New: Noctigon Meteor M43 ; in production New color added: Tan
1214 posts / 0 new
DB Custom
DB Custom's picture
Last seen: 2 weeks 5 days ago
No wonder Booom is mentioned…
Serp
Serp's picture
As far as I understood from the discussion at fonarevka the microcontroller monitors all of this and will not let them explode. But of course it is better to four identical Smile
LinusHofmann
LinusHofmann's picture
Last seen: 2 years 4 months ago
Mixing cells with different capacities/chemistries/IR is a really bad idea. And seeing as the cells are in parallel there is no way for the light to monitor the health of each cell individually.
This is a very high power light, if you can’t feed it 4 matched high power cells to take advantage of it fully maybe hold off buying it until you can.
ToyKeeper
ToyKeeper's picture
Last seen: 5 hours 39 min ago
Serp wrote:
you can use three ordinary battery and one high current HE2/HE4
… what?
It’s not a good idea to connect mismatched cells in parallel. The MCU doesn’t even matter; the cells will equalize each other simply by being connected, and if they’re mismatched the equalizing process can cause fires or explosions. I’ve actually made fire this way, when I accidentally connected a couple mismatched cells in a config similar to what the Meteor uses. It took only a fraction of a second.
Get one set of four identical cells, and make sure they always stay together and get charged together as if they were one.
keengeorge
DBCstm wrote:
No wonder Booom is mentioned...
LinusHofmann wrote:
Serp wrote:
As far as I understood from the discussion at fonarevka the microcontroller monitors all of this and will not let them explode. But of course it is better to four identical :)
Mixing cells with different capacities/chemistries/IR is a really bad idea. And seeing as the cells are in parallel there is no way for the light to monitor the health of each cell individually. This is a very high power light, if you can't feed it 4 matched high power cells to take advantage of it fully maybe hold off buying it until you can.
ToyKeeper wrote:
... what? It's not a good idea to connect mismatched cells in parallel. The MCU doesn't even matter; the cells will equalize each other simply by being connected, and if they're mismatched the equalizing process can cause fires or explosions. I've actually made fire this way, when I accidentally connected a couple mismatched cells in a config similar to what the Meteor uses. It took only a fraction of a second.
+1,000,000,000,000,000,000......
ChibiM
ChibiM's picture
Last seen: 21 hours 28 min ago
@ keen George: can you say that again, but then in words? My brain can't come past the second 0 from the back.
DB Custom
DB Custom's picture
Do all those zero’s symbolize emphatic agreement?
Can I May I please have a dollar for every one of those please? :bigsmile:
Kloepper Knife Works
Last seen: 5 years 7 months ago
I think he mistook the ability to run on, say, only 2 cells (which it CAN do) as something else.
keengeorge
+1 Quintillion  Smile Wink
keengeorge
DBCstm wrote:
Do all those zero's symbolize emphatic agreement?
Nah, my keyboard got stuck.  Wink
And yes Dale, you Can have a dollar for each zero if you so desire.  Smile Wink
keengeorge
I think you are probably right, BUT what a Dangerous mistake....
I think you are probably right, BUT what a Dangerous mistake….
No kidding, it’d be an expensive lesson turning a Meteor into a meteor.
I’ll refrain from speculation about the cause of your sticky keyboard. :bigsmile:
fatsteve0
subscribed/ ordering when i get off work
mhanlen
mhanlen's picture
Last seen: 1 year 11 months ago
Ok, just got it today. Wow, it’s small and heavy (relatively speaking)… And by the way thanks for linking the English manual some pages back because, out of the box I wasn’t sure how it operated.
So once I read the flow chart I figured it out… but don’t expect to get it without reading it… because you won’t. I like to think of it as a short cut based UI. I don’t necessarily love it, because you need to remember what 1 press, 2 presses, 3 presses do… but it isn’t difficult. UI 3, I don’t even think I’ll bother with, and so far UI 2 seems the one that suits me the best. Personally I’d like it if it was a press on and press off… with pressing and holding from on to get to the mode you want.
Unlike Dale, I probably won’t post anything until I’m finished with the review… but I plan on getting it in the mail in less than a week and a half… and getting my review up a few days after. It’s much brighter even in the daylight than my new Imalent DDT40.. but I won’t know how much until I see it in the dark. The light is extremely well built… The fit and finish is pretty flawless too.
DB Custom
DB Custom's picture
I hurried my look at it because I have one of my own coming and there were others wanting to get their hand on it. No real reason for me to do an in-depth review with extensive pics and video on the same light several others will also be looking at.
So I’ll give a better look with my own in XP-G2 S4 2B trim. Wink And maybe then in XP-L V6 3D. And maybe then in Nichia 219C. Wink
mhanlen
mhanlen's picture
My review will probably be a bit briefer than I normally do, because of this. Can’t say I’ll drop the money on this one, unless I can get it for a decent price. That said, it’s tinier than any 4× 18650 light I own, and it’s also way brighter. By the way, what version of the light is this? Anyone know? Anyone know the specific optic used in it? I want to make sure my review is accurate.
DB Custom
DB Custom's picture
The sample you’re playing with is the XP-G2 S2 1D de-domed with 10507 Carclo optics.
mhanlen
mhanlen's picture
thanks!
mhanlen
mhanlen's picture
Ok, I lied. I’ll upload runtime tests as I do them, even though I’ll speed them up a bit more and integrate them into my main review. I plan on also doing a runtime test on Turbo with some Sanyo UR18650FM 2600mah batteries… just for the hell of it… The light is recommended to use the LG high drain batteries… but the Sanyos didn’t do so bad. When I get both of them rendered I can watch the videos side by side to make an accurate assesment of how the batteries perform during this test
mhanlen
mhanlen's picture
Ok here is turbo with the Sanyos.
keengeorge
Good Day mhanlen, Smile
Great & Useful videos.
Thank you Very Much,
George
Ray-o-light
Ray-o-light's picture
Last seen: 2 months 4 weeks ago
Nothing like a run time test with a couple of different batts. Thanks for the real info!
Hey Babe, check out my new light!!
mhanlen
mhanlen's picture
Having just watched the two videos side by side above… it seems the winner in runtime at least is the Sanyo by about 10 minutes. Plus is seems to have a much nicer taper off in brightness. I can’t say side by side which was brighter initially though.
jhalb
jhalb's picture
Last seen: 4 years 8 months ago
And I happen to have around a hundred of those Sanyos..... But there laptop pulls.Frown
I doubt they would last that long.
Thank you for the review!
mizjif
mizjif's picture
Last seen: 5 hours 14 min ago
Thanks for the videos!
My stone white xp-g2 s2 dedome just shipped. Now the real wait begins.
mhanlen
mhanlen's picture
And another runtime test on High 1… Sorry I know these are boring, but I had some people mention I should have a slightly longer version to better appreciate the drop in brightness. They’ll be sped up considerably in the final review.
ryansoh3
ryansoh3's picture
Last seen: 10 months 1 week ago
Hey mhanlen, correct me if I’m wrong, but isn’t the video footage sped up around 50x, not 5000x? Seems like one video second corresponds to just a little less than one real minute.
Thanks for the shots though, they provide a very nice runtime & brightness comparison.
BLF ≠ B-grade Flashlight Forum
mhanlen
mhanlen's picture
In Final Cut Pro, in the speed, I put in 5000%. Is that not 5000x? Maybe it’s not interchangeable if 100% is full speed. Or would it translate to 500x?
maksoff
5000% / 100% = 50x
Hikelite
120minutes compressed into 2 minutes is 60 times faster.
