ALL THINGS BUDGET KNIVES
5282 posts / 0 new
ArtieT59
ArtieT59's picture
Last seen: 2 hours 40 min ago
AgentSteel wrote:
Yes, D2, even well treated, is nowhere near ideal for bushcraft knives. In the above video, the tip broke in rotten wood with very light lateral stress Tired
My first thought too- D2 is too hard for hard use. Like my fixed blade ka-Bar Becker necker, made in 1095. Not the best steel obviously, but it has some give to it. Tough edged steel like D2 just has not lateral (?) strength to be bending and prying with. You want something that’s bend not snap.
Check out some of my new lights (picture heavy) and quick first impressions of them here: https://budgetlightforum.com/node/77180
My Sft40 beamshots / comparison thread: https://budgetlightforum.com/node/78100
Ig
Last seen: 1 week 1 day ago
What about this:
Kwispelhond
Kwispelhond's picture
Last seen: 5 hours 20 min ago
D2 is fine steel, about 12% Cr so often called “almost stainless” steel, at that much Cr it’s expected to be less strong than real Carbon-steels but it’s still pretty good compared with most stainless-steels. In fact I’m thinking of buying a D2 outdoor-knife, have my eye on the Real Steel Bushcraft III convex.
I have one Chinese D2 budget knife, a HX Outdoors ZD-031. The steel on that one is excellent but these knives were not the cheapest back then, I have no way to confirm real D2 and it does seems a bit to much stainless but it is simply very good steel. I just wanted to try one of those China-fantastic’s so bought this one to play with: too thick and heavy for my liking so I rarely use it, it is shaving-sharp and flips and falls shut super smooth thou.
Chronovore
Last seen: 5 days 10 hours ago
Lower hardness can be helpful if more toughness is needed. Going softer on D2 might gain a little toughness but also trades away a lot of the edge retention that makes it an attractive steel in the first place. Based on just a few tests I’ve seen from other QSP knives, they run their D2 around 58-59 HRC. Another potential issue could be the purity or consistency of the Chinese D2. We know from LTK’s XRF testing that the composition can vary on Chinese D2.
The German K110 should be better in that respect. The bad reputation on Chinese D2 has given Petrified Fish, Bestech, and a few other brands that usually use it a reason to start importing K110. Either way, the toughness is still only around 5ft/lb at 60HRC. I’d rather avoid these issues in the first place and use a steel like 14C28N. Aside from being much more stainless, 14C28N has roughly six times the toughness at similar hardness!
BTW, if you don’t mind messing up your knives then you can do a mustard test for D2. The steels used by unscrupulous companies to substitute for D2 are usually 3Cr13, 5Cr15, or 8Cr13Mov. All of those steels are notably more stainless. After thoroughly cleaning with isopropyl alcohol, you can put a blob of yellow mustard on the blade for an hour and see what happens. I recently tested this on satin finishes at around 68 degrees Fahrenheit . At just over an hour, Walmart’s Organic Yellow Mustard left a permanent gray mark in the shape of the blob on D2 but wiped away pretty cleanly from 8Cr13Mov.
Bwana
Last seen: 1 day 16 hours ago
If there are any sword guys out there , Vipon has some coupons for swords on Amazon.
https://www.myvipon.com/promotion/index?search=sword&group=
Pete7874
Pete7874's picture
Last seen: 4 hours 21 min ago
I wanna see how people EDC their swords. Smile
Bwana
I use the bread you can buy for a long sub sandwich . You can order 3 to 6 foot lengths from most bakeries. For a slim knife like a bayonet, regular French bread works fine . A loaf of Italian is perfect for Bowie knives.
And you always have a snack handy if you EDC in bread
djmcconn
djmcconn's picture
Last seen: 55 min 15 sec ago
Bwana I like your style!
turkeydance
turkeydance's picture
Last seen: 4 hours 49 min ago
Rusty
Rusty's picture
Last seen: 7 hours 48 min ago
how2 wrote:
This is one for the people who live in the UK.
Has anyone bought pocket knives from China without any problems.
Will customs confiscate the knive?
Bought quite a few over the last few years, without a hitch; however I’ve bought nothing since brexit and would be worried about BF, since they’re confiscating (perfectly legal) CO2 air pistol imports, claiming they’re imitation firearms (they’re not imitation firearms, by law they’re real firearms, you just don’t need an FAC).
xatu
xatu's picture
Very good friends.
I have finished my review of this impressive knife, if you want to take a look you have it in:
https://chinese-knives.blogspot.com/2021/05/review-with-armour-stones-wa-092bk.html
My reviews about knives: : http://chinese-knives.blogspot.com/
how2
Last seen: 6 hours 4 min ago
Bought about 10 knifes shipped into 4 and 6 knifes packages. All of them are small knifes about 12cm length and blade less than 5cm. Only one knife is 16.5cm and blade length 6.5cm.
