Review TrustFire TR-3T6 Triple XM-L T6 5-Modes Memory LED Flashlight (3x18650)
748 posts / 0 new
benckie
benckie's picture
Last seen: 8 years 2 months ago
well put imo sb
thinking out loud if the TF-3T6 is 2.5 amp and the driver is buck plus bost and the new DRY is claimed 5 amp is that driver buck and i doubt its buck plus bost ? and if people get the full claimed 5 amp draw will it put out much more light to the human eye then the other tripple xm-l,s,or tripple xm-l,s with buck plus bost drivers ? just thinking out loud i have not followed the light or any of its threads as it is not my thing and i have a good reliable tripple so im just thinking out loud.
while thinking out loud, people ask me witch one to get torch or RC, i recomend what i know and what i think is good and what i think will last, in my younger days i would buy any thing and would push every thing to the limmet they stand back when it failed and scratch your head.
like realy cars these days i like a big lazy 6,s then a small high reving 4 bagger and the lazy 6 engine will do many more miles but it might not have the same top end as the 4 banger engine, also the more common lazy big 6 is the one has the most spare parts forsale and the best price thats the most common....
i like the trustfire brand i like the constant current drivers as they seam to last long and can be ran for longer if im the guy who keeps harping on about the trustfire,s as Sprivey puts it Laughingi will say this to him, please buy the fandy fire one mode thats a drop in and it will do poorly with heat and will not handle heat or long runs, well not with atlest modification imoh, or buy the fry ray and beat that drum how its a great torch if they are like the one ive seen personaly and the countless hours of threads ive read on them before making up my mind witch one to get.
i also like manafont, but you dont have to buy from there, you dont have to read or participate in my threads  please feel free to report any of my threads or post to the mod,s as to me this is just a internet forum and if your not sure witch light to buy google is your friend, good thing about budget lights or none budget lights there is that many around to suit just about any one Smile
Hikelite
Last seen: 3 months 1 day ago
The new Driver is just a different arrangement of modes + medium, and it's direct drive @ 5A on Turbo.  It will not put put the double from 2.5A. simply because the XM-l @ 2.5A outputs about 800L and @5A outputs 970L. And there's the batteries, are they capable of that, not all of them. And there's the heat.
Mentioning about human eye is useless in my opinion, because you could easily argue about this on all kind of output levels, on all kind of flashlights.
benckie
benckie's picture
cheers so its no big deal then just a DD
i agree the human eye is usless and so are the torches if you use them against a wall.
sb56637
sb56637's picture
Last seen: 2 days 6 hours ago
And what's the scoop on using the DRY with protected cells? And what about using it with only 2 cells inserted?
benckie
benckie's picture
after 2 mins of resurch the dry has a battery holder for 3 x 18650,s it will not work with 2 x 18650 unless you solder a bridge wire across the battery holder but that will depend if the torch will handle the lower voltage as the battery holder is wired in series so 3 x 18650,s is 12.6v and 2 x 18650,s is 8.4v.
since it has a direct drive driver (DD) i feel it might not be as bright running on two 18650 as direct driver torches drop in brightness as the battery voltage goes down.
if the torch does have the full 5 amp draw run time on 2 x 18650,s will be very short around 30 mins and running it on the standard 3 x 18650 setup will be around 45 mins maxium, you will need very good batteries to do this.
running it on protected cell,s could be an issue if you use cheap cells if the new dry draws 5 amps as battery protection might kick in and this will depend of where you get the cells from.
i use these they dont drip and no form of over discharge kicks in even with 5 amp busts Protected TrustFire 18650 but the same batteries from DX trip....
since the dry is direct drive you would be better off running it with 3 batteries or you going to lose brightness it does not have a buck + bost driver with constant current like the TR-3T6 that will maintain constant brightness untill the batteries have past there limmet whether you're running 2 batteries or 3 batteries.
becuase of this the new 5 amp dry at 5 amp is going to get pritty dam hot also so it will be a short run torch, just my thoughts from a quick bit of reasurch on this forum.
sb56637
sb56637's picture
Thanks benckie for the reply!
Hikelite
Initially there were these two drivers.
High Low Strobe. High being direct drive with a max of 4A
Low Medium High Strobe. Which theoretically had to be regulated @ 3A. In fact it's direct drive even on High where you have PWM, Guys reported 2A- 2.2A .
Now there's this L-M-H-S with 3A max. It's not known if it's the same driver with direct driver on high as above, the supposedly regulated 3A.
And there the  L-M-H-Turbo with 5A max.
Even running with Xtar's 2600 the protection could kick in @5A, on the other hand few cells are capable of that current draw. Anyway everything is a speculation for the moment.
We can speculate as much as we want, that running on 2 x18650 will not be as bright as 3 cells. From my initial tests it seems it can barely give any light with 2 x 18650, maybe 100L.
For the moment I do not like what drivers DRY is using. Great potential but there are actually 5 drivers out there.
