ALL THINGS BUDGET KNIVES
5512 posts / 0 new
Chronovore
Last seen: 23 hours 48 min ago
So Bestech released another budget winner and in a decent stainless this time. I almost missed it because this little guy is a Kaviso exclusive. I hadn’t heard of them before. Apparently, they’ve taken over the knife lines from Drop (formerly known as Massdrop) since Drop dropped out of the knife game. Silly
The action is good. The lock-up is solid. I’m especially glad to see them using N690 instead of D2 here. Keeping it under $50 was a bonus. If you’ve seen my criticism of brands like Kershaw and CRKT in recent years, this is the kind of quality for the money that makes me feel that way.
BTW, if it looks a little funny, that might be because the scale edges are offset for the liner lock. I was a little skeptical at first but it’s not uncomfortable in hand.
turkeydance
turkeydance's picture
Last seen: 2 hours 16 min ago
every time it is available,
it sells out really, really fast.
i do not understand that at all.
if the link is broken,
it is already g.o.n.e.
https://www.bladehq.com/item—Boker-Dessert-Warrior-Kalashnikov—108010
raccoon city
raccoon city's picture
Last seen: 15 min 51 sec ago
Location: Palm Desert CA ~ West Coast is the best coast
My eyes!  }P
Lightbringer
Lightbringer's picture
Last seen: 19 min 12 sec ago
That’s one that’ll get through TSA no prob.
Lightbringer
Btw, how much were they going for? For some reason, I really want one.
xevious
xevious's picture
Last seen: 1 min 44 sec ago
Looks like the Hello Kitty wanted a foldable cake knife. Facepalm LOL
There’s also a “Warrior BuffetQuestion Party
xevious
xevious's picture
I’m usually pretty good about keeping my knife blades clean after use. I got a little careless and left a thin bit of debris on my CRKT Squid D2 knife blade. It was on there for probably about 8 hours. When I cleaned off the blade, I noticed there were some stains. Yep, it’s real D2 alright. There had begun some surface level oxidation. Using a scrubbie didn’t get it off. I had to resort to using some silver polish with a paper towel. A bit of scrubbing for a minute or two—stains are now gone.
I’d seen a few other techniques when searching around. I’d avoid using steel wool as that will scratch the steel somewhat, which can ruin a polished or stone washed treatment. Naval jelly is supposed to be a good method. Also a polishing compound like simichrome.
Anyone else use some other techniques to easily remove rust stains from a D2 blade?
brtactical
Last seen: 1 month 1 day ago
WD-40 works well for light rusty
Ragsy
Ragsy's picture
Last seen: 1 day 14 hours ago
xevious wrote:
I'm usually pretty good about keeping my knife blades clean after use. I got a little careless and left a thin bit of debris on my CRKT Squid D2 knife blade. It was on there for probably about 8 hours. When I cleaned off the blade, I noticed there were some stains. Yep, it's real D2 alright. There had begun some surface level oxidation. Using a scrubbie didn't get it off. I had to resort to using some _*silver polish*_ with a paper towel. A bit of scrubbing for a minute or two--stains are now gone. I'd seen a few other techniques when searching around. I'd avoid using steel wool as that will scratch the steel somewhat, which can ruin a polished or stone washed treatment. Naval jelly is supposed to be a good method. Also a polishing compound like simichrome. Anyone else use some other techniques to easily remove rust stains from a D2 blade?
I've had good results from FLITZ ...might be worth considering
We should get sushi Carol
G'day mate, ow ya garn?
Yeah, nah good mate
willc68
willc68's picture
Last seen: 2 days 5 hours ago
Flitz is great for getting rid of rust and pepper spots on non stainless steel. Bar Keepers Friend is also good for rust also.
Plasmatoast
Last seen: 8 hours 14 min ago
On my non Stainless knives, I usually will coat the blade in froglube and let it sit for a while before wiping it off, seems to give some protection to the metal later during use, if the knife will sit or be stored I coat it in wd40 specialist corrosion inhibitor.
For cleaning CLP or froglube work well And for light specks of rust, flitz is good.
Ragsy
Ragsy's picture
I forgot to mention I also give my knives a light coating of Camellia oil after a Flitz polish....acts as a rust inhibitor too
Yeah, nah good mate
turkeydance
xevious….
try Fine Brass Wool.
just like steel wool
but softer scrubbing.
xevious
xevious's picture
Sounds like Flitz is the popular solution. Will be getting some. The silver polish worked and so far the stains are not returning but it did require a few passes to finally clean them off.
Hey TD, I’d never heard of brass wool before. Sounds interesting & will make a point of picking up some — thanks!
Froglube sounds interesting, PT. I wonder if it’s anything like naval jelly? I do liked the idea of being proactive & putting on some kind of coating periodically to reduce staining of D2 blades.
Plasmatoast
I don’t think that frog lube is very similar to the naval jelly. Frog lube is a bio based product and it’s food safe. It’s sold as a eco friendly gun cleaner and lube
JenkinsMatti
Last seen: 3 hours 3 min ago
“Navl Jelley” is a rust remover, it does not prevent rust.
caramba
caramba's picture
Last seen: 3 weeks 5 days ago
I think Naval Jelly and Coke or Coca Cola, have Phosphoric Acid,
Here is a nice video comparing a few rust removers:
max
max's picture
Last seen: 6 hours 10 min ago
caramba wrote:
I think Naval Jelly and Coke or Coca Cola, have Phosphoric Acid, Here is a nice video comparing a few rust removers:
You are correct on the Naval jelly but Coke (coca cola) is Carbonic acid from the carbonation.
 max
Chronovore
Coke, Pepsi, and a few other sodas do in fact contain phosphoric acid. It makes them more acidic than what you’d get from just the dissolved carbon dioxide in plain seltzer.
xatu
xatu's picture
Last seen: 1 day 18 hours ago
Hello guys and girls.
My review of the most extreme parts of the Brother brand!:
https://chinese-knives.blogspot.com/2022/08/quad-review-brother-1615-bro...
My reviews about knives: : http://chinese-knives.blogspot.com/
weklund
weklund's picture
Last seen: 1 hour 17 min ago
Civivi Relic
... Happy Landings ...