The smallest knife is 9cm and blade 3.6cm but it locks. The cost taking into account exchange rate and shipping, will cost me £5.09 per knife.
turkeydance
Schrade knives $6 and up
with code WELCOME20.
free shipping, too. one example:
https://www.schrade.com/sale/?srule=price-low-to-high&start=0&sz=12
Chronovore
Chronovore wrote:
turkeydance wrote:
here is a $2.60 (free shipping) example from from Smith & Wesson using code Groundhog….
last time, these sold out fast.
Usually, the gun-branded knives are not very good. As usual though, “good” is relative. For $2.60, that’s an incredible bargain and 7Cr17Mov isn’t unreasonable at the usual $15.99. Edge retention isn’t too far off from 8Cr13Mov and corrosion resistance is actually quite good. Much like 440A, 7Cr17Mov used to be a celebrated steel for budget diving, camping, and survival knives.
Of course, these did sell out right away. Just in the time since you posted, this model is gone. Looking over all the items on sale under ten bucks, only one model was left. It was an 8Cr13Mov knife similarly marked down to $5.97. I ordered it because “what the heck”.
… and they biffed it. I just got an email saying they accidentally oversold a bunch of their clearance stuff. They are sorry and are giving out some one-shot coupon codes for 15% off.
Tangra
Last seen: 7 hours 27 min ago
Can I find on Ali or other site 5 inch fliper knife with solid lock sytem?
Lightbringer
Lightbringer's picture
Last seen: 1 hour 37 min ago
Chronovore wrote:
[S&W] … and they biffed it. I just got an email saying they accidentally oversold a bunch of their clearance stuff. They are sorry and are giving out some one-shot coupon codes for 15% off.
I got the same email, but replied wanting to “make a deal” with what they might actually have.
Turns out the knives I ordered weren’t available in the usual box but the plastic clamshell packages only, and I said I don’t care about that, I’ll take ‘em, so they were ostensibly just shipped today.
So looks like all of mine are complete, woohoo!
They seem to have nice smooth action except the “stonewash” ones (no model number that I saw listed), which seem a bit “gritty” and tight.
They’re all shaving-sharp out of the box, though. Found that out the hard way. Sick
Chronovore
That’s what I get for reading emails on my mobile. Tired
I went through the website looking for a comparable swap. So many of their knives are tip-down only. A bunch are assisted. Some were too heavy. Most were 8Cr13Mov… In a lot of ways, their catalog feels years out of date. The only thing that made any of these remotely interesting was the pricing on the clearance sale.
I’ll see if something works out. Otherwise, I’ll get my $6.99 or whatever back plus a coupon code that I’ll probably never use. BTW, how bad of a cut?
Lightbringer
Wellp, I’m not really A Knife Guy so even outdated stuff works fine for me, if only that I don’t know any better. LOL
Like that go,comma branded PF clone that GB was selling for something like 7bux a pop. I got a few, expecting them to be “disposable” but I’m still banging on my first one that’s holding up great.
My small Sanremu with a thumb stud is nigh impossible (to me) to open one-handy, but the go,comma and most of the S&Ws with flipper-tabs open soooooo smoothly and nicely. Only the stonewash is tight enough to only open part-way.
But for the prices, hellyeah, I’ll take ‘em!
Oy… Facepalm
I only got one other AO, and it clicks into place almost gently, whereas the S&W snaps open with one Hell of a kick.
I was holding it gingerly with only fingertips, seeing how far it needs to go before the spring kicks in and opens it. Was wearing only shorts and flipflops (if only I were Ukrainian, that’d be enough safety gear for driving nails through 18650s, but I’m not).
Anyhoo, it kicks, I lose my grip and drop it, it hits tail-first on the floor and “bounces” somewhat, and gives me a little scratch by my instep. Or so I thought. “Whew, just a scratch…”, only a few seconds later it starts to bleed. And bleed. And bleed. Wtf, am I a closet hæmophiliac?? Nope, it didn’t just give me a scratch, but went straight-in a good ¼ inch or so, the whole tip.
Wellp, that’ll learn me…
Chronovore
The budget market has really come a long way in recent years. Check out brands like Civivi, Tangram, Ruike, CJRB, Harnds, Petrified Fish, etc. Sanrenmu still makes a bunch of tip-down only knives, combo edges, knives in junk steel, etc. However, they also make some amazing knives like the Land series in 12C27. AFAIK, they also make the Ruike and Real Steel knives. Also take a look at the difference between much older Ganzo stuff and their more recent FH line in D2. The S&W knives are clearly on the far side of the rift between where the market was and how far it has come.
Assisted actions have largely been phased out because great manual actions have gotten easier and cheaper to make. Now even sub-$20 counterfeits can be had with captured bearings and dialed-in detents. I seem to recall that cheap and mislabeled Go,Comma (which was made by Petrified Fish) having excellent manual action. Combined with legal issues in some places and mechanical issues such as needing to replace torsion bars in Speedsafe knives, the overall community has been trending away for a while now.
