637's picture
Good, thanks 2100!
2100
sb56637 wrote:
Good, thanks 2100!
Ok to make it even clearer, the 3-cell version of TF-3T6 has 1 main tube + 2 extensions. 1 extension is shorter, and 1 extension is longer.
Those 2-cell version from Sky Ray 3800, 818, 850 and TF-3T6 have 1 main tube + 1 short extension.
All lights with main tube only can take 100mm cells. Eg 2 x 18500, 3 x 18350 (but with 2mm gap). Make sure your light can take 3 cells voltage first. So far I know TF-3T6 and the less popular SBOMZ can do that.
All lights main tube + 1 short extension can take 2 x 18650.
All lights main tube + 1 short extension + 1 long extension can take 3 x 18650.
benckie
benckie's picture
atbglenn wrote:
2100 wrote:
harry25175,
  I have measured the lux throw of the light doing 3 cells and 2 cells.  Both light output are the same.
Have you measured the run time difference between 2 and 3 cells?
I get 50 mins on 2 x trustfire flames and 80 mins on 3 x trustfire flames that's on high with constant running with no dimming. on off running should give more as the rested cells rise back up on voltage.
2100
benckie wrote:
I get 50 mins on 2 x trustfire flames and 80 mins on 3 x trustfire flames that's on high with constant running with no domming. on off running should give more as the rested cells rise back up on voltage. I think I could easily run it for 1 hour on 2 x 18650,s (4800 mAh) and 1.5 hours with 3 x 18650's (7200 mAh) but I have not done the math or run it longer then 80 mins on 3 cells
Guess we can do a guesstimation.  2-cells 2.2A avg you get 70 mins with 2600 cells. Definitely less if you want full regulated output.
3-cells 1.5A avg you get 107 mins with 2600 cells. Definitely less if you want full regulated output.
Try not to push the cells too far, not for more than 15 mins after dimming. You may not be able to recover the cells.
SR3800 with higher draw (eg 2.8A avg) got me exactly 53-54 mins before LV cutoff.
benckie
benckie's picture
I have not run in it dimming yet on my TR-3T6 3 x 18650,s that's why i like being able to run 3 cells (above post i said domming dam iPhone) but on my TR-1200 I've run into dimming with cheap ultrafire greys that only took 900 Mah they have been scraped cause they where crap
2100
Yep Benckie...3-cells, running in low mode of about 300 lumens and yet able to garner 20% more eff than single XM-L, very long times of a couple of hours, it's difficult to run the cells down unless in a real emergency.
Trust me the LEDs definitely won't die on you. Get 1 more additional driver and tailcap/switch (cheap) and you probably have a light for a good couple of years.  Easily till the next Cree new pdts.  Big Smile
benckie
benckie's picture
What's low mode ? Lol It's a keeper I'm glad just about all the parts from the TR-1200 fit (o-rings, bezel, tail cap, glass lense and extention tubes) you could fully rebuild it for $13 usd lol I'm also glad manafont sell the TR-3T6 driver (2 x 18650) for $5.80 as you could keep this torch running for the rest of your life. That's what puts me off some high end lights is replacement parts if any or there price for them.
benckie
benckie's picture
2100 wrote:
sb56637 wrote:
Good, thanks 2100!
All lights main tube + 1 short extension + 1 long extension can take 3x 18650.
That's more clear then my post and the long extention tube can be unscrewed into two parts also it's the same battery tube set up as the TR-1200. When I first got my TR-1200 I disasembled it added some more grease then put it back to gether when using two 18650's it was tight as he'll but three was ok I mixes up the tubes. I'm going to buy another bare TR-1200 host so I can get some spares for my TR-1200 and TR-3T6 and so I can run my TR-3T6 on 8 x AA nimh for some thing to do lol
2100
And yeah...the UCL 52mm lens fits too, if you want that.  LOL!  But DX has 52.8mm lens for 2.50.
8AA is cool for a baseball bat!
benckie
benckie's picture
I was looking at the ucl lense but not sure if it will make a difference I can see
harry25175
harry25175's picture
Last seen: 7 years 10 months ago
I've received tr-3t6 with 2 cells battery. However, when i compared with my Trustfire X8, the 3t6 beam not as bright as x8. Both units were using fresh fully charged panasonic 2900mah batteries.
