Test/Review of Eizfan IMR18650 2000mAh (Gold)
Official specifications:
  • Capacity: 2000mAh
  • Nominal Voltage: 3.70V
  • Standard Charge: 1250mA End current(Cut off): 50mA
  • Fast Charge: 4000mA End current(Cut off): 100mA
  • Max. Charge Voltage: 4.20V
  • Max. Charge Current : 4000mA
  • Standard Discharge: 500mA
  • Fast Discharge: 10000mA, 20000mA
  • End voltage(Cut off): 2.5V
  • Max. Discharge Current for continuous discharge: 20A
  • Max discharge: 40A
  • Weight Approx.: Max. 47.0G
  • Operating Temperature: Charge 0 ~ 50°C, Discharge -20~ 75°C
  • Storage Temperature: 1 month -20 ~ 60°C, 3 months -20 ~45°C, 1 year -20 ~ 20°C
  • Dimension: (D)18.2 + 0.2/-0.3 mm , (H) 64.55 ± 0.2 mm
A 18650 high current battery with more than promised capacity.
The cells do not track perfectly but fairly good. The cell can deliver a lot of current.
Conclusion
The cell can deliver a lot of current and has a good capacity, I could have wished for a bit better tracking between the two cells, but I will call it an acceptable cell anyway.
Notes and links
The batteries was supplied by Efan for review.
Compare to 18650 and other batteries