As far as steel, 8Cr13Mov is finally becoming a point of derision. It still rules the big box knife stores with offerings from Kershaw, CRKT, etc. However, enthusiasts can now get Acuto 440, 9Cr18Mov, AR-RPM9, D2, and Sandvik steels at competitive prices. All of those steels can cut circles around 8Cr13Mov and except for D2, all have better corrosion resistance. People walking into a big box store without researching these things online won’t know better. People reading forum posts like this one hopefully will. Innocent
Kwispelhond
I don’t know, I have 2 knives in 8Cr13MoV and I actually like both of them, someone who knows the steel makes a good knife out of every kind that can be hardened enough. Mine carry the names of Spyderco and Sanremnu and the makers behind these 2 brands obviously know this steel and made the best out of it. It does dull out some faster than say D2 or 14C28N but give them 6 or 8 swipes over any sharpener and they shave again. (yes, I also have knives in these 2 steels).
Chronovore
There is an important difference between being good relative to a person’s use and good relative to rest of the market.
For instance, consider 3Cr13. It’s a bottom-tier steel from the same series. Many companies use it to make their liners but we also see it used as blade steel. Edge retention is terrible relative to something like 8Cr13Mov. If a person only uses their knife as a letter opener, not for cutting cardboard but for actual paper envelopes, it is probably okay.
My issue is that if better steels have been widely available within the same price range, and especially if that’s been the case for years, then kudos to the companies offering better steel and thumbs down to the companies that don’t.
Chronovore
Lightbringer wrote:
… Oy… Facepalm
I got a cut like that once. I was tending bar at a pool party sometime last century. The martini glasses were made of actual glass back then. I was barefoot because it was a pool event. Somebody bumped into me while I was carrying a tray. One of the glasses shattered on my toe knuckle. It looked okay until I flexed my toe. Then I could cleanly see the bone for what probably seemed like longer then it actually was. Then the blood started.
There is a current thread discussing AO accidents on Blade Forums. Besides sharing the story of my own Leek pocket bite, I referenced this thread and mentioned what happened to you.
raccoon city
raccoon city's picture
Last seen: 1 min 5 sec ago
I've been collecting assisted-openers since 2008.
I have owned scores of them, and they're what I EDC over 99% of the time (when I have a knife on me.)
I've only drawn blood twice, and each injury was extremely minor.
Neither time was caused by the knife opening or closing.
I just accidentally knicked myself once and poked myself the other time.
I consider myself very lucky.  :-)
EDIT:
Actually, I drew blood one other time, but not by the razor sharp blade.
My most recent purchase was a dud.
It was surprisingly difficult to open the knife by pushing on the flipper, and where I was pressing was jagged, so I chewed up my finger and bled a little bit.
I returned that knife today via USPS.
Rdubya18
Rdubya18's picture
Last seen: 1 day 11 hours ago
Bought this Roper for $11.00 out of curiosity. Really a nice knife .
Lightbringer
Ow. That had to suck.
Not many of my blades tasted blood. Think this one, maybe my go,comma/PF (just scratches; don’t recall actually drawing blood, though), and my old Sanremu.
Worst or at least most annoying cut was from an Xacto blade. Was opening a coconut(!) and it slipped and went like halfway in the fleshy part between thumb and forefinger.
Wouldn’t stop reopening (and rebleeding) with the slightest flexing, so actually filled the gap with stoopit-gloo to seal it shut. Eventually, the little wedge of glue just slid out on its own, quite effortlessly (and when I saw just how deep the blade went in), and I had a little “mouth” in that part of my hand for quite a while.
Can’t help thinking of this scene, and that if I had one of my knives and did that at the end, I’d probably bleed out right then and there.
anotherbot
Last seen: 4 days 15 hours ago
isti242, i saw on your blog there is some PM3 on aliexpress now
if they make some micarta version i will order one
Chronovore
I picked up the new Sencut Snap with Cuibourtia wood scales. I’m impressed for the $45 this cost on Amazon. Between the gorgeous scales, skeletonized liners, sweet action, solid lock-up, and great blade steel; this is on par with much more expensive knives. The Sencut knives use the same 9Cr18Mov as the Civivi knives with WE’s heat treatment. Effectively, it’ll out-cut any other 9Cr18Mov and a lot of the Chinese D2 out there.
I wasn’t sure if the handle would be comfortable based on the pictures but it is. Just know that the stonewashed blade looks a little more gray IRL.
isti242
isti242's picture
Last seen: 9 hours 30 min ago
anotherbot wrote:
isti242, i saw on your blog there is some PM3 on aliexpress now if they make some micarta version i will order one
Only G10 versions are available at the moment. Thanks to the ball bearings the action is pretty good. Have a look at here. Cool
anotherbot
i just received a carbon bugout, so i can wait for more color or material choices laughing
isti242
isti242's picture
Did you go for the Jufule version with real D2 blade?
