New: Noctigon Meteor M43 ; in production New color added: Tan
1214 posts / 0 new
xed888
Last seen: 10 months 3 weeks ago
Hikelite wrote:
Cheap and extremely powerful (they have to be button tops),  right about the best cells you can get.
LG ICR18650HE2 or LG ICR18650HE4
Unfortunately, its difficult to ship stuff from the US. Id rather get it from China
ChibiM
ChibiM's picture
Last seen: 1 day 9 hours ago
Maybe good to let us know your exact location.. whats BN?
okupka
Last seen: 6 years 5 months ago
Rod911
Last seen: 11 months 2 weeks ago
Reposting in this thread…
I know to get the most out of this light, you should be using high drain, low resistance cells. The problem is, I’m looking for something relatively cheap, has a high capacity (>2900mAh) and performs well.
These are the candidates:
- Panasonic NCR18650PF at US$55.90 for 10
- LG HG2 at US$66 for 10
- Panasonic NCR18650BD at US$72.80 for 10
- Panasonic/Sanyo NCR18650BL at US$86 for 10
If you simply go for $ per mAh ratio, the best option is NCR18650PF at $0.0019 per mAh. The LG is a little bit higher at $0.0022 per mAh; NCR18650BD is $0.0023; and NCR18650BL is $0.0025.
I’m leaning towards the LG HG2 because that has more headroom at 20A versus NCR18650PF’s 10A discharge.
okupka
But you need button top battery for it. To make contact and to not to be too short(as is written on fonarevka).
Rod911
okupka wrote:
Rod911 wrote:
Reposting in this thread...
But you need button top battery for it. To make contact and to not be too short(as is written on fonarevka).
Solder.  Make your own button top cells with it.
Hikelite
Last seen: 9 months 4 weeks ago
Rod911, forget about capacity, it is irrelevant becasue you do not care what capacity can be gained after 3V (most cells are claimed for down to 2.5V). And for any serious flashlight you only care about capacity that is resulted at 5A-7A down to 3.6V, after that all cells are way too weak, to matter what they offer at ultra low voltage.
Take a look at this and see the capacity at 3.6V, you will see how the NCR18650PF are the last option and the nominal 2900mAh is irrelevant for 5A.
Hikelite
Solder will be sanded off in time due to friction.
Rod911
I know.  That's why you do it again when it wears down?
I'll stick with my original thoughts and get the LG INR18650HG2 cells.  Thanks for stating the obvious.
Hikelite
I actually use some 9mm diameter by 1.5mm thick brass piece  that is soldered on top of the cell. But I also have a button top model like the Keeppower IMR18650 2500mAh.
DB Custom
DB Custom's picture
Last seen: 1 week 6 days ago
That chart seems to indicate that the Samsung 25R is a better choice than the LG HE-2 or Sony VTC5.
In my experience with my dozens of FET driven lights, this is simply not the case. The Sony VTC5 is one of the best cells money can buy, with the LG HE-2 and Efest 35A hot on it’s heels. The 25R is tagging along on their heels. I don’t have fancy testing equipment that makes neat computer charts, but I do have some pretty fancy high drain devices and those tell the real world story. Wink
Yes, I have all these cells. Wish I had more C5’s but I’ve only got half a dozen of those. I’ve got a dozen or more 25R’s, used in specific lights for their button tops. I’ve got dozens of 35A’s, all in all my favorite cell out of the close to 200 that I have. (I don’t know exactly how many cells I do have, but with 105 lights and many of those requiring multiples and a box almost full of spares I have a LOT.)
I’ll try to get numbers on the Meteor M43 with as many different sets of cells as I can to show what it does with each.
No, I don’t have the light in hand at this point. I was going to put a beamshot up of my Trustfire Showerhead light with it’s 12 XP-E2 Torch emitters so I’d know where to find it, lol. Figured everyone would get confused by their anxiety and misinterpret that so I didn’t start it yet. I’ll just re-shoot comparison lights against it when I do testing on the M43.
Possibly today? Probably early next week…
xed888
okupka wrote:
from europe:
http://eu.nkon.nl/rechargeable/18650-size/efest-imr-18650-battery-35a-pu...
from china:
http://www.banggood.com/AceBeam-MRC18650H-250A-LG-18650HE2-20A-2500mAh-R...
They should have the same LG HE2 inside
Thanks for the link
Hikelite
Well not exactly, becasue if you look at the 4V and 3.9V capacity the the LG is higher (sustaining that voltage for longer time, if we can use such word for small time differences). So for those "fresh tailcap readings" I can see why the LG will give better results in a unregulated direct drive flashlight, which goes along with your findings.  However I would not take anything as 100% correct, there is always room for at least 1% to 5% error in anything.
