Review TrustFire TR-3T6 Triple XM-L T6 5-Modes Memory LED Flashlight (3x18650)
748 posts / 0 new
Dimitrioptimus
Last seen: 8 years 4 months ago
Actually I had 2 primary questions & its not related to run times or heat management though they are very important
1>Was confused thatsy asked,if with the help of optics better throw can be attained with Tr3T6
which I chose from Deal Extreme for the best match\fit
ie;SKU 13569
SKU 13618
SKU 43044
plz suggest
2>I meant whether TR-3t6 has same luminous output as Tr-X6 ,actually the linked video showed that the luminous values for X6 & the one with 3t6 emitter which are same as same as in TR3t6 have relatively same light output.
so anyone...
JohnnyMac
JohnnyMac's picture
Dimitrioptimus wrote:
I have chosen some optics from DX
SKU 13569
SKU 13618
SKU 43044
plz suggest which will be best for concentrated beam for using with TR3T6
None of them! Aspheric lenses are designed to focus a single, centered beam. With a triple LED light such as this none of the three beams will be focused and you would severely screw up the output and only make it worse.
The only way would be to use a single aspheric lens for each LED and figure out how to mount all three in the head at the proper focus distance. Even if a single lens like the ones linked could work the focal length would be all wrong as the reflectors on this light are too shallow.
Dimitrioptimus
thankx JohnnyMac it was helpful,saved me from purchasing the optics
JohnnyMac
JohnnyMac's picture
You are welcome. I'd hate to see you waste your time & money and get excited for nothing. Wink
Don
Don's picture
Last seen: 8 months 23 hours ago
regal wrote:
Is the UCL lens a worthwhile upgrade?
I intend on keeping this thing,  its probably the plateau for performance/technology/cost for a long while.  Its a long term "keeper".
Can't say for sure for this light, but I've seen 10-15% using the cheap KD voted lenses for P60 lights. If they have one in your size it'll be hugely cheaper than the UCL ones.
Actually I've seen way more than 15% but that was comparing a dirty glass lens of some age with a brand new coated one. I'd reckon you can expect the difference between one Cree bin and the next - 7-10%.
Whether that is worth it to you is another matter.
The numbers from my light tests are always to be found here.
https://spreadsheets.google.com/ccc?key=0ApkFM37n_QnRdDU5MDNzOURjYllmZHI...
asok
Last seen: 9 years 7 months ago
Has anybody tried this with 4xCR123A? The voltage shouldn't be too high once you get some load on the batteries (but don't blame me if it the driver burns)... CR123As would provide a nice backup and be always usable even if you take the flashlight out of the glovebox after two years of no use and in -30C temperature. And you would have a wall of light available to scare away the wolves Wink
Dimitrioptimus
Can anyone tell the size of the diameter of single refector in TR3T6.
benckie
benckie's picture
Last seen: 8 years 2 months ago
sorry i have not tryed mine on 4 x CR123A,s so i cant answer that one, but i know it will run on AA,s lol
benckie
benckie's picture
i measured the reflector,s in my TR-3T6 that i brought from manafont
depth 17.30 mm 0.681 inch or 681 thou
width 22.50 mm 0.885 inch 885 thou
hope that helps
Dimitrioptimus
Thankx Benkie for measuring,
Previously I wanted to fit a single aspheric optics but I was wrong as correctly explained by JohnnyMac now I am thinking that to fit 3 aspheric lens glued on a single 52mm normal lens for better throw mode,thatsy I required the measurement,I don't know what would happen with this Idea.
