[WIP] Supfire M6 series 18650 conversion (2S2P for now -- 4S possible)
29 posts / 0 new
JaredM
JaredM's picture
Last seen: 1 hour 8 min ago
This is what I’ve been thinking about for a simple, cheap, safe, and reversible series mod to the M6.
I still haven’t put enough time into figuring out Eagle so I haven’t been able to make to contact board.
The nylon legs are available on amazon along with the proper sized screws that I’ll post later.
Pi Day UPDATE:
The first prototype is being made this morning. I managed to simplify the leg assembly by using self retaining pcb spacers. This eliminates the only ‘ugly’ part of the design which was the need for metal screws. Now there are zero conductive parts other than the contacts. I’ll post a picture of what I make later today.
3-15-15
The prototype is working beautifully, and now that I’ve identified most of the quirks with the format and resolved them to my standards, I’m ready to move on and get these boards produced. I still need to learn Eagle, so I don’t know when I’ll be finished if I draw it up, but I’ve PMed other experienced users and they’re willing to put it together with dimensions that I supply. As for the hard goods involved. The nylon legs are $12.33/100pcs at Future Electronics . And assuming $1.50 for the Oshpark board this unit could go for as little as $2 (not including springs and brass buttons, which most modders have in stock).
https://fundrazr.com/osturaband
No affiliation, just a fan.
Edited by: JaredM on 03/15/2015 - 11:19
RMM
RMM's picture
Pretty cool!  Designing the contact plate in Eagle is probably easier than what you did creating those drawings.
Mountain Electronics : batteries, Noctigon, and much more! What's new?
JaredM
JaredM's picture
Thanks Richard,
I know I’d be able to do it, I’ve just been lazy I suppose. Never put the time in to learn what is required to get them produced with all the layers and drill files and what not..
RMM
RMM's picture
JaredM wrote:
Thanks Richard, I know I'd be able to do it, I've just been lazy I suppose. Never put the time in to learn what is required to get them produced with all the layers and drill files and what not..
Just watch Mattaus' videos, they're pretty good.  I do a few things differently now, but they gave me enough guidance (and courage) to get started.
wight
Don’t forget that it should be keyed. That’s easy enough, eliminate one leg and replace it with a plug/key/etc.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
dchomak
Last seen: 3 years 6 months ago
This is good, I’m glad someone will tackle this!
JaredM
JaredM's picture
I put thought into a keying mechanism back when I was designing this, but didn’t think of anything that didn’t require someone to grind or drill into the battery tube. The only way to make it ‘idiot-proof’ is to make one leg extra long and drill a hole into one of the ears inside the battery tube.
Or I suppose you could make it require button tops and put a mechanical reverse polarity setup on it. Find nylon washers/bushings/rings slightly taller than the positive brass buttons and super glue them onto the board.
wight
Huh? Either I don’t understand exactly what this thing is or you are overlooking the obvious. Where and how do you intend for this thing to interface with the M6?
I assume that the user will be required to leave the body tube in place and remove the tailcap, at which point this item will fall out of the light… yes?
I see that I misunderstood what this was. Carry on.
JaredM
JaredM's picture
This is intended to drop into the top end of the battery tube after the required modifications were made to the stock contact board at the bottom to essentially convert the battery tube into a series carrier. As drawn, it is 2P2S, but with a slight modification we could make it 4S also.
Make sense now? Sorry for lacking descriptions early on.
wight
Eh, the misunderstanding was my own fault.
Anyway it does make sense. Your mockup is about as elegant as this type of solution is going to get, other than lacking a method of keying it.
I’m not really 100% happy with any method I’ve seen or thought of for doing a series conversion on the M6. If there was a clean, reversible way to lock the body tube in place then I’d advocate Mike C’s method, but I just haven’t seen a good way to handle that either.
JaredM
JaredM's picture
OP updated
DB Custom
DB Custom's picture
Last seen: 3 weeks 17 hours ago
Very nice, me neeeeds! lol
I have one in the wind at the moment to Australia in an effort to sort this out. Switching tubes to a modified TK75 extension tube so the carrier can be used. Hope it works! Wink
One (or two) of yours would be nice for the reversibility.
Subscribed.