That would be interesting, just make sure the host temperature is the same when you take change the cells.
DB Custom
DB Custom's picture
Thanks for that reminder, I’d have forgotten and jumped right into the next set.
So I’ll tell the wife that YOU said we had to play around a while so the light can cool down between test runs. Wink
Serp
Serp's picture
M4D M4X
M4D M4X's picture
damn is that light small Shocked
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
DB Custom
DB Custom's picture
Wow, that reminds me what I’ve been forgetting to do… I need to make a Dr.‘s appointment. How do I decide which hand to have the pinky finger removed from so I can hold this light properly?
saypat
saypat's picture
Last seen: 1 week 1 day ago
Every time I see a new post I fear Hank has added the new Neutral emitter to the list (he said this week sometime), and I would be forced to spend some $.
Or I will just wait and see if I can snag one from Richard when his arrive.
DB Custom
DB Custom's picture
Say what? S2 3D? for the M43? And I’ve already ordered S3 2B? Oh brother! Gotta look into that…
The sample Meteor arrived today from RMM, and this thing is exquisite! The machining and finish are simply spot on, unbeaten at any level. The feel in the hand is superb, it’s so stinking cute you just want to get 3 or 4 of em!!! He sent HE-2 cells with it for consistency across the board, they’re on the charger.
Noctigon’s first step up to the plate is a grand slam home run in the bottom of the 9th! Very well done, whatever corroborations were needed on this it was worth every bit of time and effort applied. Thank you, for entering the game with such Pizzazz!
M4D M4X
M4D M4X's picture
this is the S2 1D D-D ?
pleeeeeease make a beamshot for me!
PLEASE NOTE
RMM
RMM's picture
Your thoughts echo mine.  I sat it down and compared it side-by-side with every Fenix, Nitecore, Niwalker, Olight, and other premium light I have, and this is as good or better than all of them.  I would say that as an overall package, the light is currently unrivaled.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
DanielM
DanielM's picture
Last seen: 9 months 3 weeks ago
Y’all twistin’ my arm here with all the praises :bigsmile:
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
atbglenn
atbglenn's picture
Last seen: 2 years 6 months ago
How would the stock XP-G2 compare with my just sold Nitecore TM26 XM-L2?. I'm thinking about getting one of these.
Boycott Nike
ToyKeeper
ToyKeeper's picture
Last seen: 6 days 21 hours ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
atbglenn wrote:
How would the stock XP-G2 compare with my just sold Nitecore TM26 XM-L2?. I’m thinking about getting one of these.
The Meteor CW XP-G2…
  • is much smaller and lighter
  • puts out more lumens (~6900 vs 3500)
  • doesn’t throw as far (33.6kcd vs 43kcd, or 366m vs 415m) (unless you get the de-domed version, which throws farther)
  • has a 3-color lighted switch instead of OLED display
  • costs significantly less
  • has a different type of beam pattern due to optics instead of reflectors
  • uses a very different (and more flexible) interface
  • isn’t a battery charger
  • doesn’t trigger thermal step down as quickly as the TM26
  • has a regular e-switch instead of a 2-stage switch
I think that mostly covers it.
atbglenn
atbglenn's picture
ToyKeeper wrote:
The Meteor CW XP-G2... * is much smaller and lighter * puts out more lumens (~6900 vs 3500) * doesn't throw as far (33.6kcd vs 43kcd, or 366m vs 415m) (unless you get the de-domed version, which throws farther) * has a 3-color lighted switch instead of OLED display * costs significantly less * has a different type of beam pattern due to optics instead of reflectors * uses a very different (and more flexible) interface * isn't a battery charger * doesn't trigger thermal step down as quickly as the TM26 * has a regular e-switch instead of a 2-stage switch I think that mostly covers it.
Not that it matters much, my TM26 was the newer 3800 lumen version. I don't care about the internal battery charger which I never used. I just want something significantly brighter flood wise. Will the Meteor do that with the XP-G2?
Boycott Nike
Firelight2
Firelight2's picture
Last seen: 14 hours 52 min ago
Agreed! Please post a beamshot Dale! Pleaaaaase!!!! Shocked
DB Custom
DB Custom's picture
mizjif
mizjif's picture
Last seen: 13 hours 45 min ago
Awesome! Thanks for the video. I have been waiting for some sort of footage of the light.
Hikelite
DBCstm wrote:
Say what? S2 3D? for the M43? And I've already ordered S3 2B? Oh brother! Gotta look into that... The sample .....
Something ain't right there, I think you mean S3 3D, respectively S4 2B.
Hikelite
Mostly a matter of taste I believe, do you find the UI to bring  to you any advantage, then that should make the difference.  The higher the lumens the harder to notice the difference.