I was wondering what is the real maximum current can be drawn by 3t6 driver? let say, if 3Amp currents is being drawn, does it mean that 3A will be split into 3 LED (so 1Amp per LED is received)?
Honestly, I was quite disappointing with this 3t6 output beam, it doesnt perform as what i expected. Anyone has compared with x8 before?
benckie
benckie's picture
The TR-3T6 is a buck pluss bost so there should be more then 3 amps going to the LEDs wired in series. The beam should be wider on the TR-3T6 it is a flood light it's more spread out with small reflectors, more of a wall of light, the x8 is more of a thrower with a concertraited focused beam with a single deeper reflector. Because of this you can really compare the beams, one will light up a wide area (wall of light) the other will light up a small area and has more throw and will seam brighter because of this. I've tryed to mention a few times its a wall of light not thrower, a good way to test it with the x 8 is take them both bush walking (forest walking).
Spivey
Last seen: 8 years 3 months ago
Harry25175- are you saying you're dissatisfied with the intensity/brightness of TR-3T6's beam?  Or, with the difference in it's beam vs. the X8?  I'm on the fence as to which of these triples to go with...TF-SR-DRY, etc.
I like the form of the 2 or 3 x 18650 vs. the DRY but am concerned with everyone's stating the Trustfire is visibly dimmer.  I just wanted to ensure I understand your comment.
srtbrazil
srtbrazil's picture
I´ll stick with Benckie. I have both X9 and TR-3T6 and for a walk in the bush the 3T6 is unbeatable (IMHO). A wall of light is a great definition.
2100
Then a C8 Q5 would also be "visibly brighter" than the DRY triple XM-L direct-driven cold white even with UCL lens upgrade.    Smile
You must see what is the usage.  In a walking-the-dog scenario, the DRY would trash a C8 XP-G in illumination that it won't even be funny.  If you are trying to illuminate your fridge or something from 1m away, it might even be painful to look at it the DRY.  But yes, the hotspot of the C8 Q5 is "visibly brighter" if you are doing a light meter reading, or illuminating something that is 200m away.
harry25175
i just received a message from an owner of tr-3t6, he is planning to get sst-90 9A driver and install it on tr-3t6. would it be possible??
Hikelite
Last seen: 3 months 1 day ago
OMG, are you sure that's the plan?
sb56637
sb56637's picture
Should work...
PilotPTK
Last seen: 7 years 4 months ago
Anything is possible.  Getting a 9A Driver in there shouldn't even be that difficult.  Will it make the above mushroom cloud... probably....
I am currently extremely busy with work. Please do not expect a response from me quickly. I will be dropping in as time permits, but the amount of time I can dedicate to responding to topics and PMs is very limited.
harry25175
hahaha.. so i can say that person is trying something useless???
2100
Not really impossible...just a matter of balancing and there still be light though Vf is a bit lower than sst90. I am going to mod my faulty Sr 3800 as i hv many spare drivers. Will work as same form factor. Tf-3t6 driver is too tall unless you bend it. If i have time i will mod the tf-3t6.
Nothing wrong with the 3t6, 1300L OTF and 14-15k
Good heatsinking, no appreciable sag for 5 mins.
harry25175
well, i am waiting for that person report on modifying with sst-90 driver. once i get the report, i will post it
r1derbike
Last seen: 2 years 5 months ago
Mushroom cloud shots! Err...beamshots!
sb56637
sb56637's picture
:bigsmile:
Spivey
Yes, I get that there are different beams due to reflector configuration, etc.
What I wanted to know is if Harry was dissatisfied with the output of the Trustfire TR-3T6.  I'm trying to decide which of the triple xml's to get & read lots of different opinions.  Several are happy with their Sky Ray 3800s's, others had failures, one guy keeps beating the Trustfire drum, one really likes his new Sky Ray 818, etc.  Plus I now see a F.F. single mode triple on DX.
I know you & others are swapping drivers, going DD, etc. but I'm not there yet.  I just want to make the best buying decision, & don't want to buy more than 2 different triples at most.
I'll likely get the new DRY 5A.  Which one of the others would you get?
Anyone else & why?
sb56637
sb56637's picture
Anyone else & why?
My take--
DRY: Too expensive, too ugly, but should be insanely bright and fairly reliable.
Sky Ray: Reliability problems, some complaints of lower brightness, 818 is the best looker of the bunch.
Trustfire: Too ugly, but should be bright and fairly reliable.