RMM
RMM's picture
Excited to see the results
JaredM
JaredM's picture
Contact board is done. I made it from a full faced copper pcb from radio shack. It’s going into my second M6 to run 3 XHP-50s (soon to be 6) from four 25Rs using an old fubared M6 driver with just the FETs remaining. I hooked up the gates in parallel and I’m going to use the switch to run it momentary direct drive only. I’ll do my best to get some beamshots too tonight.. but I’m not making any promises Wink
JaredM
JaredM's picture
MRsDNF
MRsDNF's picture
That is one good looking creation JM. Very clever.Smile
DayLighter
DayLighter's picture
Last seen: 4 years 8 months ago
Nice work.. can’t wait for the beam shot Beer
The only way to do a great work is to love what you do.
JaredM
JaredM's picture
So now that I’ve got a day of use on the piece, with plenty unnecessary times opening and closing the light, I can say with confidence this is a reliable solution. The design is naturally keyed and at least in 2P2S, you can’t physically put it together the wrong way.
As you can see by the unused hole and leftover solder, I tried at first using a central spring for + plate to driver contact.. this worked but added that much more effort to compress the springs and get thread engagement. Another side effect was the spring would sometimes bind the contact plate inside the head, where it would remain after you opened it up. Nothing terrible but didn’t prove to be an advantage over my second solution, which is better for current carrying anyway.
As for the beamshots, I’m charging up all my batteries today and am going to try and do a full shoot of my collection if the conditions are good. It was too foggy last night and everything is wet so not ideal conditions..
But I’m kind of mad I built this. Now my modded K40M and XML2 M6 look like they’re running on primaries, and any light that’ll outdo it will require a lot of $$$$$$$$. lol. Still cracks me up that we call it BLF Beer
RMM
RMM's picture
BLF is generally budget in the beginning for most of us, who then proceed to put $60 worth of parts into a $35 light.
Very cool and very simple solution.  I like it.  Do you think there is enough length for protected cells?
JaredM
JaredM's picture
Yes. They should be no problem. EDIT I checked with four cells measuring ~69mm and I could only manage one thread before I gave up. With softer springs (I used some strong ones) and shorter/no positive contacts it could be done. I figure though if anybody is running this setup they are using IMRs anyway. End EDIT I only have two protected 18650s so I can’t prove it with pics but the way the unit works is there is no lockout. As long as there is one thread engaged I can operate the light. Of course this isn’t a recommended way of running something, I only intend to illustrate the concept at an extreme.
The O-ring on the body tube is still completely covered by the head when fully tightened, since added length is only 1.6mm. I’ll go do my best to simulate protected cells.. might use some magnets or something.
DB Custom
DB Custom's picture
You should be able to run it on one pair, two pairs is a bonus. Try the pair of protected cells you have and leave the other two out…
JaredM
JaredM's picture
Regarding protected cells I’ll say I didn’t give them much/any thought during the design process. Like I mentioned in my edit of post #19, if the user intends to run protected cells, different hardware can be used to accommodate them. The body tube depth from front lip to face of rear pcb is ~70.6mm. This means with a std protected cell at ~69mm, you’ll have 1.6mm remaining for a spring. This is reasonable as long as the right springs are used.
NOW, for those that are really eager to run prot. cells AND have beefy springs that are resistance modded, you can always add some spacers under the rear pcb and gain tons of room (relatively). The body tube with this setup no longer carries current so any material can be used. I’ll measure but the factory screws probably are long enough to give you ~2mm comfortably.
pilotdog68
pilotdog68's picture
Last seen: 9 months 3 days ago
Any updates?
JaredM
JaredM's picture
pilotdog68 wrote:
Any updates?
Yes. I’ve revised the design to enable mechanical lockout with aprox a 1/4 turn. I’m still working on learning eagle. I’ll post 2D drawings of the design here tonight. I may ask for help from the community to get this drawn up in Eagle for the sake of time. I just don’t have enough time to devote to this at the moment. :~
jhalb
jhalb's picture
Last seen: 4 years 9 months ago
8000+ lumens? Silly
JaredM
JaredM's picture
jhalb wrote:
8000+ lumens? Silly
Something around that Wink It’s at least 2x my K40M that’s running full throttle..
jhalb
jhalb's picture
Would you say its more of a flooder than a thrower now comparatively?
JaredM
JaredM's picture
Just did a ceiling bounce test with these two head to head, both on fresh cells. Light meter on the floor, sensor up, underneath a wooden table the lights were tail-standing on. 14lux startup and 12@30sfor the M6, 5 for the K40M (steady). That puts it around 9k+ lumens startup.
JaredM
JaredM's picture
Thrower is such a subjective term. My personal descriptions of a thrower may not match yours, but last I checked it did in the 70K lux range at 30s. I don’t remember startup values, or if I’ve ever recorded them.