Dimitrioptimus
I am thinking of this,
Our local optician told me that he can make it with even AR coating,but he requires full specs,
Just wondering  what full specs perquisites are required,perhaps one would be diameter,Focal Point but what else ?
benckie
benckie's picture
No problem, my measurements might be out 0.2 mm but close. As for aspherical lens or lens's I might not understand what you are doing but I feel it would take away what the torch is for. With out any aspherical lens it will give out a white wall of light and put out good usable throw for a couple hundred meters (well to me any way). One or more aspherical lens might kill the performance of the spill with not to much more throw it just might turn it into a fire starter lol. The UCL lense upgrade might be the best bet and cheap I think I'll do some measurements tomorow and post up the best matching UCL lens if you like as I'm going to buy a couple any way.
jedavet
Last seen: 9 years 8 months ago
Benckie,
Let us know what options you come up with for the UCL Lens.
viffer750
Last seen: 4 years 3 months ago
Forget it.
Xm-l needs at least 40-50mm aspheric lens.
unique engrish language... Smile
benckie
benckie's picture
i have measured the len's from my TR-1200 and TR-3T6 they both are 51.82 by 1.43mm aprox im looking at using this lens as a replacment
http://www.flashlightlens.com/str/index.php?app=ccp0&ns=prodshow&ref=mag_521_UCL
there is also a Light Diffusion Film you can have added if you like
http://www.flashlightlens.com/str/index.php?app=ccp0&ns=prodshow&ref=ucl_lens
i belive the 52.1 mm will not be a problem as there is a little side to side movement in lens with the trustfire host,s and i belive the 1.9mm will not be a problem in the TR-1200 at all but in the TR-3T6 you might have to screw down the alloy bezel spacer down a bit tighter.
i will buy one and try it in both lights and report my finds on fit, i dont have a light meter (will get one) so i go only go one how i feel for out put, but i feel it should be an improvement over the stock glass len's, i will give them a long run time test to see how they hold up.
Rezolution
Rezolution's picture
I have a few of the UCL lens laying around from other various Maglight projects.  I did a side by side eyeballing of the lens that's stock on the TR-3T6 and the UCL 52.1mm lens.  They were so close in transmittance that I didn't bother replacing it (mostly because I couldn't figure out how to get the lens retaining ring out safely).  If I had to guess, I'd say that the transmittance on the stock lens is probably around 95% (the UCL claims 99%).
Let me know if you get drastically different readings on the UCL lens and I'll swap mine out Smile
Also, if you're looking for a GOOD/cheap lux meter, this is the one I use from DX...
http://www.dealextreme.com/p/lodestar-premium-digital-light-meter-20000-...
I don't use it to get "lux" numbers, I use it for a general comparison of all my lights.  I mostly do ceiling bounce tests so the exact lux numbers don't matter, just how they compare to each other.
benckie
benckie's picture
It's easy to get the retaining ring off the TR-3T6 last time I used digital multi meter probes the stock lens is just glass. Thanks for the heads up on the light meter I've been looking at that one and the on from manafont.
Dimitrioptimus
To Benkie,
Thanks benckie for giving info on UCL lense,plz  give ur views for UCLp AR Acrylic Lens,they have light transmittance of 97%(as advertised), but I think they would deal better if accidentally dropped,what are ur opinion ?
To Rezolution
 Can u post the lux readings for Tr-3t6
To viffer750,
Thankx for the info regarding  aspheric lens,
Regarding "unique engrish language..."Wink
As I am an Indian,My native language is not English,beside we have to learn 4 languages including English,so If I made a mistake then I am sorry Embarassed
ILIKEFLASHLIGHTS
ILIKEFLASHLIGHTS's picture
Last seen: 2 years 9 months ago
I wanted to tell you guys that the folks that have bought this light from this seller on ebay have been very pleased.
That's the same seller I bought my Ultrafire C8 XM-L T6 light from.  He is very good.
http://www.ebay.com/sch/perotan/m.html?_nkw=3800+lumens&_sacat=0&_odkw=&_osacat=0&_trksid=p3911.c0.m270.l1313
ILIKEFLASHLIGHTS
And here's another option.  Folks seem to like this light they have bought from this seller.  He's the same guy that sells the Hi-Max 18650 2600MAH batteries that everyone is talking about.
http://www.ebay.com/itm/HI-MAX-3xCREE-XM-L-T6-LED-Flashlight-Torch-FULL-SET-/220815901089?pt=US_Flashlights&hash=item3369a741a1
http://www.ebay.com/itm/HI-MAX-3xCREE-XM-L-T6-LED-3000Lm-Flashlight-Torch-/220817770034?pt=US_Flashlights&hash=item3369c3c632
The first link is the better deal.  I just showed the second one because he has it listed as 3000 lumens.