I'll have to test the my DRY.
FX-32
FX-32's picture
Last seen: 5 years 3 weeks ago
I'm interested on giving a try to this flashlight. Have anybody measured the current from the LEDs (not tailcap) at high mode?
Another interesting thing for me, is to compare this TR-3T6 with the DRY 3xT6 (throw, spill, beamshots).
benckie
benckie's picture
i have not measured the current from the led,s yet i would have to disasemble the screw in for that, but at a guess since the driver is buck + bost and the led,s are in series i would gues they are driven at 3 amps or very close to that so each led would be getting the same cause they are wired in series.
comparing to c8,s jetbeam bc40 thats around 710 lumens and some other trustfires around 800 lumens the TR-3T6 is an eazy 3 + x brighter and since the TR=3T6 driver is constant current and digitaly regulated it will draw a steady current and maintain full brightness and because of the constant current it will run cooler and should last a long time due to not over heating or scaling up in current draw as the batteries voltage drops straing the driver.
once the batteries have ran past there limmet the torch will drop out of regulation, constant current and the torch will dim, this is where you turn it off and replace the batteries, but i have not ran into dimming with runs to 50 mins on 2 x 18650,s and 80 mins on 3 x 18650,s and i predict an easy 60 mins runs on 2 x 18650,s and 1.5 hours on 3 x 18650,s using my cheap Protected TrustFires
i took my TR-1200 and my TR-3T6 camping in the small wyvern nature reserve last friday we ran the torches on and off for most of the night gathering fire wood and checking the nets along the river i would say an easy 1 + hour of off and on running and when i got home i wacked the batteries on ballance charge the 3 from the TR-3T6 where 3.83v and the 3 from TR-1200 3.91v since the protection on the trustfire flames is ment to kick in at 2.75v i could of ran the torches much much longer (but i can not get any over discharge protectiong to kick in so i go by time used normaly or wait for dimming but i have not seen any dimming on the TR-3T6 yet)
before i left i did a quick test with a c8, ultrafire, jetbeam bc40 and my tr-1200 the beam on the jetbeam was brighter on the wall and out in the feild the beam of the tr-1200 was brighter and more focused at a distance of 2 meters on a tree as it will throw 300 + yards or 300 meters with its q5 emmiters but the TR-3T6 is an easy 3 x + brighter and with massive spill, while walking along the river with my TR-1200 that has good spill and a nice white light my wife walked up behind me using the TR-3T6 and totaly drowned me in light and the spill over took the spill on the TR-1200.
the TR-3T6 would have to be my first choice when i go into the bush (forrest) because of its wall of light its massive spill makes it a great exploring, walking light you can see every thing infront of you left right and straight ahead to 150 meters but my second choice is the tr-1200 due to its good spill so you can see whats infront of you but its ability to throw a great distance for spotting animails at a distance and its more concertated beam looking into clear water another reason i pick both of them over my other lights is the ability to run 3 x 18650,s it makes them a bit longer or bulky but the increased run time by 50 % is much welcomed by me.
my camping trip with my faimly was awsome im so glad i found bright high powered led torches and i dont have to use my old over priced dolphin or maglite torches that are usless in stock form and not very bright on rechargabiles.
selphb
selphb's picture
Last seen: 9 years 6 months ago
benckie
benckie's picture
I don't think so as the tail cap looks more like a c8 then a TR-3t6 or TR-1200 but my trustfire USA should be here with in the next week so I'll let you know
selphb
selphb's picture
Thanks!!!
benckie
benckie's picture
selphb wrote:
will the extender work with a TrustFire USA 168???
http://www.manafont.com/product_info.php/trustfire-usa168-q5-3mode-memory-led-flashlight-118650-p-5494
no i tryed the extenders from my TR-1200 and TR-3T6 (same thing) and it was a no go sorry
benckie
benckie's picture
well ive been telling people the TR-3T6 has a throw of around 150 meters as its been hard to do beam shots and test the range of the light in the forrest as the wall of light it put,s out, but last weekend when we whent camping it made me think it had more throw the i have said, so we took it over to my old man,s who lives on a cattle farm to do some measured range testing with some other lights and i was blown away.
my actual measured range test
we test my TR-3T6 3 x 18650 on two trustfire flame batteries with a caip cap current draw reading of 2.7 amp's
250 meters (273 yards or 820 feet) of good usible throw with massive spill and i mean massive spill it basicly lit up the whole feild during the test.
300 meters (328 yards or 984 feet) of throw.
i was blown away by this i has under estimated the throw of this light due to the size of the reflectors and them being xm-l,s but xm-l,s seam to throw dam well also.
FX-32
FX-32's picture
Thanks benckie!
