First Mod. Now I'm Addicted! Need Advice On Next Light
13 posts / 0 new
Yourrid
Yourrid's picture
Well I think I’ve been bitten by the bug.
I finally decided to do my first driver swap for one of my BLF Eagle Eye X6’s and managed to pull it off without burning the house down (or causing serious bodily harm to myself). Ended up putting in a Wight’s driver and am pretty happy with the results. Heck, with my inexperience, I was just happy the dang thing turned on Party I still have to do a spring bypass, but so far so good.
So… now I want to set my sights on more lights that are within my ability to mode (simple driver swap, spring bypass and the like). I haven’t read up on how to reflow emitters yet, but that is next on my list.
My question is: what lights do you guys recommend that are of decent quality, that just need a new driver, maybe an AR lens and some new springs, that really “open up” once properly driven? I figured there must be a few “must have” modded lights out there that are just under-driven and have great potential.
Links would be greatly appreciated!
MRsDNF
MRsDNF's picture
How about just buying a host and putting in your own led and driver?
tristanxoxo
Last seen: 8 months 4 days ago
Depends what kind of light you want. I definitely suggest one of the Convoys though. They make awesome hosts and I love their build quality. IMO their build is right up there similar to X6.
The next mod you should definitely be Noctigon or Sinkpads though…they really make a huge difference. If you are not comfortable reflowing emitters, you can just buy them already mounted. For the $2 it costs for a DTP copper star, it is one of the best bang for your buck mods.
Rufusbduck
Rufusbduck's picture
Last seen: 6 months 1 week ago
Convoy S2 with a noctogon triple xpl V-6 3D on copper spacer from MtnE, BLFADD-S08. A true little pocket wall ‘o light.
Scott
Yourrid
Yourrid's picture
MRsDNF; I’m totally open to using hosts. Cracking open an already working flashlight, and just swapping out the guts gives me a little more confidence that I’m not going to screw it all up. Big Smile
Tristan; I’m all about the wow factor lights. I have a few EDC’s already that fit the bill just fine. I am kind of looking for ideas from everyone else’s previous builds.
Rufusbduck; now that is what I’m talking about! Does that spacer allow a 20 mm noctogon to fit in the host or something?? I read where the s2 requires a 16 mm but I can’t find any triple 16mm’s on the site. Or am I going to have to file down the noctogon?
keltex78
keltex78's picture
Last seen: 1 year 4 months ago
Yourrid wrote:
Does that spacer allow a 20 mm noctogon to fit in the host or something?? I read where the s2 requires a 16 mm but I can't find any triple 16mm's on the site. Or am I going to have to file down the noctogon?
The spacer is to help maintain the correct height as you are removing the reflector and using a much shorter optic lens to make the triple. The spacer fits the pill and gives you a surface for the PCB to rest on. I'm slowly accumulating the parts to make one myself...
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
Bigchelis
Last seen: 2 years 10 months ago
Try a 2D Maglite and mod it to take an MTG2 direct drive off 2 Li-on 32650’s or put a FED DD Driver.
or
2C Maglite with MTG2 and put MTG2 Direct Drive off 2 IMR 18650 cells. 2 IMR 18650 cells fit length wise, but those Protected 18650’s are a bit longer and will not fit.
bigC
Yourrid
Yourrid's picture
keltex78 wrote:
The spacer is to help maintain the correct height as you are removing the reflector and using a much shorter optic lens to make the triple. The spacer fits the pill and gives you a surface for the PCB to rest on. I’m slowly accumulating the parts to make one myself…
Do you have a link for the triple in 16mm at mtnelectronics? I don’t see it anywhere.
bugsy36
bugsy36's picture
The triple in the Convoy S lights is 20mm Since it rides on the spacer and not inside the pill it fits well as to the optics
It's the simple things that we take for granted that cost us the most
Ευκαιρία λέει πιάσε με από το μέτωπο γιατί μόλις έχω περάσει δεν θα με πιάσειs
Yourrid
Yourrid's picture
Ahhhhhhhh… makes sense now!
Ronin42
Ronin42's picture
Last seen: 1 year 11 months ago
Yup I get that if it is working when it comes in th door then (as an idea) it is simpler to start substuting parts.
lots of folks like the:
courui d01
The TK35 “clone”
For an easy MT-G2 upgrade this light is attractive, the link has all the details.
“New-117 (TK35 clone) mod. Turn a TK35 into a TK35UE”
http://budgetlightforum.com/node/36591
Be careful about maglite mods folks have often go so far as to start cutting them down to use different batteries types (which to me is a whole additional level of “mod”).
Lots of folks start off with changing parts on a C8, or similure they are also known as lego lights. There is a guy on ebay who sells a 10×7135 pill for his c8 lights that just drops in and make the cells the weakest link in the light (assuming the spring resistance mods have been done.
Once you start looking you will find way too many options.
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
Yourrid
Yourrid's picture
courui d01
The TK35 “clone”
Ronin, that TK35 clone looks awesome! I’d rather use the huge head of the courui as a thrower personally (xml2 de-domed?)
Yea the maglits seem like a massive hassile for me at this point in the game. I have an LED maglite but the internals look nothing like the rest of my flashlights. I’m actually shopping around right now for the Convoy C8 v2 so that is on my list for sure. Thanks for the help!
bugsy36
bugsy36's picture
I just realized that you used Wight's driver. That and the 17DD are the cat's ass in my opinion if you want big power Smile
Just food for thought....before you get to far into buying lights to mod...look into building a couple drivers. Do not worry about flashing firmware because you can get flashed mcu's from RMM. My personal experience is that I wanted to do the same thing by purchasing working lights and then I figured I will start collecting parts that I replace. Then it dawned on me...what the hell am I going to do with these extra drivers and emitters. Maybe one I will use them Smile
If later you get into flashing the firmware you can start enjoying the ability to make the lights do whatever you want Smile