FX-32
FX-32's picture
Last seen: 5 years 3 weeks ago
I was just "tracking" perotan/s auctions some days ago, I still have a bookmark to check everyday Big Smile
My brother just won one TR 3xT6 from this seller at only USD41 inc.Shipping!!
http://www.ebay.com/sch/minglo2010-88/m.html?_trkparms=65%253A1%257C66%2...
The first picture doesn't look like a genuine TrustFire, but pictures in description does. So, I'll wait and tell you then (may be in a month).
ILIKEFLASHLIGHTS
FX-32,
That might be a great buy.  I checked his feedback and those that have bought from him are pleased.
And I wanted to say in the quote you qoted me above is 2 different sellers.  I went back and fixed it so I put the info where it needed to be.  But I can't fix yours that you qouted me above.  I just wanted to make that clear.  Both those sellers I have no doubt are very good.  I have bought from both.  The Hi-Max batteries are very good batteries.
FX-32
FX-32's picture
OK, i edited my post in the quote. Wink
Have you seen the croco at the end of description? http://www.ebay.com/itm/LUMINUS-SST-50-5MODE-PCB-DRIVER-/220699453480?pt...
Laughing
benckie
benckie's picture
Are they geniune TR-3T6 or just copies, what happened last time ilikeflashlIghts posted eBay links ? + 28 people brought fakes and are still trying to sort it out. Maybe hold off on the eBay links untill you have personally brought, try and tested the light in question and they are proven not to be none genuine (fake) TR-3T6,s if they are genuine Awsome but if they are fakes or another type of 3 x T6 and you are happy with them then make a new thread
viffer750
Smile That's my signature.
benckie
benckie's picture
To Benkie,
I will as soon as it gets here, my thoughts are since the lense is stil glass it can still break but since it has a AR coating on both sides it should be stronger then normal glass atlest it should not shatter. I have a torch with an AR coated lense and it seams really good, strong and lets out good light, the UCL Lense seamed to be used alot in high out put modified maglites. I will test the lense with a long run time test as I have been planing to do another run time test longer then my last ones i did with the TR-3T6 as I want to see if the AR coating on the UCL will handle atlest 45 min runs on high, because if it will not it's no good to me. I'm sure the UCL lense will handle it no problem but I would like to test it for fit and use before I recommend it
Rezolution
@Dimitrioptimus
I can't do any testing with it until after Christmas.  My wife let me open it up to see if it powered on (so if there was a problem we could return it), but she got it for me as a Christmas gift Smile
benckie
benckie's picture
with in the next couple of weeks im going to buy this lux meter as im intrested in testing the TR-3T6 and testing the diffrence in the stock lense and the UCL lense
junk250
Last seen: 6 years 4 weeks ago
I have ordered the TrustFire TR-3T6 (3x 18650 version), but I don't have it yet.
I saw this optic that was made for the 3x xm-l cree, comes in 19 degree and 25 degree I think.
Was wondering if you could use this instead of the stock reflector to create a thrower out of the tr-3t6 ?
It mounts to the PCB via 3 pins, but I don't know if the TrustFire tr-3t6 PCB has the 3 holes in it or same alignment?
Probably not, but maybe custom file/glue it on ?
Here is where I saw it
http://www.led-tech.de/en/High-Power-Supply/LEDIL-Optics/CREE-CUTE-3-XM-...
I'm new here, and to led flashlights, so may be a stupid question.
Thanks !
Great forum by the way, I've learned a lot here !
benckie
benckie's picture
Hello and welcome, i dont think that reflector will work, well not with out a hell of alot of effort
