Nitecore D2 or I2
Dear fellows, I come before thee with this great question. Should I buy the Nitecore D2 or I2 charger?
I’m planning to use it to charge NiMh, and eventually if as I get into LiIon, charge them as well.
I think that the format is good, I don’t really need more than 2 slots, I just don’t know if I should go for the Digi charger that has the LCD or the Intelli charger that doesn’t.
I don’t really need the display but I want to know if it is worth having it, I don’t want to buy the I2 now and then end up buying the D2 because the display would come in handy.
Thanks in advance for all the responses, I’ve been learning a lot in this great and friendly fórum.
I have both, I like the D2 more. Shows me the charging status much more accurately and has a “low current mode” for charging AAA and smaller Li-ion cells.
The batteries that will see more use are AAA, so the low current mode is really nice! Thanks so much for the input, much appreciated!!!
I had an I4. It was great. I now have the D4 and D2. I prefer the display and lower current mode for 10440 etc.
My ignorance would never allow me to consider the lower current mode as anything more but a feature, should I use on 10440 only or for regular NiMH AAA as well?
Thanks for the great input, I guess that in the end all I wanted was a little push.
And since you are reading this, does the BLF code apply for chargers or just flashlights? I could use a couple of bucks less on the price. Thanks again!!!
The code applies to anything related to flashlights.
Where are you buying from?
I know the lower current mode is good for 10440, I’m not sure if it’s needed for AAA (but don’t use me as a guide).
Note, the 2014 I4/I2 has “trickle” charging on nimh that can cook batteries. I had the V2 (not 2014) version and was happy. I believe the D2/D4 just stop, so I’m quite pleased with that.
Test/Review of Charger NiteCore Intellicharger D2 D2 Charger Review
use the Search box, upper left hand corner
http://budgetlightforum.com/search?q_as=D2%20I2%20nitecore%20charger%20review
Banggood seems to have the best pricing. If the code applies I may have to give it a try.
On regards to HKJ testing, I’ve read it, a few times. Took me a while to get the graphs, but I missed the NiMH AAA test, so thanks for the heads up.
I thank everybody for all the great input and suggestions. I need to ask one more thing though. Do you guys know what kind of plug would fit the brazilian standards? I believe it (the new brazilian plug) is based on the euro plug but it has diferent dimensions, not quite sure which one should I choose.
I only realized I could have a problem with it while browsing HKEquipment. The menu where you can choose the insurance also shows the type of plug you want, and I just have no idea which one would be the best choice.
More info here