I will buy it Laughing
scheven_architect
Last seen: 3 years 6 months ago
250-300m of throw, although it seems to have the same reflectors. I don't think my DRY throws that far but maybe in a pitch black environment it will Smile
2100
Last seen: 2 years 7 months ago
Your DRY with the turbo mode even with neutral white emitters (-15% for T4 5A3) will definitely outthrow the the 3T6 with CW, by quite a lot.
LEDMatt
Last seen: 7 years 8 months ago
These lights are really fun to play around with. I ended up getting one of these as a gift.
I wanted to ask: Did anyone experience some issues with the modes? After running on high for 30 seconds, the rest of the modes don't work (goes black). When switching to medium after it ran for 30 seconds, it will go black. If you leave it "on" medium it will kick back on in about 10 seconds. Cleaned and lubed it pretty good. I re-heated the solder on the outer-spring part of the module but that had no effect. No idea what the next step is.
Can anyone provide any input?
Otherwise, it's a really fun light. It feels heavier than my Sky-ray drop-in I purchased earlier. It's a tad dimmer also as others have mentioned. I'm probably happier with my SR just because it held up very well so far.
regal
Last seen: 6 years 9 months ago
Is the UCL lens a worthwhile upgrade?
I intend on keeping this thing,  its probably the plateau for performance/technology/cost for a long while.  Its a long term "keeper".
atbglenn
atbglenn's picture
Last seen: 1 year 11 months ago
No issues with mine. Where did you get yours? There appears to be some fakes on ebay
Boycott Nike
benckie
benckie's picture
I think so it's only a few bucks
LEDMatt
atbglenn
I purchased mine from Manafont.com SKU: 8009 (the three 18650 version). Since I started reading this forum I stopped trusting other sellers. Online chat told me to E-mail them. Kind of worried about return shipping.
It's a very interesting issue. Could be as simple as a cold solder joint inside; however, it still doesn't make since why high works so solidly in that case. I'll see what Manafont says first before I go tearing into the driver. I could just order a new driver board but then I don't think it could accept 11.1 volts.
benckie
benckie's picture
have a chat to Jim @ manafont as mine will run fine in any mode and will do 60 min runs on high and has been use for many hours now, sounds like yours might be playing up, im sure you have tryed other batteries ive had some cheapies cause me issue,s with lights cutting out before.
Hikelite
Dimitrioptimus wrote:
Hello brothers & friends I am new in the World of Flashlights & have no experience in this field.
Actually I bought TR-1200 but with 2*18650 trustfire flames it was only drawing 991mA so I returned it to Dx and got the refund.
By reading to this blog I find TR-3T6 to be amazing so I would buy it soon but I have a question which are as follows:-
1>By reading to this blog it clearly states that it is a flood light and don't have a good throw,so is it possible to use a aspherical optic to convert it into throw mode momentarily or with a moded housing so that by pushing the optics back and forth ,zoom to throw mode can attained.
2>I saw a video (ie;     http://www.youtube.com/watch?v=W6scgin_UKc    ) of a flash light Fandyfire which has also 3T6(XML) emitter just like TR-3T6,in this video (lux meter or Lumen meter I don't know exactly what it was)it was showing the same value as TrustFire X6 with SST-90 emmiter,so probably TR-3T6 can do it also if with the same driver,so my question is are the lumen output of both X6 and the flashlights with 3T6 emitters & with Fandyfire type driver have the same lumen output as TR-X6 with SST-90 bin.
Thankx in advance Laughing
Is that a good way to measure? Less than 1m distance to the meter ?
Dimitrioptimus
Last seen: 8 years 4 months ago
I have chosen some optics from DX
SKU 13569
SKU 13618
SKU 43044
plz suggest which will be best for concentrated beam for using with TR3T6
Dimitrioptimus
There were some errors thatsy deleted my post instead Read the REPLY post of "Hikelite"(the grey portion) posted on Wed, 10/05/2011 - 21:39 post number #204.In conjunction also read post no #205 of mine.
Plz assist that if it is possible or not.
Dimitrioptimus
 By reading to your reply post no #204,probably ur asking with referernce to the linked video of mine,even I don't have the clue,it was just that I found the 3T6 video on Youtube & for query pupose I posted,but I noticed some thing in the video actually the total corona section is not falling in the sensor so the actual lumen measure can get increased if "Less than 1m distance to the meter" is set.
benckie
benckie's picture
no to mention the 3T6 light you mention is not the same light we have been talking about on here, its a drop in not the TR-3T6 screw in module to diffrent brands with two diffrent styles of drop in.
the TR-3T6 made by trustfire with the screw in module will throw 150 + meters depending of your conditions and what you call usible throw, mine to me will throw good usable light to 250 meters while lighting up the whole feild.
my opion is the 3T6 light you linked if your video will not handle long runs or transfer heat to well or as good as the TR-3T6 due to less contact erea of the drop in and not directly contacting the head.
i sugest reading the whole thread
priceangels
Last seen: 9 years 8 months ago
hi ,it is really nice one ,how can i get one ?
benckie
benckie's picture
