New FL-4H-LCD-A and FL-4H-LCD-D from Gear Best
Just saw these 2 chargers at Gearbest New Arrivals.
Looks like these are analyzing chargers as well. The FL-4H-LCD-A is a higher end model that can charge 4.35 Li-ion automatically while the FL-4H-LCD-D is only for normal 4.2V Li-ion
FL-4H-LCD-A Link
FL-4H-LCD-D Link
Looks like a good contender for the OPUS 3100! Anyone knows anything about these 2 chargers?
I have FL-4H-LCD-A.
Measuring in the discharge mode is OK but actual current is a bit lower (460 mA at “500 mA”).
Measuring in the charge mode is about 15% less than actual. Actual current is 1020 mA at “1.0 A” but calculated capacity 500 mAh only after 35 minutes so it must be 500 mAh after a half hour.
Voltages are OK at all modes +/-0.02 V.
It has no fan so it became very hot in discharge mode.
For NiMH it is good but MAHA 9000 puts additional 100 mAh in the white Eneloop (1800 mAh vs 1900 mAh).
