Test/Review of Aosibo IMR18650 2600mAh (Yellow)
21 posts / 0 new
HKJ
HKJ's picture
Last seen: 2 days 7 hours ago
DSC_8543
Official specifications:
  • Nominal Capacity: 2600mAh
  • Nominal Voltage: 3.70V
  • Charging Voltage: 4.2V
  • Discharge Cut-off Voltage: 2.5V
  • Max. cont. discharging current: 30A
  • Cell Dimension: Diameter 18.3±0.2 mm, Height 65.0±0.2 mm
  • Cell Weight (Approx.): 46g
  • Initial internal impedance Max, at 1000Hz.: Charging Current (CC/CV): Rapid charge 2CA×2.5hrs, Standard charge 0.5 CA×4hrs
  • Operating Temperature Charge: 0°C ~ 60C°
  • Operating Temperature Discharge: -20°C ~ 75°C
  • Storage Temperature: -20°C ~ 45°C
Aosibo%20IMR18650%202600mAh%20(Yellow)-info
A high current battery with fairly high capacity.
DSC_8542
DSC_8544 DSC_8545
DSC_8546
DSC_8547
The battery is marked with two currents 30A is the continuous discharger current and 60A being a unspecific pulse discharge.
Aosibo%20IMR18650%202600mAh%20(Yellow)-Capacity
Fairly good tracking between the two cells and capacity hold fairly well at 30A. As usual the reason for slightly more capacity at very high currents is heat. The high current heats the cell and chemistry works better when warm.
Aosibo%20IMR18650%202600mAh%20(Yellow)-CapacityTimeHours
Aosibo%20IMR18650%202600mAh%20(Yellow)-Energy
Aosibo%20IMR18650%202600mAh%20(Yellow)-PowerLoadTime
Aosibo%20IMR18650%202600mAh%20(Yellow)-TripCurrent
Aosibo%20IMR18650%202600mAh%20(Yellow)-Charge
Conclusion
This battery has very good performance and capacity at high currents.
Notes and links
The batteries was supplied by Aosibo for review.
Compare to 18650 and other batteries
Ray-o-light
Ray-o-light's picture
Last seen: 3 months 1 day ago
Thanks HKJ for the review! Looks like a great battery.
Hey Babe, check out my new light!!
dangerous
dangerous's picture
Last seen: 6 years 10 months ago
This cell is impressive. It handily beats HKJ’s HE2 and 25R samples in capacity, but it seems to have more initial voltage sag under high current. I wonder what cell they are using.
BLF
shadockan
shadockan's picture
Is the HE4 under the label of Aosibo ???? :quest:
The positive pole is however like the LG Chem and say it’s better at a high temperature from the HE2…… :quest:
Thanks HKJ for your time.
HKJ
HKJ's picture
I cannot tell you. The datasheet for the cell just has the Aosibo name on it.
shadockan
shadockan's picture
Thank’s HKJ
Newland
Newland's picture
Last seen: 6 years 2 months ago
Thanks for the review. Never saw them around.
Tapis
Tapis's picture
Same. Where to buy them?
ryansoh3
ryansoh3's picture
Last seen: 10 months 2 weeks ago
I’m pretty sure the cell is a Sony VTC5 IMR 2600mAh.
The Keeppower IMR 2600mAh (which uses Sony VTC5 cells) tracks very closely with the Aosibo, both at very low as well as high currents.
BLF ≠ B-grade Flashlight Forum
Yanic Osbest
Yanic Osbest's picture
Last seen: 6 years 6 months ago
It is not Sony battery cell, Sony has discontinued.
Here is pic of our battery cell, pls check it.
Li-ion battery 10440/14430/18350/18500/18650/26650, battery charger
Yanic Osbest
If you need it, pls contact me.
Yanic Osbest
Contact me, Dear !
ryansoh3
ryansoh3's picture
Yanic Osbest wrote:
It is not Sony battery cell, Sony has discontinued. Here is pic of our battery cell, pls check it. !https://twitter.com/AmalSherny/status/573655243273064449!
Here’s your photo:
Do you know what brand cell it is? I don’t see any identifiable markings on it.
Yanic Osbest
It is our own brand cell. We dont make any lable on it for this moment, but it is made in China.
ryansoh3
ryansoh3's picture
I see, thank you.
Is there a supplier you have for those who are interested in purchasing these cells?
Yanic Osbest
ryansoh3 wrote:
I see, thank you.
May I know your location?
ryansoh3
ryansoh3's picture
Yanic Osbest wrote:
[ May I know your location?
I’m in the United States.
I’m sure international members will be interested as well.
Yanic Osbest
Dear, Contact ways of American retailer and wholesaler has been PM you. Big Smile
ryansoh3
ryansoh3's picture
Thank you for the PM.
Yanic Osbest
You’re welcome. Hope you will be satisfied with our battery.
Yanic Osbest
DSC_8543
  • Initial internal impedance Max, at 1000Hz.: <=10 mOhm (Charged)
  • Charging Current (CC/CV): Rapid charge 2CA×2.5hrs, Standard charge 0.5 CA×4hrs
DSC_8542
DSC_8544 DSC_8545
DSC_8546
DSC_8547
Conclusion
Notes and links
Thank you Henrik, really appreciate your help.
