Adding a protection-board to a non-protected cell ?
8 posts / 0 new
DBSAR
DBSAR's picture
Last seen: 1 day 15 hours ago
Have any one tried removing a protection board from a dead, weak, or cheap LiIon cell, and transplanted it to a good non-protected cell ?
I have 2 really crappy red Crapfire cells that has a ridiculous high internal resistance, ( drops from 4.12 volts to 3.7 volts in a couple weeks) and they tested at a lethargic 560mah and 610mah each, but the protection circuits actually work. (cuts off the voltage at around 2.5 volts when discharging in a light that don;t have low-voltage protection.)
I was going to toss the cells to the recycle bin at the local HomeDepot, but wondered if the protection bases and side-strips could be salvaged and transplanted on laptop pulls, then re-wrapped.
Jaidmaster
Jaidmaster's picture
Last seen: 11 months 3 days ago
I have never done it, but assuming you can solder to the unprotected cell, I don’t see why this wouldn’t work…
pilotdog68
pilotdog68's picture
Last seen: 9 months 3 days ago
I’ve done it with the protection circuits fasttech sells. The hardest part was getting the solder connections clean and compact enough to still fit in a light.
cbrake10
Last seen: 1 year 1 month ago
I wonder if solder paste might help with that? No experience, just spit-balling.
-Clark
Halo...
Halo...'s picture
Last seen: 5 years 5 months ago
You can also get seiko protection pcbs on aliexpress.
zeremefico
zeremefico's picture
Last seen: 1 hour 42 sec ago
I am looking for the button top of 18650’s, as a spare part. Any ideas?
₪₪₪₪ ΟΥΔΕΝ ΚΡΥΠΤΟΝ ΥΠΟ ΤΟΝ ΗΛΙΟ ₪₪₪₪
My YouTube channel
Flashlights & edc gear
K40M F16
DBSAR
DBSAR's picture
some use small neodymium magnets, i have used just blobs of solder on most of mine.
hank
hank's picture
Last seen: 6 days 20 hours ago
Remember the legitimate manufacturers will warn you never, ever try to solder to a Li-ion cell, because that heat can damage the thin membrane that separates the reactant chemicals (just as denting it, or dropping it, can do). Once that sort of damage happens you can get crystals slowly growing and eventual “Rapid Unplanned Disassembly”
The right way: have tabs spot-welded on; then you can solder to the tabs.
